Discuss
oven temp off
 in
my gas oven temperature is about 75 degrees higher than the setting. can this be adjusted
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven temp off
  #1 (permalink)
Old 04-11-2013, 05:00 PM
Junior Member
laurieat is on a distinguished road
Default oven temp off
Brand: GE   Age: 5 - 10 years
  #2 (permalink)
Old 04-11-2013, 06:51 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
I'm afraid not.You need to replace the temperature control. If you'll provide the model number of the unit, I'll be able to help with the part number.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven heats up to Temp, but wont light back up to keep at temp Pooler Oven Repair (including Ranges and Cooktops) 1 05-06-2014 08:46 AM
Actual Oven Temp Lower Than Set Temp oddie Oven Repair (including Ranges and Cooktops) 0 01-05-2012 06:06 PM
Internal Oven temp 100 degrees hotter than set temp saadragna Oven Repair (including Ranges and Cooktops) 1 11-14-2010 06:52 AM
oven temp selector and temp in oven varies significantly larry68417 Oven Repair (including Ranges and Cooktops) 1 11-12-2010 08:02 PM
Oven temp varies from display temp topxfuelx69 Oven Repair (including Ranges and Cooktops) 0 10-14-2009 02:45 PM
