After completing the self cleaning cycle the control panel lost power. The oven door remains locked. There is power to the oven from the breaker. How do I open the oven door?
Turn off the power to the oven. Open the lower oven door. Remove the bottom screw from each of the two side trim pieces. To remove the side trim, pull the bottom out approximately 2", and slide the top down top free it from the control panel. Remove the four screws secured the oven to the cabinet and pull the oven about halfway out. Remove the front top cover and open the control panel.
Now you can access the oven door latch.
