Control panel not functioning. Replaced thermal cut-out. Panel is blank with no activity when any control points are pressed.
:confused: Originally Posted by: rslodysko Control panel not functioning. Replaced thermal cut-out. Panel is blank with no activity when any control points are pressed.
