Cant stop range from beeping. Have tried unplugging to reset. Would this beeping occur if the heat sensor was bad? Is this an indication that the computer board is is afailure mode? Any idea's......
Groups: APP Team
Hi. Do you see any failure codes displayed? If not - disconnect the control panel's flex ribbon connector from the control board and then plug the range back in. If the beeping stops - replace the control panel, if not - replace the control board. Here are the breakdown diagrams and Top Assembly parts for Jenn-Air JGS8750ADS - AppliancePartsPros.comPost the results. Simon.
