Discuss
Clockwise and CCW Temp Increase
 in
I am working on an Tappan oven for a friend and it had an open thermostat. When I went to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Clockwise and CCW Temp Increase
  #1 (permalink)
Old 04-25-2013, 06:14 PM
Junior Member
JohnRTappan is on a distinguished road
Default Clockwise and CCW Temp Increase
Brand: Tappan   Age: More than 10 years
I am working on an Tappan oven for a friend and it had an open thermostat. When I went to get a new thermostat, I found it was "NLA". So I learned something, "NLA" means "no longer available". I gave the service man the number from the thermostat I was needing to replace, and he suggested maybe trying a generic one from Harper Wyman. I ordered it, got it in the mail, ohmed it out and installed it. The problem I am having is the original thermostat had the numbers on the stove back panel and to increase setpoint you turned the control knob counter clockwise. With the Harper Wyman, to increase setpoint, you turn clockwise. I can use a thermocouple and determine approximate temperature positions and make a new plate for the back panel, but I hate to do that if I don't have to. Am I overlooking the obvious here or did I just get the wrong thermostat?
John R.
  #2 (permalink)
Old 04-26-2013, 04:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
What are the numbers from the original thermostat?
What is the part number for the thermostat you installed?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer drum moves clockwise but not counterclockwise electricmedic Washer Repair 0 11-29-2011 04:44 PM
Kenmore Motor will not spin Clockwise. greg5832 Washer Repair 1 10-21-2011 06:23 PM
Cannot increase oven temp after self-clean misc1 Oven Repair (including Ranges and Cooktops) 0 12-05-2009 07:57 AM
no clockwise rotation bluestorm Washer Repair 6 09-26-2009 09:22 AM
Increase oven temp control not working fioman6740 Oven Repair (including Ranges and Cooktops) 1 04-26-2009 05:56 AM
