Discuss
Oven Buttons not working and igniter problem
 in
Is there any chance the burner has an orafice clogged that feeds the igniter?
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Buttons not working and igniter problem
  #11 (permalink)
Old 06-28-2013, 01:47 PM
Junior Member
jimtone is on a distinguished road
Default JGS8860BDP range
  #12 (permalink)
Old 06-28-2013, 01:54 PM
Junior Member
Default Jenn-air JGS8860BDP
I have the same range which was bought new in late 2006 that has worked fine up until this month when the oven has started taking a longer time to lite and sometimes it will not reach upper temps ( 425 and up ). We were using the oven last week set on 450 and it stalled at 375. Other times it doesn't seam to want to lite the oven as it used to?? I went to an appliance parts site that offers help, that suggested it may be the temp probe. Mine is the shorter 3 inch probe, but I'm not sure if this is the problem. Just thinking out loud it seamed it could be the control panel also even though that was not one of the 4 parts the site suggested?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven Buttons Not Working tomkj Oven Repair (including Ranges and Cooktops) 0 10-06-2012 06:42 AM
Oven igniter problem robbfox Oven Repair (including Ranges and Cooktops) 0 03-05-2011 01:03 PM
Buttons not working on Jenn Air stove/oven trickitytrav Oven Repair (including Ranges and Cooktops) 0 03-10-2010 01:34 PM
Problem removing a round GE oven igniter norm647 Oven Repair (including Ranges and Cooktops) 5 08-17-2009 07:36 PM
GE Oven touchpad buttons not working philko Oven Repair (including Ranges and Cooktops) 1 06-23-2008 12:56 PM
