Discuss
Oven Error Codes & Won't Heat Fully
 in
We had gotten error codes F2 and F3 which would then shut down the oven. We've read that these codes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes & Won't Heat Fully
  #1 (permalink)
Old 04-18-2013, 08:46 AM
Junior Member
davem68 is on a distinguished road
Default Oven Error Codes & Won't Heat Fully
Model Number: fed387chsc   Brand: Frigidaire   Age: More than 10 years
We had gotten error codes F2 and F3 which would then shut down the oven. We've read that these codes apply to the temperature probe or wiring. Now the codes have stopped and the oven will heat to 335 or so slowly ..it appears only the top heating element is working. I replace the bottom element about 6 months ago as it had broken in half in one place and was obviously no longer working. The oven worked fine after that replacement until last week when the error codes started. My question ...is it the temperature probe, the heating element (again) or something else. I also noticed that it appears the fan located at the rear of the oven is not working ...at least I see no blade movement at all when the door is opened (and understand that it shuts off when the door is opened ...but would think there would still be some slow down movement. What steps / parts would you suggest. Thanks, Dave
Related Models
Frigidaire FED387CHSC Frg(v0) / Range
Frigidaire FED40P2 Frg(v3) / Dehumidifier
Frigidaire FED40P4 Frg(v2) / Dehumidifier
Frigidaire FED50P1 Frg(v4) / Dehumidifier
Frigidaire FED50P3 Frg(v3) / Dehumidifier
Frigidaire FEF300PADA Frg(v2) / Electric Range
Frigidaire FEF300PAWA Frg(v1) / Electric Range
Frigidaire FEF303BADA Frg(v2) / Electric Range
Frigidaire FEF303BAWA Frg(v1) / Electric Range
Frigidaire FEF303BWA Frigidaire/electric Range
Frigidaire FEF303CWA Frigidaire/electric Range
Frigidaire FEF303CWB Frigidaire/electric Range
Frigidaire FEF303CWC Frigidaire/electric Range
Frigidaire FEF303CWD Frigidaire/electric Range
Frigidaire FEF303CWE Frigidaire/range
Frigidaire FEF303CWF ELECTRIC RANGE
Frigidaire FEF303CWG ELECTRIC RANGE
Frigidaire FEF303CWH ELECTRIC RANGE
Frigidaire FEF303CWJ ELECTRIC RANGE
Frigidaire FEF303HWA ELECTRIC RANGE
Frigidaire FEF303HWB ELECTRIC RANGE
Frigidaire FEF303KWA ELECTRIC RANGE
Frigidaire FEF303KWB ELECTRIC RANGE
Frigidaire FEF304PHDB Frigidaire/electric Range
Frigidaire FEF304PHWB Frigidaire/electric Range
Frigidaire FEF304PHWY Frigidaire/electric Range
Frigidaire FEF305PHDA Frg(v1) / Electric Range
Frigidaire FEF305PHDB ELECTRIC RANGE
Frigidaire FEF305PHSA ELECTRIC RANGE
Frigidaire FEF305PHSB ELECTRIC RANGE
Frigidaire FEF305PHSC Frigidaire/electric Range
Frigidaire FEF305PHTA ELECTRIC RANGE
Frigidaire FEF305PHTB ELECTRIC RANGE
Frigidaire FEF305PHWA Frg(v2) / Electric Range
Frigidaire FEF305PHWB ELECTRIC RANGE
Frigidaire FEF305PHWC Frigidaire/electric Range
Frigidaire FEF305SHDC Frigidaire/electric Range
Frigidaire FEF305SHWC Frigidaire/electric Range
Frigidaire FEF311SADA Frg(v2) / Electric Range
Frigidaire FEF311SADB Frg(v1) / Electric Range
Frigidaire FEF311SADC Frg(v2) / Electric Range
Frigidaire FEF311SADD Frg(v1) / Electric Range
Frigidaire FEF311SADE Frg(v1) / Electric Range
Frigidaire FEF311SADF Frg(v1) / Electric Range
Frigidaire FEF311SADG Frg(v1) / Electric Range
Frigidaire FEF311SAWA Frg(v1) / Electric Range
Frigidaire FEF311SAWB Frg(v3) / Electric Range
Frigidaire FEF311SAWC Frg(v4) / Electric Range
Frigidaire FEF311SAWD Frg(v2) / Electric Range
Frigidaire FEF311SAWE Frg(v2) / Electric Range
Frigidaire FEF311SAWF Frg(v2) / Electric Range
Frigidaire FEF311SAWG Frg(v2) / Electric Range
Frigidaire FEF311SAWH Frg(v0) / Range
Frigidaire FEF312ASA Frigidaire/range
Frigidaire FEF312BSA Frigidaire/electric Range
Frigidaire FEF312BSB Frigidaire/electric Range
Frigidaire FEF312BSC Frigidaire/electric Range
Frigidaire FEF312BSD Frigidaire/electric Range
Frigidaire FEF312BSE Frigidaire/range
Frigidaire FEF312BSF ELECTRIC RANGE
Frigidaire FEF312BSG ELECTRIC RANGE
Frigidaire FEF314AUA Frigidaire/range
Frigidaire FEF314AUB Frigidaire/electric Range
Frigidaire FEF314AWA Frigidaire/range
Frigidaire FEF314AWB Frigidaire/electric Range
Frigidaire FEF314BUA Frigidaire/electric Range
Frigidaire FEF314BUB Frigidaire/electric Range
Frigidaire FEF314BWA Frigidaire/electric Range
Frigidaire FEF314BWB Frigidaire/electric Range
Frigidaire FEF316AQA Frigidaire/range
Frigidaire FEF316AQB Frigidaire/electric Range
Frigidaire FEF316ASA Frigidaire/range
Frigidaire FEF316ASB Frigidaire/electric Range
Frigidaire FEF316BQA Frigidaire/electric Range
Frigidaire FEF316BQB Frigidaire/electric Range
Frigidaire FEF316BQC Frigidaire/electric Range
Frigidaire FEF316BQD Frigidaire/electric Range
Frigidaire FEF316BQE Frigidaire/range
Frigidaire FEF316BQF ELECTRIC RANGE
Frigidaire FEF316BQG ELECTRIC RANGE
Frigidaire FEF316BQX ELECTRIC RANGE
Frigidaire FEF316BSA Frigidaire/electric Range
Frigidaire FEF316BSB Frigidaire/electric Range
Frigidaire FEF316BSC Frigidaire/electric Range
Frigidaire FEF316BSD Frigidaire/electric Range
Frigidaire FEF316BSF Frigidaire/range
Frigidaire FEF316BSG ELECTRIC RANGE
Frigidaire FEF316BSH ELECTRIC RANGE
Frigidaire FEF316BSJ ELECTRIC RANGE
Frigidaire FEF316WGSA Frg(v1) / Electric Range
Frigidaire FEF316WGSB Frg(v1) / Electric Range
Frigidaire FEF316WGSC Frg(v2) / Electric Range
Frigidaire FEF316WGSD Frg(v3) / Electric Range
Frigidaire FEF316WGSE Frigidaire/electric Range
Frigidaire FEF316WGSF Frigidaire/electric Range
Frigidaire FEF316WGTA Frg(v2) / Electric Range
Frigidaire FEF316WGTB Frg(v4) / Electric Range
Frigidaire FEF316WGTC Frg(v5) / Electric Range
Frigidaire FEF316WGTD Frg(v6) / Electric Range
Frigidaire FEF316WGTE Frigidaire/electric Range
Frigidaire FEF317HBA ELECTRIC RANGE
Frigidaire FEF317HSA ELECTRIC RANGE
Frigidaire FEF322BADA Frg(v2) / Electric Range
Frigidaire FEF322BADB Frg(v1) / Electric Range
Frigidaire FEF322BADC Frg(v1) / Electric Range
Frigidaire FEF322BADD Frg(v1) / Electric Range
Frigidaire FEF322BADE Frg(v1) / Electric Range
Frigidaire FEF322BADF Frg(v1) / Electric Range
Frigidaire FEF322BADG Frg(v1) / Electric Range
Frigidaire FEF322BADH Frg(v1) / Electric Range
Frigidaire FEF322BADJ Frg(v1) / Electric Range
Frigidaire FEF322BADK Frg(v1) / Electric Range
Frigidaire FEF322BADL Frg(v2) / Electric Range
Frigidaire FEF322BADM Frg(v3) / Electric Range
Frigidaire FEF322BAWA Frg(v1) / Electric Range
Frigidaire FEF322BAWB Frg(v2) / Electric Range
Frigidaire FEF322BAWC Frg(v2) / Electric Range
Frigidaire FEF322BAWD Frg(v2) / Electric Range
Frigidaire FEF322BAWE Frg(v2) / Electric Range
Frigidaire FEF322BAWF Frg(v2) / Electric Range
  #2 (permalink)
Old 04-18-2013, 07:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello Dave,
Check the Bake (bottom) heating element for continuity.
If the heating element if good, replace the oven control board.
The fan on the back wall in the oven is for convection only and should work only when you use the convection cooking.
- The control board Part number: 318012901
Here are the breakdown diagrams and Parts for Frigidaire FED387CHSC Range - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Xfe361lvb Oven Wont Heat,no Error Codes awvufan76 Oven Repair (including Ranges and Cooktops) 9 01-11-2013 12:18 PM
whjirlpool oven won't heat and gets error codes E-1 F-1 tmlscm Oven Repair (including Ranges and Cooktops) 3 03-24-2012 11:43 AM
ge oven f2 f3 error codes geraheinz Oven Repair (including Ranges and Cooktops) 0 11-17-2010 05:12 PM
GE oven error codes bdeinhardt@aol.com Oven Repair (including Ranges and Cooktops) 5 07-03-2009 11:41 AM
No error codes, no heat from oven, ignitors on stovetop non-op rvaeponce Oven Repair (including Ranges and Cooktops) 6 11-15-2008 09:26 AM
