Discuss
Temp inaccurate and weird warnings
 in
My Frigidaire gas oven has begun to act up. Occasionally I get this continuous beeping noise and the display shows
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Temp inaccurate and weird warnings
  #1 (permalink)
Old 02-06-2008, 02:13 PM
Junior Member
rbmanrow is on a distinguished road
Question Temp inaccurate and weird warnings
Model Number: FGFL83DSB   Brand: Frigidaire   Age: 1 - 5 years
My Frigidaire gas oven has begun to act up. Occasionally I get this continuous beeping noise and the display shows F30 and the oven shuts off. I wait a while and reset the temp, sometimes it works fine other times I just get the F30 warning again. Along with this the oven seems very cool. I bought an oven thermometer and it is running a good 50 plus degrees below the set temp. When I put the temp up to compensate it stays low for a while and then it runs the temp up way above where I set it. It was converted when I got it about 2 1/2 years ago from natural gas to propane and it seemed to work fine until the last couple months. I did read my manual and I did the procedure to adjust the temp from the factory setting and I am to the max of +35 degrees and it seems to make no difference. I read on the internet that the F30 warning might mean a module is bad. Is that something I could replace myself and do you think that is the problem? Thanks for the help.
Ads By Google
Related Models
Frigidaire FGFL83DSB Frigidaire/range
Frigidaire FGFL83DSE Frigidaire/gas Range
Frigidaire FGFL87DCA Frigidaire/gas Range
Frigidaire FGFL87DCB Frigidaire/gas Range
Frigidaire FGFL87DCC Frigidaire/range
Frigidaire FGFL87DCD Frigidaire/range
Frigidaire FGFL87DCE Frigidaire/range
Frigidaire FGFL87DCF Frigidaire/gas Range
Frigidaire FGFL87DCG Frigidaire/range
Frigidaire FGFL87DQA Frigidaire/gas Range
Frigidaire FGFL87DQB Frigidaire/range
Frigidaire FGFL87DQC Frigidaire/range
Frigidaire FGFL87DQE Frigidaire/range
Frigidaire FGFL87DQF Frigidaire/range
Frigidaire FGFL87DQG Frigidaire/range
Frigidaire FGFL87DSA Frigidaire/gas Range
Frigidaire FGFL87DSB Frigidaire/range
Frigidaire FGFL87DSC Frigidaire/range
Frigidaire FGFL87DSE Frigidaire/range
Frigidaire FGFL87DSF Frigidaire/range
Frigidaire FGFL87DSG Frigidaire/range
Frigidaire FGFL87GSA GAS RANGE
Frigidaire FGFL87GSB GAS RANGE
Frigidaire FGFL87GSC GAS RANGE
Frigidaire FGFL87GSD GAS RANGE
Frigidaire FGFL87GSE GAS RANGE
Frigidaire FGFL87GSF GAS RANGE
Frigidaire FGFL87GSG GAS RANGE
Frigidaire FGFL87GSH GAS RANGE
Frigidaire FGFL88ACA Frigidaire/gas Range
Frigidaire FGFL88ACB Frigidaire/gas Range
Frigidaire FGFL88ACC Frigidaire/gas Range
Frigidaire FGFL88ASA Frigidaire/gas Range
Frigidaire FGFL88ASB Frigidaire/gas Range
Frigidaire FGFL89CCA Frigidaire/gas Range
Frigidaire FGFL89CCB Frigidaire/gas Range
Frigidaire FGFLMC55ECA Frigidaire/gas Range
Frigidaire FGFLMC55ECB Frigidaire/range
Frigidaire FGFLMC55ECC Frigidaire/range
Frigidaire FGFLMC55GCA GAS RANGE
Frigidaire FGFLMC55GCB GAS RANGE
Frigidaire FGFLMC55GCC GAS RANGE
Frigidaire FGFLMC55GCE GAS RANGE
Frigidaire FGFLMC55GCF GAS RANGE
Frigidaire FGFLMC55GCG GAS RANGE
Frigidaire FGFLMC55GCH GAS RANGE
Frigidaire FGFLMC55GCJ GAS RANGE
Frigidaire FGFLMC55GCK GAS RANGE
Frigidaire FGFLZ87GCA GAS RANGE
Frigidaire FGFLZ87GCB GAS RANGE
Frigidaire FGFLZ87GCC GAS RANGE
Frigidaire FGFLZ87GCE GAS RANGE
Frigidaire FGFLZ87GCF GAS RANGE
Frigidaire FGFLZ87GCG GAS RANGE
Frigidaire FGFLZ87GCH GAS RANGE
Frigidaire FGFS36FUA GAS RANGE
Frigidaire FGFS36FUC GAS RANGE
Frigidaire FGFS36FUD GAS RANGE
Frigidaire FGFS36FWA Frigidaire/range
Frigidaire FGFS36FWB Frigidaire/range
Frigidaire FGFS36FWC GAS RANGE
Frigidaire FGFS36FWD GAS RANGE
Frigidaire FGFS36FWE GAS RANGE
Frigidaire FGFS36FWF GAS RANGE
Frigidaire FGFS36FWG GAS RANGE
Frigidaire FGFS36FWH GAS RANGE
Frigidaire FGFS36FWJ GAS RANGE
Frigidaire FGFS56FSA Frigidaire/range
Frigidaire FGFS68CJBA Frigidaire/gas Range
Frigidaire FGFS68CJSA Frigidaire/gas Range
Frigidaire FGFS68CJTA Frigidaire/gas Range
Frigidaire FGGC3045KBA COOKTOP
Frigidaire FGGC3045KBB COOKTOP
Frigidaire FGGC3045KSA COOKTOP
Frigidaire FGGC3045KSB COOKTOP
Frigidaire FGGC3045KWA COOKTOP
Frigidaire FGGC3045KWB COOKTOP
Frigidaire FGGC3065KBA COOKTOP
Frigidaire FGGC3065KBB COOKTOP
Frigidaire FGGC3065KSA COOKTOP
Frigidaire FGGC3065KSB COOKTOP
Frigidaire FGGC3065KWA COOKTOP
Frigidaire FGGC3065KWB COOKTOP
Frigidaire FGGC3645KBA COOKTOP
Frigidaire FGGC3645KBB COOKTOP
Frigidaire FGGC3645KSA COOKTOP
Frigidaire FGGC3645KSB COOKTOP
Frigidaire FGGC3645KWA COOKTOP
Frigidaire FGGC3645KWB COOKTOP
Frigidaire FGGC3665KBA COOKTOP
Frigidaire FGGC3665KBB COOKTOP
Frigidaire FGGC3665KSA COOKTOP
Frigidaire FGGC3665KSB COOKTOP
Frigidaire FGGC3665KWA COOKTOP
Frigidaire FGGC3665KWB COOKTOP
Frigidaire FGGF3031KBA GAS RANGE
Frigidaire FGGF3031KBB GAS RANGE
Frigidaire FGGF3031KBC GAS RANGE
Frigidaire FGGF3031KBD GAS RANGE
Frigidaire FGGF3031KBE GAS RANGE
Frigidaire FGGF3031KBF GAS RANGE
Frigidaire FGGF3031KBG GAS RANGE
Frigidaire FGGF3031KBH GAS RANGE
Frigidaire FGGF3031KBJ GAS RANGE
Frigidaire FGGF3031KQA GAS RANGE
Frigidaire FGGF3031KQB GAS RANGE
Frigidaire FGGF3031KQC GAS RANGE
Frigidaire FGGF3031KQD GAS RANGE
Frigidaire FGGF3031KQE GAS RANGE
Frigidaire FGGF3031KQF GAS RANGE
Frigidaire FGGF3031KQG GAS RANGE
Frigidaire FGGF3031KQH GAS RANGE
Frigidaire FGGF3031KQJ GAS RANGE
Frigidaire FGGF3031KWA GAS RANGE
Frigidaire FGGF3031KWB GAS RANGE
Frigidaire FGGF3031KWC GAS RANGE
Frigidaire FGGF3031KWD GAS RANGE
Frigidaire FGGF3031KWE GAS RANGE
Frigidaire FGGF3031KWF GAS RANGE
Frigidaire FGGF3031KWG GAS RANGE
  #2 (permalink)
Old 02-06-2008, 04:38 PM
Junior Member
Red face oops
I apologize...the error code is F10 not F30. I saw elsewhere on your site that you have links to error codes but F10 is not listed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven has inaccurate tempuratures andymcd Oven Repair (including Ranges and Cooktops) 0 02-06-2009 11:32 AM
Gas range - weird smell, temp not right elisedavies21 Oven Repair (including Ranges and Cooktops) 0 11-24-2008 09:15 AM
