[FONT="Arial","sans-serif"] havea 12 year old Dacor ERSD36 that started to beep intermittently. Everythingworks perfectly fine and I don’t get any codes or anything else. If I put it insafe/lock mode by pressing the CANCEL button (so it says OFF) it will come outof that mode on its own (and no longer say OFF) and beep beep beep. I reset thecircuit breaker several times and since that didn’t work, I called Dacor andthey of course told me to replace Part # 62707, Oven Control Board. I did thatand went to bed and an hour later, beep beep beep beep. No codes, no flashing,nothing, just the beeping. I can’t find anything online that says what elsecould’ve been wrong with it. When I installed the board, I cleaned all threeconnectors very well. EVERYTHING works on this stove, bake, broil, convection,pure convection, light, timers, everything. I have an appliance tech coming Friday, which I rather avoid of course. Anyadvice? I thought about replacing the “other control panel” also or the TouchPad Membrane part # 62309. Thank you. Please email me at rsylvstr@gmail.com[/FONT]
