Discuss
What size bolt on Jenn-Air A100 cartridge?
 in
Hi, My Jenn-Air range has 2 cartridges for a total of 4 burners. One of my burners has stopped working.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » What size bolt on Jenn-Air A100 cartridge?
  #1 (permalink)
Old 04-26-2013, 10:11 AM
Junior Member
catalogguy is on a distinguished road
Question What size bolt on Jenn-Air A100 cartridge?
Model Number: A100   Brand: Jenn-Air   Age: More than 10 years
My Jenn-Air range has 2 cartridges for a total of 4 burners. One of my burners has stopped working. I have determined that the problem exists within the cartridge: the same element works when installed in the other cartridge, and the problem is the same when i switch the positions of the cartridges. I intend to open the cartridge to examine and test the wiring.
My smallest socket, 10mm, is too large to remove the exterior bolts of the cartridge. I am going to go purchase a set of nut drivers for the size range. Does anyone know whether I will need standard or metric nut drivers?
Thank you.
Related Models
Jenn-Air A100 ELE CARTRIDGE
Jenn-Air A100-8 ELE CARTRIDGE
Jenn-Air A100-C ELE CARTRIDGE
Jenn-Air A100B ELE CARTRIDGE
Jenn-Air A100B-8 ELE CARTRIDGE
Jenn-Air A100B-C ELE CARTRIDGE
Jenn-Air A100L ELE CARTRIDGE
Jenn-Air A100L-C ELE CARTRIDGE
Maytag A100S WASHER-TOP LOADING
Jenn-Air A100S-8 ELE CARTRIDGE
Jenn-Air A100W ELE CARTRIDGE
Jenn-Air A100W-8 ELE CARTRIDGE
Jenn-Air A100W-C ELE CARTRIDGE
Maytag A101 WASHER-TOP LOADING
Maytag A102 WASHER-TOP LOADING
Maytag A102S WASHER-TOP LOADING
Maytag A103 WASHER-TOP LOADING
Maytag A103S WASHER-TOP LOADING
Maytag A104 WASHER-TOP LOADING
Maytag A105 WASHER-TOP LOADING
Jenn-Air A105-8 MISC / ACCESSORY
Jenn-Air A105W-8 MISC / ACCESSORY
Maytag A106 WASHER-TOP LOADING
Jenn-Air A106B ELE CARTRIDGE
Maytag A106S WASHER-TOP LOADING
Jenn-Air A106W ELE CARTRIDGE
Maytag A107 WASHER-TOP LOADING
Maytag A107S WASHER-TOP LOADING
Maytag A108 WASHER-TOP LOADING
Hoover A1089
Maytag A108S WASHER-TOP LOADING
Maytag A110 WASHER-TOP LOADING
Jenn-Air A110-8 MISC / ACCESSORY
Admiral A1100PRA RANGE- F/S STD GAS
Admiral A1100PRA-K RANGE- F/S STD GAS
Admiral A1100PRW RANGE- F/S STD GAS
Admiral A1100PRW-K RANGE- F/S STD GAS
Jenn-Air A111 MISC / ACCESSORY
Jenn-Air A111-8 MISC / ACCESSORY
Maytag A112 WASHER-TOP LOADING
Frigidaire A11ME5E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5F1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5L2 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E2 Frg(v2) / Room Air Conditioner
Frigidaire A11ME8E3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDC2 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDSD3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDTC2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUC2 Frg(v3) / Room Air Conditioner
Frigidaire A11MEUSD2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUTSD2 Frg(v3) / Room Air Conditioner
Jenn-Air A120 MISC / ACCESSORY
Jenn-Air A120-8 MISC / ACCESSORY
Amana A1200S COMMERCIAL MICROWAVES
Jenn-Air A121B ELE CARTRIDGE
Jenn-Air A121B-8 ELE CARTRIDGE
Jenn-Air A121W ELE CARTRIDGE
Jenn-Air A121W-8 ELE CARTRIDGE
Amana A1225S COMMERCIAL MICROWAVES
Jenn-Air A122B ELE CARTRIDGE
Maytag A122B14 RADIANT ELEMENT CARTRIDGE
Jenn-Air A122W ELE CARTRIDGE
Maytag A122W13 RADIANT ELEMENT CARTRIDGE
Frigidaire A1238EC2 Frg(v4) / Room Air Conditioner
Jenn-Air A125B ELE CARTRIDGE
Jenn-Air A126B ELE CARTRIDGE
Jenn-Air A126W ELE CARTRIDGE
Jenn-Air A130F INDUCTION CARTRIDGE
Jenn-Air A130R INDUCTION CARTRIDGE
Jenn-Air A135F INDUCTION CARTRIDGE
Jenn-Air A135R INDUCTION CARTRIDGE
Frigidaire A13MUC2 Frg(v5) / Room Air Conditioner
Frigidaire A13MUD2 Frg(v4) / Room Air Conditioner
Jenn-Air A140 MISC / ACCESSORY
Hoover A1408 WASHER-TOP LOADING
Hoover A1408010 WASHER-TOP LOADING
Jenn-Air A141-C MISC / ACCESSORY
Hoover A1410 WASHER-TOP LOADING
Hoover A1410010 WASHER-TOP LOADING
Hoover A1410B WASHER-TOP LOADING
Jenn-Air A145 MISC / ACCESSORY
Jenn-Air A150 MISC / ACCESSORY
Jenn-Air A150-8 MISC / ACCESSORY
Admiral A1500PRA RANGE- F/S STD ELE
Admiral A1500PRW RANGE- F/S STD ELE
Jenn-Air A151 MISC / ACCESSORY
Jenn-Air A151-8 MISC / ACCESSORY
Frigidaire A1538EC2 Frg(v6) / Room Air Conditioner
Frigidaire A1538UD2 Frg(v5) / Room Air Conditioner
Jenn-Air A158 MISC / ACCESSORY
Jenn-Air A158-8 MISC / ACCESSORY
Maytag A15CA MANUAL, PARTS (WASHER)
Maytag A15CM MANUAL, PARTS (WASHER)
Maytag A15CT MANUAL, PARTS (WASHER)
Maytag A16CA MANUAL, PARTS (WASHER)
Maytag A16CM MANUAL, PARTS (WASHER)
Maytag A16CT MANUAL, PARTS (WASHER)
Maytag A17CA MANUAL, PARTS (WASHER)
Maytag A17CM MANUAL, PARTS (WASHER)
Maytag A17CT MANUAL, PARTS (WASHER)
Maytag A180 WASHER-TOP LOADING
Maytag A181 WASHER-TOP LOADING
Maytag A182 WASHER-TOP LOADING
Maytag A183 WASHER-TOP LOADING
Frigidaire A1838C2 Frg(v7) / Room Air Conditioner
Frigidaire A1838D2 Frg(v6) / Room Air Conditioner
Frigidaire A1838EC2 Frg(v1) / Room Air Conditioner
Frigidaire A1838ED2 Frg(v7) / Room Air Conditioner
Frigidaire A1838UC2 Frg(v8) / Room Air Conditioner
Frigidaire A1838UD2 Frg(v8) / Room Air Conditioner
Maytag A18CA MANUAL, PARTS (WASHER)
Maytag A18CM MANUAL, PARTS (WASHER)
Maytag A18CT MANUAL, PARTS (WASHER)
Frigidaire A18NE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A18NE2E2 Frg(v2) / Room Air Conditioner
Maytag A190 WASHER-TOP LOADING
Maytag A1910 WASHER-TOP LOADING
Maytag A200 WASHER-TOP LOADING
Maytag A200S WASHER-TOP LOADING
  #2 (permalink)
Old 04-26-2013, 04:58 PM
Senior Member
scott5495 is on a distinguished road
Default bolt
you need a standard 1/4 inch nutdriver or socket
  #3 (permalink)
Old 04-26-2013, 05:38 PM
Junior Member
Default
1/4" is the answer. I found that the lug connecting the socket lead to the terminal spade had broken. Also, there spade itself is corroded. Hopefully with this couple of parts the burner will be up and running again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air cartridge issue np5551 Oven Repair (including Ranges and Cooktops) 0 01-25-2013 09:18 AM
Jenn-air stove cartridge Low=High Csmoferret Oven Repair (including Ranges and Cooktops) 0 05-15-2012 05:04 AM
Which Jenn-Air cartridge is better - radiant or coil? ath Oven Repair (including Ranges and Cooktops) 0 07-12-2011 11:11 AM
Jenn Air Replacement cartridge mjbetz@laga.com Oven Repair (including Ranges and Cooktops) 0 02-06-2010 04:56 PM
jenn air cartridge bentfender Oven Repair (including Ranges and Cooktops) 0 03-22-2009 09:37 AM
