The convection does not work. Replaced bad heating coil in back. Still does not work. Fan works. The single wire to convection element has no power. Wire comes from temp control
It suppose to be a second wire connected to the heating element. Look for it.
Gene. P.S. Do not forget to remove the power first.
Thanks. Turns out the contacts on the temperature control were corroded needed to be cleaned.
You are welcome. I'm glad you were able to fix it.
