Discuss
Frigidaire range oven problem...
 in
Hello, I have a Frigidaire Gallery (model# GSG3PZBCB), that started to have problems with the oven. Starting up the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire range oven problem...
  #1 (permalink)
Old 04-22-2013, 08:58 AM
Junior Member
Cr00zng is on a distinguished road
Default Frigidaire range oven problem...
Brand: Frigidaire   Age: Less than 1 year
Hello,
Starting up the oven by setting the bake temperature works and after a while the oven beeps to indicate that it is ready. There's a ten degree difference between the set and actual temperatures, 360 vs. 370, which is fine. The problem is that at times, once the baking goods placed in the oven, the temperature drops continuously. After about 20 minutes, the temperature observed with thermometer is at 200 degree, the burner does not come on, and the range makes a humming noise. Cranking up the temperature to 400 degree does initiate the preheat cycle and the temperature does rise even above 400 degree, pretty much ruining the baking goods, but the humming noise remains.
Other times the oven would not "cool off", instead it goes to 400+ degree, but exhibits no humming noise. That's not good for baking either; I meant the temperature and not the humming noise...
The "sweet spot" from temperature wise seems to be around 315 degree, where it seems to be working normally. The burner does come on and shuts off around that temperature range. It also seems to make a difference, if the oven is cold started vs. warm oven. The cold start has the first, while the warm start has the second symptom.
I don't have much experience with gas ranges, but do have some experience with other gas appliances, such as hot water heaters, furnace, etc. From the novice range troubleshooter's perspective, there might be some issue with the oven thermostat, the gas valve, or both. Could someone with more experience chime in help me with troubleshooting this oven?
TIA...
Last edited by Cr00zng : 04-22-2013 at 09:01 AM. Reason: Spelling, what I could find...
  #2 (permalink)
Old 04-22-2013, 04:50 PM
Senior Member
scott5495 is on a distinguished road
Default oven
the oven should have a thermistor instead of a thermostat. remove back of range and you should find a plastic connector [ usually 2 white wires ] unplug the connector and check the thermistor. it should read about 1000 to 1100 ohms at room temperature
  #3 (permalink)
Old 04-23-2013, 02:16 PM
Junior Member
Default
Thanks Scott5495...
I won't have time to check the thermistor with the Volt meter until this Friday, but will get back to you then.
I do home that this place sells thermistor, a quick search did not find it, but it could be under a different name.
  #4 (permalink)
Old 04-26-2013, 10:59 AM
Junior Member
Default
Well, the thermistor has a resistance of 1,079 Ω, which is within the limits.
Since the oven starts up just fine, the dual purpose safety valve should be just fine. Could it be the circuit board that has some problems?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire range conversion back to nat. gas problem Danno185 Oven Repair (including Ranges and Cooktops) 5 01-23-2017 09:15 AM
Frigidaire Electric Oven/Range Problem stevo7fgg Oven Repair (including Ranges and Cooktops) 2 06-10-2012 03:09 AM
frigidaire gas range oven repairmann Oven Repair (including Ranges and Cooktops) 1 11-07-2011 08:15 AM
Frigidaire Range Oven Problem bgarrett6 Oven Repair (including Ranges and Cooktops) 1 01-26-2011 02:46 PM
Frigidaire electric smoothtop range - element problem digglife Oven Repair (including Ranges and Cooktops) 2 09-04-2009 03:24 PM
