Discuss
fridgidaire oven doesn't heat up
 in
When I turn the oven on, the igniter comes on. I do not hear the "whoosh"" sound that I hear
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » fridgidaire oven doesn't heat up
  #1 (permalink)
Old 05-08-2013, 08:15 AM
Junior Member
debshroom is on a distinguished road
Default fridgidaire oven doesn't heat up
Model Number: FGF3687GBC   Brand: Frigidaire   Age: 1 - 5 years
When I turn the oven on, the igniter comes on. I do not hear the "whoosh"" sound that I hear when I turn on the broiler and that igniter opens the gas valve for the broiler. I replaced the oven igniter but that wasn't any better. Some flames are seen coming from the burner tube but are very few and not strong. Could it be the valve
Related Models
Frigidaire FGF368CJBA Frigidaire/gas Range
Frigidaire FGF368CJBB Frigidaire/gas Range
Frigidaire FGF368CJSA Frigidaire/gas Range
Frigidaire FGF368CJSB Frigidaire/gas Range
Frigidaire FGF368CJTA Frigidaire/gas Range
Frigidaire FGF368CJTB Frigidaire/gas Range
Frigidaire FGF368CXASA Frigidaire/gas Range
Frigidaire FGF368GBA Frigidaire/gas Range
Frigidaire FGF368GBB GAS RANGE
Frigidaire FGF368GBC GAS RANGE
Frigidaire FGF368GBD GAS RANGE
Frigidaire FGF368GBE GAS RANGE
Frigidaire FGF368GBF GAS RANGE
Frigidaire FGF368GBG GAS RANGE
Frigidaire FGF368GBH GAS RANGE
Frigidaire FGF368GBJ GAS RANGE
Frigidaire FGF368GBK GAS RANGE
Frigidaire FGF368GCA GAS RANGE
Frigidaire FGF368GCB GAS RANGE
Frigidaire FGF368GCC GAS RANGE
Frigidaire FGF368GCD GAS RANGE
Frigidaire FGF368GCE GAS RANGE
Frigidaire FGF368GCF GAS RANGE
Frigidaire FGF368GCG GAS RANGE
Frigidaire FGF368GCH GAS RANGE
Frigidaire FGF368GCJ GAS RANGE
Frigidaire FGF368GCK GAS RANGE
Frigidaire FGF368GCM GAS RANGE
Frigidaire FGF368GCN GAS RANGE
Frigidaire FGF368GCP GAS RANGE
Frigidaire FGF368GMA GAS RANGE
Frigidaire FGF368GMB GAS RANGE
Frigidaire FGF368GMC GAS RANGE
Frigidaire FGF368GMD GAS RANGE
Frigidaire FGF368GME GAS RANGE
Frigidaire FGF368GMF GAS RANGE
Frigidaire FGF368GMG GAS RANGE
Frigidaire FGF368GMH GAS RANGE
Frigidaire FGF368GMJ GAS RANGE
Frigidaire FGF368GMK GAS RANGE
Frigidaire FGF368GMN GAS RANGE
Frigidaire FGF368GMP GAS RANGE
Frigidaire FGF368GMR GAS RANGE
Frigidaire FGF368GQA Frigidaire/gas Range
Frigidaire FGF368GQB GAS RANGE
Frigidaire FGF368GQC GAS RANGE
Frigidaire FGF368GQD GAS RANGE
Frigidaire FGF368GQE GAS RANGE
Frigidaire FGF368GQF GAS RANGE
Frigidaire FGF368GQG GAS RANGE
Frigidaire FGF368GQH GAS RANGE
Frigidaire FGF368GQJ GAS RANGE
Frigidaire FGF368GQX GAS RANGE
Frigidaire FGF368GSA Frigidaire/gas Range
Frigidaire FGF368GSB GAS RANGE
Frigidaire FGF368GSC GAS RANGE
Frigidaire FGF368GSD GAS RANGE
Frigidaire FGF368GSE GAS RANGE
Frigidaire FGF368GSF GAS RANGE
Frigidaire FGF368GSG GAS RANGE
Frigidaire FGF368GSH GAS RANGE
Frigidaire FGF368GSJ GAS RANGE
Frigidaire FGF368MXASA Frigidaire/gas Range
Frigidaire FGF374CCBA Frg(v1) / Gas Range
Frigidaire FGF374CCBB Frg(v1) / Gas Range
Frigidaire FGF374CCBC Frg(v1) / Gas Range
Frigidaire FGF374CCBD Frg(v2) / Gas Range
Frigidaire FGF374CCBE Frg(v1) / Gas Range
Frigidaire FGF374CCBF Frg(v1) / Gas Range
Frigidaire FGF374CCBG Frg(v1) / Gas Range
Frigidaire FGF374CCBH Frg(v1) / Gas Range
Frigidaire FGF374CCBJ Frg(v2) / Gas Range
Frigidaire FGF374CCSA Frg(v2) / Gas Range
Frigidaire FGF374CCSB Frg(v2) / Gas Range
Frigidaire FGF374CCSC Frg(v3) / Gas Range
Frigidaire FGF374CCSD Frg(v4) / Gas Range
Frigidaire FGF374CCSE Frg(v2) / Gas Range
Frigidaire FGF374CCSF Frg(v0) / Gas Range
Frigidaire FGF374CCSG Frg(v0) / Gas Range
Frigidaire FGF374CCSH Frg(v1) / Gas Range
Frigidaire FGF374CCSJ Frg(v2) / Gas Range
Frigidaire FGF374CCSK Frg(v3) / Gas Range
Frigidaire FGF374CCSL Frg(v4) / Gas Range
Frigidaire FGF374CCTA Frg(v3) / Gas Range
Frigidaire FGF374CCTB Frg(v3) / Gas Range
Frigidaire FGF374CCTC Frg(v5) / Gas Range
Frigidaire FGF374CCTD Frg(v6) / Gas Range
Frigidaire FGF374CCTE Frg(v3) / Gas Range
Frigidaire FGF374CCTF Frg(v2) / Gas Range
Frigidaire FGF374CCTG Frg(v2) / Gas Range
Frigidaire FGF374CCTH Frg(v3) / Gas Range
Frigidaire FGF374CCTJ Frg(v5) / Gas Range
Frigidaire FGF374CCTK Frg(v6) / Gas Range
Frigidaire FGF375BHBA Frigidaire/gas Range
Frigidaire FGF375BHBB Frigidaire/gas Range
Frigidaire FGF375BHBC Frigidaire/gas Range
Frigidaire FGF375CHSA Frigidaire/gas Range
Frigidaire FGF375CHSB Frigidaire/gas Range
Frigidaire FGF375CHSC Frigidaire/gas Range
Frigidaire FGF375EBA Frigidaire/gas Range
Frigidaire FGF375EBB Frigidaire/range
Frigidaire FGF375EBC Frigidaire/range
Frigidaire FGF375EQA Frigidaire/gas Range
Frigidaire FGF375EQB Frigidaire/range
Frigidaire FGF375EQC Frigidaire/range
Frigidaire FGF375ESA Frigidaire/gas Range
Frigidaire FGF375ESB Frigidaire/range
Frigidaire FGF375ESC Frigidaire/range
Frigidaire FGF375FBB Frigidaire/gas Range
Frigidaire FGF375FBC Frigidaire/range
Frigidaire FGF375FBD Frigidaire/range
Frigidaire FGF375FCA Frigidaire/gas Range
Frigidaire FGF375FCB Frigidaire/range
Frigidaire FGF375FQB Frigidaire/gas Range
Frigidaire FGF375FQC Frigidaire/range
Frigidaire FGF375FQD Frigidaire/range
Frigidaire FGF375FSB Frigidaire/gas Range
Frigidaire FGF375FSC Frigidaire/range
Frigidaire FGF375FSD Frigidaire/range
Frigidaire FGF375GCA Frigidaire/range
  #2 (permalink)
Old 05-08-2013, 11:47 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Based on your post information and description, Yes, it could be the gas valve
Part number: AP3879604
Before you replace the part, you'd want to recheck and make sure the new igniter is mounted and aligned to the burner tube mount properly and there are no loose connections in the wires. Remove the burner tube, unscrew the orifice on the valve and check for debris, grease, spider webs, etc. If all's OK, replace the valve.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridgidaire oven will not heat fjohzl Oven Repair (including Ranges and Cooktops) 4 11-19-2012 12:49 AM
fridgidaire gas oven won't heat Gill Bates Oven Repair (including Ranges and Cooktops) 0 07-12-2011 08:47 PM
Fridgidaire Electric Oven wont heat After self clean fwiggs Oven Repair (including Ranges and Cooktops) 0 07-23-2010 07:05 AM
fridgidaire oven disam Oven Repair (including Ranges and Cooktops) 0 12-20-2008 06:14 PM
Fridgidaire Dryer wont heat Hozer Dryer Repair 8 09-11-2007 02:45 AM
