Discuss
Replaced Glass Cooktop, Broke Heating Element or Burner
 in
I just replaced the glass cooktop on my oven. When I was moving the burners from the old top to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replaced Glass Cooktop, Broke Heating Element or Burner
  #1 (permalink)
Old 04-21-2013, 09:08 AM
Junior Member
terrymell is on a distinguished road
Default Replaced Glass Cooktop, Broke Heating Element or Burner
Brand: Kitchen Aid   Age: 5 - 10 years
I just replaced the glass cooktop on my oven. When I was moving the burners from the old top to the new top I damaged one of the burners. The hard claylike ring inside the burner broke into several pieces. I set that aside and finished installing the cooktop. The burner works, but is there any danger or hazard because of that broken piece? I'm not sure what that does, but it obviously has a purpose. Any help would be appreciated.
  #2 (permalink)
Old 04-21-2013, 01:49 PM
Senior Member
scott5495 is on a distinguished road
Default replaced glass cooktop
the grey ring around the burner is insulation. it keeps heat from leaking past the outside of the burner. take the pieces and put into place as close as possible and mount burner, should be o.k. unless there is a gap larger than 2 inches.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replaced 2 burners for glass top still not heating traiaberg Oven Repair (including Ranges and Cooktops) 0 01-27-2011 06:28 AM
kenmore glass top front right heating element replaced still will not work donbrewster Oven Repair (including Ranges and Cooktops) 1 10-20-2010 05:29 PM
heating element broke after installing vagannaway Refrigerator & Freezer Repair 13 08-21-2010 08:49 AM
Kenmore Stackable Heating element broke smachappy Dryer Repair 1 12-08-2009 04:02 PM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
