Discuss
How to replace Bosch Spark Module
 in
Can anyone give me instructions as to how to get at the spark module on my gas cooktop? I am
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to replace Bosch Spark Module
  #1 (permalink)
Old 04-22-2013, 04:30 PM
Junior Member
willieb is on a distinguished road
Unhappy How to replace Bosch Spark Module
Model Number: SGCS365RS   Brand: Thermador   Age: More than 10 years
Can anyone give me instructions as to how to get at the spark module on my gas cooktop? I am reasonably handy but don't even know if I need to remove the unit from the counter in order to work on it.
Thanks!
Related Models
Thermador SGCS365RS GAS COOKTOP
Thermador SGCS365RW GAS COOKTOP
Thermador SGCS456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RB SN 9803
Thermador SGCS456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RS SN 9803
Thermador SGCS456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RW SN 9803
Thermador SGCV36 COOKTOP
Thermador SGCV3601 COOKTOP
Thermador SGCV36G01 COOKTOP
Thermador SGCV36G02 COOKTOP
Amana SGD22TL REF - SXS/I&W
Amana SGD22TW REF - SXS/I&W
Amana SGD26VL REF - SXS/I&W
Amana SGD26VW REF - SXS/I&W
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
White Westinghouse SGR351HQ0 DRYER
White Westinghouse SGR351HQ1 DRYER
White Westinghouse SGR351HS0 DRYER
White Westinghouse SGR351HS1 DRYER
White Westinghouse SGR641HQ0 DRYER
White Westinghouse SGR641HQ1 DRYER
White Westinghouse SGR641HS0 DRYER
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
  #2 (permalink)
Old 04-22-2013, 05:57 PM
Senior Member
scott5495 is on a distinguished road
Default spark module
to access the spark module, remove grates and burner caps. there will be what looks to be brass nuts on each burner. these are venturies that guide the gas up to the unit. these can be hard to remove, but they all have to be removed. once this is complete, remove the knobs and carefully raise the cooktop. there is a light that slides off the indicator lens at the switches. once the top is up you will see the spark module. there are two blue boxes, 1 is the spark module and the other is the spark reignitor. in addition to the spark module there are 2 printed circuit swithces on your gas valve that operate the extra low units. also there are two coils that open and close as these switches operate. if i had more info about the problem i could help you track it down.
  #3 (permalink)
Old 04-22-2013, 07:14 PM
Junior Member
Default
Quote:
Thanks so much. The unit has 5 burners. None of them spark, so I am assuming that the spark module is a gonna?
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace spark module and igniters eholub Oven Repair (including Ranges and Cooktops) 0 01-23-2012 10:25 AM
Just replace the 6 point Spark Module jcpcac Oven Repair (including Ranges and Cooktops) 0 11-12-2011 08:59 AM
need help to replace stove top spark module phillipjohnson Oven Repair (including Ranges and Cooktops) 0 07-11-2011 10:04 AM
how to replace a thermator spark module alexcorea Oven Repair (including Ranges and Cooktops) 3 12-03-2009 07:56 PM
Replace spark module BOBRI Oven Repair (including Ranges and Cooktops) 1 03-01-2009 05:27 PM
