Discuss
elements not working
 in
Ran cleaning cycle. After that both elements not working. Checked both with meter. Still getting continuity. So sensor or thermostat.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » elements not working
  #1 (permalink)
Old 04-22-2013, 02:33 PM
Junior Member
korean1 is on a distinguished road
Default elements not working
Model Number: RMC305PDQ2   Brand: Whirlpool   Age: More than 10 years
Ran cleaning cycle. After that both elements not working. Checked both with meter. Still getting continuity. So sensor or thermostat. Both read open contacts. Are both NO or etc.
On website the thermostat is no longer available.
Control board works fine.
Related Models
Whirlpool RMC305PDQ2 30" BUILT-IN ELECTRIC COMBO
Whirlpool RMC305PDQ4 30"BUILT-IN ELECTRIC WALL OVEN
Whirlpool RMC305PDZ1 30" BUILT-IN ELECTRIC COMBO
Whirlpool RMC305PDZ2 30" BUILT-IN ELECTRIC COMBO
Whirlpool RMC305PDZ4 30"BUILT-IN ELECTRIC WALL OVEN
Whirlpool RMC305PVB00 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVB01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVQ00 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVQ01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVS00 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVS01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVT00 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Whirlpool RMC305PVT01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Amana RMC700 MICROWAVE - CONVECTION
Amana RMC720 MICROWAVE - CONVECTION
Amana RMC720A MICROWAVE - CONVECTION
Amana RMC800E MICROWAVE - CONVECTION
Amana RMC800W MICROWAVE - CONVECTION
Amana RMC810E MWAVE - FAMILY SIZE (60 HZ)
Amana RMC810W MWAVE - FAMILY SIZE (60 HZ)
Amana RMD269 RANGE- S/I STD GAS
Amana RMD335 RANGE- S/I STD GAS
Amana RMD339 RANGE- S/I STD GAS
Amana RMD357 RANGE- S/I STD GAS
Amana RMD359 RANGE- S/I STD GAS
Amana RMD364 RANGE- S/I STD GAS
Amana RMD379 RANGE- S/I STD GAS
Amana RMD393 RANGE- S/I STD GAS
Amana RMD395 RANGE- S/I STD GAS
Amana RMD399 RANGE- S/I STD GAS
Amana RMD664 RANGE- S/C S/I DDRAFT GAS
Amana RMD669 RANGE- S/I STD GAS
Amana RMD679 RANGE- S/I STD GAS
Roper RME23300 24" ELECTRIC FREESTANDING RANGE STANDARD CLEAN OVEN
Roper RME30000 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME30001 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME30002 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME30003 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME30100 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME30101 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME32300 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME32301 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME32302 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper RME32303 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Amana RMN380UL RANGE- S/I STD GAS
Amana RMN380UW RANGE- S/I STD GAS
Amana RMN381UL RANGE- S/I STD GAS
Amana RMN381UW RANGE- S/I STD GAS
Amana RMN383UL RANGE- S/I STD GAS
Amana RMN383UW RANGE- S/I STD GAS
Amana RMN385UL RANGE- S/I STD GAS
Amana RMN385UW RANGE- S/I STD GAS
General Electric RMQ80UB2F Refrigerator
Amana RMR340 RANGE- S/C S/I DDRAFT GAS
Amana RMR345 RANGE- S/C S/I DDRAFT GAS
Amana RMR359 RANGE- S/C S/I DDRAFT GAS
Amana RMR364 RANGE- S/C S/I DDRAFT GAS
Amana RMR395 RANGE- S/C S/I DDRAFT GAS
Amana RMR398 RANGE- S/C S/I DDRAFT GAS
Amana RMS112 RANGE- S/C S/I DDRAFT GAS
Amana RMS113 RANGE- S/C S/I DDRAFT GAS
Amana RMS269 RANGE- S/I STD GAS
Amana RMS305 RANGE- S/C S/I DDRAFT GAS
Amana RMS306 RANGE- S/I STD GAS
Amana RMS312 RANGE- S/C S/I DDRAFT GAS
Amana RMS313 RANGE- S/C S/I DDRAFT GAS
Amana RMS335 RANGE- S/I STD GAS
Amana RMS339 RANGE- S/I STD GAS
Amana RMS340 RANGE- S/C S/I DDRAFT GAS
Amana RMS341 RANGE- S/C S/I DDRAFT GAS
Amana RMS342-OF RANGE- S/C S/I DDRAFT GAS
Amana RMS343 RANGE- S/C S/I DDRAFT GAS
Amana RMS345 RANGE- S/I STD GAS
Amana RMS346 RANGE- S/C S/I DDRAFT GAS
Amana RMS351 RANGE- S/C S/I DDRAFT GAS
Amana RMS352 RANGE- S/I STD GAS
Amana RMS353 RANGE- S/I STD GAS
Amana RMS354 RANGE- S/I STD GAS
Amana RMS356 RANGE- S/C S/I DDRAFT GAS
Amana RMS357 RANGE- S/I STD GAS
Amana RMS357-OF RANGE- S/C S/I DDRAFT GAS
Amana RMS358 RANGE- S/I STD GAS
Amana RMS359 RANGE- S/I STD GAS
Amana RMS359-OF RANGE- S/C S/I DDRAFT GAS
Amana RMS361-OF RANGE- S/C S/I DDRAFT GAS
Amana RMS363U RANGE- S/I STD GAS
Amana RMS363UL RANGE- S/I STD GAS
Amana RMS363UW RANGE- S/I STD GAS
Amana RMS368 RANGE- S/I STD GAS
Amana RMS369 RANGE- S/I STD GAS
Amana RMS370 RANGE- S/I STD GAS
Amana RMS371 RANGE- S/C S/I DDRAFT GAS
Amana RMS379 RANGE- S/I STD GAS
Amana RMS380 RANGE- S/I STD GAS
Amana RMS399 Range - S/i Std Gas
Amana RMS640 Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 04-22-2013, 03:18 PM
Senior Member
scott5495 is on a distinguished road
Default elements
unplug your thermistor and test. it should read between 1000- 1100 ohms
or very close to these numbers. if it reads open it is bad. since it happened after you cleaned it, this sounds like the likely problem. some ovens have a resetable safety thermostat. if you have it, check the wiring diagram.
  #3 (permalink)
Old 04-23-2013, 03:33 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool RMC305PDQ2 Wall Oven - AppliancePartsPros.com
See the attachment for the tech sheet
Odds are that the thermostat (thermal cut-off) (item 37 in the Oven Parts section) has blown.
Could be that you have lost the 240 volts so you may want to check it.
As scott5495 said it is also a good idea to check the oven sensor to make sure it is within spec.
If the thermal cut-off is blown once it is replaced check the actual oven temperature at around 400 degrees just in case the oven is running hot and needs recalibration.
__________________
  #4 (permalink)
Old 04-23-2013, 06:39 AM
Junior Member
Default
thanks for the replies. Lets say that its the thermostat. Now the problem of getting the part that is not available.
Suggestions?
EDIT: ok just ohm'd the Thermostat. Completely open. Sensor readd 1.09ohms. So probably good.
So again...sounds like i might just be in to buing a new oven all together? Unless i can find this part...
  #5 (permalink)
Old 04-23-2013, 03:42 PM
Senior Member
Default thermostat
check the thermo for a temp, such as L200. may be able to match one up
  #6 (permalink)
Old 04-24-2013, 03:52 AM
Senior Expert
APP Volunteer
Default
Here is the thermostat
Part number: AP2929236
The L135C on it means that it blows at 135 degrees C or 2785 degrees F.
You could take it to a local parts supply house and they may be able to find one for you.
Also you could go to AppliancePartsPros.
Then enter the Range/Cooktop/Oven section and search for thermostat.
then search through the results to find one that is a close match to yours.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating Elements Not Working Luketuomenoksa Dryer Repair 3 07-22-2012 05:58 PM
No elements working raspark Oven Repair (including Ranges and Cooktops) 1 05-27-2012 12:49 AM
Both elements not working amos81 Oven Repair (including Ranges and Cooktops) 0 04-08-2012 09:43 AM
both elements not working dodalu Oven Repair (including Ranges and Cooktops) 1 01-09-2011 02:57 PM
Elements quit working JakeT Oven Repair (including Ranges and Cooktops) 1 04-15-2010 02:20 AM
