Discuss
Oven not working after running self clean
 in
After running self-clean function, the oven will not heat up. All of the controls work fine and the broil function
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not working after running self clean
  #1 (permalink)
Old 05-02-2013, 11:14 AM
Junior Member
jennifergts is on a distinguished road
Default Oven not working after running self clean
Model Number: 790.92202014   Brand: Kenmore   Age: 1 - 5 years
After running self-clean function, the oven will not heat up. All of the controls work fine and the broil function works fine. After reading through posts, I thought maybe resetting the thermal limit switch might work. But I can't locate it on the back of the stove after removing the panels. Please help.
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 05-03-2013, 04:44 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Kenmore Range 79092202014 - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../316904441.pdf
It does not look like this unit has a thermal limit switch.
Try unplugging the unit for a couple minutes to see if it will reset.
Check the bake element with a meter.
Check the wiring from the control board to the bake element.
If both are OK odds are that the control board is shot.
Be sure to unplug the unit when working on it.
I am assuming that the oven stays in pre-heat and does not show that it is ready.
If it does show that is ready then you may have an oven sensor problem.
Below is the control board.
Click on the picture for more info about the part.
Part number: AP4587739
You may also need a faceplate as it is peel and stick.
Sometimes it will come off OK by heating it up with a hair dryer but often it gets damaged.
Part number: AP4567241
__________________
  #3 (permalink)
Old 05-03-2013, 07:25 AM
Junior Member
Default
I have unplugged the range for a few minutes and it hasn't helped. If something were wrong with the control panel wouldn't it not work all together? Everything else works except the oven...even the broil function works. What about the temperature probe? Could it also be the problem? Yes...it stays in preheat mode without ever heating up.
  #4 (permalink)
Old 05-03-2013, 02:00 PM
Senior Expert
APP Volunteer
Default
No.
The control board has a lot of parts on it and if one part blows then the function it controls will not work.
That is why I asked about preheat.
If the probe is the problem then the control board thinks it is ready so does not heat up the oven.
Since your unit stays in preheat the control board knows that it should send power to an element but for some reason does not.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven wont work after running self clean kohel Oven Repair (including Ranges and Cooktops) 0 08-31-2012 03:59 PM
Oven not working after self-clean. Help please. philiphotog Oven Repair (including Ranges and Cooktops) 2 04-13-2011 10:14 AM
GE Gas Oven not working after self clean psyc06 Oven Repair (including Ranges and Cooktops) 0 02-05-2011 07:31 AM
Elements not working after running self-clean lusien Oven Repair (including Ranges and Cooktops) 10 04-18-2010 12:31 PM
Oven Not working after 1st self clean ramjm_2000 Oven Repair (including Ranges and Cooktops) 5 07-20-2008 01:35 PM
