Discuss
GE Oven and Broiler won't turn on
 in
Hi I am hoping you can help me troubleshoot if it is truly the igniter that needs to be replaced
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Oven and Broiler won't turn on
  #1 (permalink)
Old 04-27-2013, 10:33 AM
Junior Member
kzinszer is on a distinguished road
Default GE Oven and Broiler won't turn on
Model Number: JGBS17PEA1WH   Brand: GE   Age: 5 - 10 years
Hi I am hoping you can help me troubleshoot if it is truly the igniter that needs to be replaced on our oven. I took pictures of the inside part of the oven and have attached them to this email.
Our Oven and Broiler do not work the range stove-top does. My husband said he smelled gas when he had left the oven on to heat for about 10 minutes but it was not hot. My husband actually was able to ignite the front range stove top and the broiler ignited?? He said if you put it on broiler then you will see it will start to glow but nothing will ignite or heat up.
Can you please help me troubleshoot through this?
Thank you!
Model# JGBS17PEA1WH
Serial # is M2125018P
Kathya
Related Models
General Electric JGBS17PEA1WH Gas range
General Electric JGBS17PEA2AD Gas range
General Electric JGBS17PEA2CT Gas range
General Electric JGBS17PEA2WH Gas range
General Electric JGBS17PEA3AD Gas range
General Electric JGBS17PEA3CT Gas range
General Electric JGBS17PEA3WH Gas range
General Electric JGBS17PEA4WH Gas range
General Electric JGBS17PEA5WH Gas range
General Electric JGBS17PEH1CT Gas range
General Electric JGBS17PEH1WH Gas range
General Electric JGBS17PEH2CT Gas range
General Electric JGBS17PEH2WH Gas range
General Electric JGBS17PEK1WW Gas range
General Electric JGBS17PEK2WW Gas range
General Electric JGBS17PEW1AD Gas range
General Electric JGBS17PEW1WH Gas range
General Electric JGBS17PEW2AD Gas range
General Electric JGBS17PEW2WH Gas range
General Electric JGBS18DEN1BB GAS RANGE
General Electric JGBS18DEN1CC GAS RANGE
General Electric JGBS18DEN1WW GAS RANGE
General Electric JGBS18DEN2BB GAS RANGE
General Electric JGBS18DEN2CC GAS RANGE
General Electric JGBS18DEN2WW GAS RANGE
General Electric JGBS18DEN3BB GAS RANGE
General Electric JGBS18DEN3CC GAS RANGE
General Electric JGBS18DEN3WW GAS RANGE
General Electric JGBS18DEN4BB GAS RANGE
General Electric JGBS18DEN4CC GAS RANGE
General Electric JGBS18DEN4WW GAS RANGE
General Electric JGBS18DEN5BB GAS RANGE
General Electric JGBS18DEN5CC GAS RANGE
General Electric JGBS18DEN5WW GAS RANGE
General Electric JGBS18DEN6BB GAS RANGE
General Electric JGBS18DEN6CC GAS RANGE
General Electric JGBS18DEN6WW GAS RANGE
General Electric JGBS18DEN7BB GAS RANGE
General Electric JGBS18DEN7CC GAS RANGE
General Electric JGBS18DEN7WW GAS RANGE
General Electric JGBS18DET1BB GAS RANGE
General Electric JGBS18DET1CC GAS RANGE
General Electric JGBS18DET1WW GAS RANGE
General Electric JGBS18EV1WW Gas range
General Electric JGBS18EV2WW Gas range
General Electric JGBS18EV3WW Gas range
General Electric JGBS18EV4WW Gas range
General Electric JGBS18GEJ1 Electric range
General Electric JGBS18GEJ2 Gas range
General Electric JGBS18GEJ3 Gas range
General Electric JGBS18GEJ4 Gas range
General Electric JGBS18GEJ5 Gas range
General Electric JGBS18GEJ6 Gas range
General Electric JGBS18GEJ7 Gas range
General Electric JGBS18GEN1 GAS RANGE
General Electric JGBS18GER1SA GAS RANGE
General Electric JGBS18GER2SA GAS RANGE
General Electric JGBS18GER3SA GAS RANGE
General Electric JGBS18GER4SA GAS RANGE
General Electric JGBS18GES1 Gas range
General Electric JGBS18GES2 Gas range
General Electric JGBS18GES3 Gas range
General Electric JGBS18GET1SA GAS RANGE
General Electric JGBS18MEN1BS GAS RANGE
General Electric JGBS18MEN2BS GAS RANGE
General Electric JGBS18MEN3BS GAS RANGE
General Electric JGBS18MEN4BS GAS RANGE
General Electric JGBS18MEN5BS GAS RANGE
General Electric JGBS18SER1SS GAS RANGE
General Electric JGBS18SER2SS GAS RANGE
General Electric JGBS18SER3SS GAS RANGE
General Electric JGBS18SET1SS GAS RANGE
General Electric JGBS19BEH1CT Gas range
General Electric JGBS19BEH1WH Gas range
General Electric JGBS19BEH2CT Gas range
General Electric JGBS19BEH2WH Gas range
General Electric JGBS19BEM1CT GAS RANGE
General Electric JGBS19BEM1WH GAS RANGE
General Electric JGBS19BEM2CT GAS RANGE
General Electric JGBS19BEM2WH GAS RANGE
General Electric JGBS19BEM4CT GAS RANGE
General Electric JGBS19BEM4WH GAS RANGE
General Electric JGBS19DEN1BB GAS RANGE
General Electric JGBS19DEN1WW GAS RANGE
General Electric JGBS19DEN2BB GAS RANGE
General Electric JGBS19DEN2WW GAS RANGE
General Electric JGBS19DEN3BB GAS RANGE
General Electric JGBS19DEN3WW GAS RANGE
General Electric JGBS19DEN4BB GAS RANGE
General Electric JGBS19DEN4WW GAS RANGE
General Electric JGBS19DEN5BB GAS RANGE
General Electric JGBS19DEN5WW GAS RANGE
General Electric JGBS19DEN6BB GAS RANGE
General Electric JGBS19DEN6WW GAS RANGE
General Electric JGBS19DEN7BB GAS RANGE
General Electric JGBS19DEN7WW GAS RANGE
General Electric JGBS19DEN8BB GAS RANGE
General Electric JGBS19DEN8WW GAS RANGE
General Electric JGBS19GEP1 Gas range
General Electric JGBS19GEP2 Gas range
General Electric JGBS19GEP3 Gas range
General Electric JGBS19GEP4 Gas range
General Electric JGBS19GEP5 Gas range
General Electric JGBS19GEP6 Gas range
General Electric JGBS19GER1SA GAS RANGE
General Electric JGBS19GER2SA GAS RANGE
General Electric JGBS19GER3SA GAS RANGE
General Electric JGBS19GER4SA GAS RANGE
General Electric JGBS19MEN1BS GAS RANGE
General Electric JGBS19MEN2BS GAS RANGE
General Electric JGBS19MEN3BS GAS RANGE
General Electric JGBS19MEN4BS GAS RANGE
General Electric JGBS19MEN5BS GAS RANGE
General Electric JGBS19MEN6BS GAS RANGE
General Electric JGBS19SER1SS GAS RANGE
General Electric JGBS19SER2SS GAS RANGE
General Electric JGBS19SER3SS GAS RANGE
General Electric JGBS20BEA1AD Gas range
General Electric JGBS20BEA1CT Gas range
General Electric JGBS20BEA1WH Gas range
  #2 (permalink)
Old 04-27-2013, 11:27 AM
Junior Member
Default
Is anyone out there????
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Broiler & Oven turn on at same time Intandem Oven Repair (including Ranges and Cooktops) 3 11-13-2015 04:04 AM
GE Oven and Broiler won't turn on kzinszer Oven Repair (including Ranges and Cooktops) 0 04-27-2013 10:30 AM
oven/broiler do not turn on ovenwoes Oven Repair (including Ranges and Cooktops) 0 01-23-2012 06:41 PM
Oven and broiler won't turn on erichmann Oven Repair (including Ranges and Cooktops) 4 01-16-2011 06:08 PM
Oven broiler gas won't turn off bakerny Oven Repair (including Ranges and Cooktops) 2 11-18-2008 05:28 PM
