Discuss
Bake element blew up like a flare
 in
I set my oven to preheat at 400 and a few minutes later I saw a very bright light coming
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bake element blew up like a flare
  #1 (permalink)
Old 04-07-2013, 08:18 AM
Junior Member
eurobred is on a distinguished road
Question Bake element blew up like a flare
Model Number: FEFL79DSD ES340 Electric Range   Brand: Frigidaire   Age: 1 - 5 years
I set my oven to preheat at 400 and a few minutes later I saw a very bright light coming from the oven and looked to see a flare like bright fire coming from the bake element near the back of the oven. By the time I could react it was already out and all the displays on the stove top were out and not functioning. The stove top elements still work but the clock and all oven buttons do nothing. Needless to say the oven no longer works. Looks like the element split open and sprayed out some type of chemical. The main fuse from my circuit box did not trip.
Are there internal fuses that need to be replaced along with a new bake element? I hope that is all I need to do.
Thanks for any help help you can give.
Related Models
Frigidaire FEFL79DSF Frigidaire/range
Frigidaire FEFL79DSG Frigidaire/range
Frigidaire FEFL79DSH Frigidaire/electric Range
Frigidaire FEFL79DSJ Frigidaire/range
Frigidaire FEFL79DSK Frigidaire/range
Frigidaire FEFL79DSL Frigidaire/range
Frigidaire FEFL79ECA Frigidaire/electric Range
Frigidaire FEFL79ECB Frigidaire/electric Range
Frigidaire FEFL79ECC Frigidaire/range
Frigidaire FEFL79ECD Frigidaire/electric Range
Frigidaire FEFL79ECE Frigidaire/range
Frigidaire FEFL79FCA Frigidaire/electric Range
Frigidaire FEFL79FCB Frigidaire/range
Frigidaire FEFL79FCC Frigidaire/range
Frigidaire FEFL79GBA Frigidaire/range
Frigidaire FEFL79GCA Frigidaire/range
Frigidaire FEFL79GQA Frigidaire/range
Frigidaire FEFL79GSA Frigidaire/range
Frigidaire FEFL79HBA ELECTRIC RANGE
Frigidaire FEFL79HBB ELECTRIC RANGE
Frigidaire FEFL79HCA ELECTRIC RANGE
Frigidaire FEFL79HCB ELECTRIC RANGE
Frigidaire FEFL79HQA ELECTRIC RANGE
Frigidaire FEFL79HQB ELECTRIC RANGE
Frigidaire FEFL79HSA ELECTRIC RANGE
Frigidaire FEFL79HSB ELECTRIC RANGE
Frigidaire FEFL79JBA ELECTRIC RANGE
Frigidaire FEFL79JBB ELECTRIC RANGE
Frigidaire FEFL79JCA ELECTRIC RANGE
Frigidaire FEFL79JCB ELECTRIC RANGE
Frigidaire FEFL79JCC ELECTRIC RANGE
Frigidaire FEFL79JCE ELECTRIC RANGE
Frigidaire FEFL79JQA ELECTRIC RANGE
Frigidaire FEFL79JQB ELECTRIC RANGE
Frigidaire FEFL79JSA ELECTRIC RANGE
Frigidaire FEFL79JSB ELECTRIC RANGE
Frigidaire FEFL88ABA Frigidaire/electric Range
Frigidaire FEFL88ABB Frigidaire/electric Range
Frigidaire FEFL88ABC Frigidaire/electric Range
Frigidaire FEFL88ACA Frigidaire/electric Range
Frigidaire FEFL88ACB Frigidaire/electric Range
Frigidaire FEFL88ACC Frigidaire/electric Range
Frigidaire FEFL88ASA Frigidaire/electric Range
Frigidaire FEFL88ASB Frigidaire/electric Range
Frigidaire FEFL88ASC Frigidaire/electric Range
Frigidaire FEFL89CCA Frigidaire/electric Range
Frigidaire FEFL89CCB Frigidaire/electric Range
Frigidaire FEFLM600DQA Frigidaire/electric Range
Frigidaire FEFLM600DSA Frigidaire/electric Range
Frigidaire FEFLM605DBB Frigidaire/electric Range
Frigidaire FEFLM605DBD Frigidaire/electric Range
Frigidaire FEFLM605DCB Frigidaire/electric Range
Frigidaire FEFLM605DCC Frigidaire/electric Range
Frigidaire FEFLM605DCD Frigidaire/range
Frigidaire FEFLM605DCE Frigidaire/electric Range
Frigidaire FEFLM605DCG Frigidaire/range
Frigidaire FEFLM605DCH Frigidaire/range
Frigidaire FEFLM605DCJ Frigidaire/range
Frigidaire FEFLM605DQB Frigidaire/electric Range
Frigidaire FEFLM605DQD Frigidaire/electric Range
Frigidaire FEFLM605DSB Frigidaire/electric Range
Frigidaire FEFLM605DSD Frigidaire/electric Range
Frigidaire FEFLM66EBA Frigidaire/electric Range
Frigidaire FEFLM66EBB Frigidaire/electric Range
Frigidaire FEFLM66ESA Frigidaire/electric Range
Frigidaire FEFLM66ESB Frigidaire/electric Range
Frigidaire FEFLM66ESC Frigidaire/range
Frigidaire FEFLMC55FCA Frigidaire/electric Range
Frigidaire FEFLMC55FCB Frigidaire/range
Frigidaire FEFLMC55FCC ELECTRIC RANGE
Frigidaire FEFLMC55GCA ELECTRIC RANGE
Frigidaire FEFLMC55GCC ELECTRIC RANGE
Frigidaire FEFLMC55HCA ELECTRIC RANGE
Frigidaire FEFLMC55HCC ELECTRIC RANGE
Frigidaire FEFLMC55HCE ELECTRIC RANGE
Frigidaire FEFLZ87GCA ELECTRIC RANGE
Frigidaire FEFLZ87GCB ELECTRIC RANGE
Frigidaire FEFLZ87GCC ELECTRIC RANGE
Frigidaire FEFLZ87GCD ELECTRIC RANGE
Frigidaire FEFS52DQA Frigidaire/electric Range
Frigidaire FEFS52DQB Frigidaire/range
Frigidaire FEFS52DQC Frigidaire/range
Frigidaire FEFS52DQD Frigidaire/range
Frigidaire FEFS52DSA Frigidaire/electric Range
Frigidaire FEFS52DSB Frigidaire/range
Frigidaire FEFS52DSC Frigidaire/range
Frigidaire FEFS52DSD Frigidaire/range
Frigidaire FEFS66DQA Frigidaire/electric Range
Frigidaire FEFS66DQB Frigidaire/range
Frigidaire FEFS66DQC Frigidaire/range
Frigidaire FEFS66DQD Frigidaire/range
Frigidaire FEFS66DQF Frigidaire/range
Frigidaire FEFS66DQG Frigidaire/range
Frigidaire FEFS66DQH Frigidaire/range
Frigidaire FEFS66DQJ Frigidaire/range
Frigidaire FEFS66DSA Frigidaire/electric Range
Frigidaire FEFS66DSB Frigidaire/range
Frigidaire FEFS66DSC Frigidaire/range
Frigidaire FEFS66DSD Frigidaire/range
Frigidaire FEFS66DSF Frigidaire/range
Frigidaire FEFS66DSG Frigidaire/range
Frigidaire FEFS66DSH Frigidaire/range
Frigidaire FEFS66DSJ Frigidaire/range
Frigidaire FEFS68CJBA Frigidaire/electric Range
Frigidaire FEFS68CJBB Frigidaire/electric Range
Frigidaire FEFS68CJBC Frigidaire/electric Range
Frigidaire FEFS68CJSA Frigidaire/electric Range
Frigidaire FEFS68CJSB Frigidaire/electric Range
Frigidaire FEFS68CJSC Frigidaire/electric Range
Frigidaire FEFS68CJTA Frigidaire/electric Range
Frigidaire FEFS68CJTB Frigidaire/electric Range
Frigidaire FEFS68CJTC Frigidaire/electric Range
Frigidaire FEGB24S5ASE GAS OVEN
Roper FEP210EN0 ELECTRIC RANGE
Roper FEP210EN1 ELECTRIC RANGE
Roper FEP210EN2 ELECTRIC RANGE
Roper FEP210EN3 ELECTRIC RANGE
Roper FEP210EN4 ELECTRIC RANGE
Roper FEP210EN5 ELECTRIC RANGE
Roper FEP210EN6 ELECTRIC RANGE
  #2 (permalink)
Old 04-08-2013, 04:46 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire FEFL79DSD Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../316417753.pdf
Do the hot surface and element on indicator lamps for the stove top elements work?
If yes then the odds are that when the oven element blew it also blew the control board.
If no then slowly shut the breaker off/on , sometimes you can loose half the line without tripping the breaker.
Be sure that either the bad element has been replaced or disconnected. If disconnected make sure that the element wires/connectors cannot short to each other or the frame.
__________________
  #3 (permalink)
Old 04-08-2013, 06:55 AM
Junior Member
Default
The stove top element indicators light up and the hot surface indicator also lights up.
Rechecked my model number and it is...
CGLEF379GCA
Frigidair ES340
Can I replace the control board?
many many thanks for your help so far.
  #4 (permalink)
Old 04-08-2013, 07:44 AM
Senior Expert
APP Volunteer
Default
Here are the parts for the new model number
Parts for Frigidaire CGLEF379GCA Range - AppliancePartsPros.com
Just click on the parts picture for more info about it.
You should be able to replace it.
Look like you just remove the back cover to get at it.
Looks like it is item 20 in the Blackguard Parts section.
You may also need a new overlay.
It is self stick, sometimes they come off OK by heating them with a hair dryer but often they get ruined.
Be sure to unplug the stove when working on it.
Also mark or make yourself a diagram or take a picture so you know where the wires go on the board.
__________________
  #5 (permalink)
Old 04-08-2013, 05:20 PM
Junior Member
Default
Thanks for the response. I have ordered the 2 parts and see if that fixes the stove. Noticed some burn on the control board so I suspect you are right on the money with your diagnosis.
I will let you know once I replace the parts.
I have had this Frigidaire stove 4 years and 1 element had to be replaced and now the stove. My frigidaire fridge lasted 3 years before the compressor blew. Not a brand I will buy again.
thanks again for the great feedback.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blew new heating element in seconds! :( climbingdan Dryer Repair 1 01-13-2012 08:32 PM
bake element blew now nothing works GeorgiaM Oven Repair (including Ranges and Cooktops) 3 12-25-2009 04:18 AM
Baking element blew out, replaced, still not working Redeye Oven Repair (including Ranges and Cooktops) 1 12-01-2009 06:18 PM
element blew; now cooktop doesn't work LoriJ1296 Oven Repair (including Ranges and Cooktops) 1 09-14-2009 06:40 AM
Element Blew-up! SAVAGE Oven Repair (including Ranges and Cooktops) 1 10-08-2008 01:06 PM
