Discuss
Kenmore Range oven handle comes loose, Model 790.94452700
 in
The handle on the oven of my Kenmore 790.94452700 (made by Frigidaire) comes loose every month or so after tightening
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Range oven handle comes loose, Model 790.94452700
  #1 (permalink)
Old 04-10-2013, 01:43 PM
Junior Member
Turbobob is on a distinguished road
Question Kenmore Range oven handle comes loose, Model 790.94452700
Model Number: 790.94452700   Brand: Kenmore   Age: 1 - 5 years
The handle on the oven of my Kenmore 790.94452700 (made by Frigidaire) comes loose every month or so after tightening it. The screw on the left side loosens up, while the right side screw is fine.
I have checked the plastic insert that the screw threads go into, and there are no cracks or damage that I can see.
The handle part number is 316443601.
I have tried putting teflon tape on the threads to enlarge the end, and even put some high temperature glue on the threads to keep the screw from loosening, but to no avail.
My next thoughts are to use a screw that is about 1/4" longer and use a lock washer to get a better grip , or to use the carpenter's trick of inserting a small toothpick into the plastic screw hole to put more tension on the screw when tightened.
This situation does represent a possible hazard when opening the oven door and the handle comes loose from it.
Any thoughts or previous experience with this issue?
Thanks in advance.
Turbobob
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 04-11-2013, 05:11 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You may not be able to see a crack with the naked eye. It may even be difficult to see it with a magnifying glass.
The lock washer may work.
Not sure about a longer screw, you may not be able to tighten it up properly.
Adding a toothpick will probably just crack the handle's screw receptacle.
Why not just replace the handle.
Click on the picture for more info
Part number: AP3906094
__________________
  #3 (permalink)
Old 11-17-2015, 11:59 AM
Junior Member
Thomshere is on a distinguished road
Smile Loose Handle on Kenmore Oven Door
We have experienced the problem with the loose handle on our Kenmore range oven door for the last four years. Tightening it several times a week. Poor engineering seems to be the problem, Metal screws heated by the oven inserted into a plastic screw hole. The forums I visited suggest the problem hasn't been corrected on replacement handles.
I encountered what seems to be a no cost solution while browsing through an old, old edition of Popular Mechanics Magazine. The writer suggested when dealing with screws that were stripped out to take some braided copper wire from like a 16 gauge extension cord. Strip off the insulation , unbraid the wire, and insert it into the screw hole, then tighten the screw.
I tried this several months ago and to my amazement I have not had to tightened the handle on the oven again in that time.
Seems to be working for me!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loose door handle on electric range rsprange Oven Repair (including Ranges and Cooktops) 3 03-01-2011 12:53 PM
Oven door handle is loose mflips Oven Repair (including Ranges and Cooktops) 1 01-26-2011 02:39 PM
Kitchenaid Gas Range Door Handle loose y1jmg Oven Repair (including Ranges and Cooktops) 1 01-26-2010 11:15 AM
Loose Oven Handle Door Lady E Oven Repair (including Ranges and Cooktops) 0 07-28-2008 12:25 PM
loose oven door handle duck Oven Repair (including Ranges and Cooktops) 1 07-31-2007 07:04 PM
