Discuss
Lower door sensor is not working
 in
Hello, As the Title suggests the lower Oven on my superba is reporting door open, but the door is closed
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Lower door sensor is not working
  #1 (permalink)
Old 04-06-2013, 11:29 PM
Junior Member
toddflora is on a distinguished road
Red face Lower door sensor is not working
Model Number: KEBC208KSS02   Brand: Kitchen Aid   Age: 5 - 10 years
Hello,
As the Title suggests the lower Oven on my superba is reporting door open, but the door is closed securely, so I think somehow the sensor is all of a sudden not working.
Let me give you the whole story.
Self Clean killed the upper oven a few days ago. After following advice on this excellent web site I was able to determine that both the fuse behind the control panel, and the fuse on the upper oven were blown.
The Oven was completely dead, so I started with the fuse behind the control panel. I ordered this from your website and replaced it and the oven powered up again. At this point the lower oven worked fine without any issues including no faulty Close Door message.
But the upper oven was not heating, so again I took your advice, and ordered the fuse for the back of the oven, and once again your advice was spot on, This fuse got the upper oven to work perfectly, Thanks.
But now after putting the back on the oven and sliding it back into the hole, I noticed that the oven lights were on, after some investigation we tried to turn on the lower oven, and the Close Door message came up on the control panel. The door was closed properly though, so I opened the lower door, and pressed the door close switch in, and the door does not registered as closed with the control panel.
So now I am wondering what I have done to cause this. Are there some things I can do to troubleshoot this issue.
Thanks in advance for your help.
Todd Flora
Related Models
Whirlpool KEBC208KSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KWH0 OVEN
Whirlpool KEBC208KWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC247KBL0 OVEN
Whirlpool KEBC247KBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH0 OVEN
Whirlpool KEBC247KWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247VBL00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC247VSS00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VSS02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC276KBL0 OVEN
Whirlpool KEBC276KBL02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KBL1 DOUBLE OVEN
Whirlpool KEBC276KSS03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH0 OVEN
Whirlpool KEBC276KWH02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH1 DOUBLE OVEN
Whirlpool KEBC277KBL0 OVEN
Whirlpool KEBC277KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBL1 DOUBLE OVEN
Whirlpool KEBC277KBT0 OVEN
Whirlpool KEBC277KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBT1 DOUBLE OVEN
Whirlpool KEBC277KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH0 OVEN
Whirlpool KEBC277KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH1 DOUBLE OVEN
Whirlpool KEBC278HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBL1 OVEN
Whirlpool KEBC278HBL2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBL3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBT1 OVEN
Whirlpool KEBC278HBT2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HWH1 OVEN
Whirlpool KEBC278HWH2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278KBL0 OVEN
Whirlpool KEBC278KBL02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBL1 DOUBLE OVEN
Whirlpool KEBC278KBS0 OVEN
Whirlpool KEBC278KBS1 DOUBLE OVEN
Whirlpool KEBC278KBT0 OVEN
Whirlpool KEBC278KBT02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBT1 DOUBLE OVEN
Whirlpool KEBC278KSS0 OVEN
Whirlpool KEBC278KSS02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KSS1 DOUBLE OVEN
Whirlpool KEBC278KWH0 OVEN
Whirlpool KEBC278KWH02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KWH1 DOUBLE OVEN
Whirlpool KEBI100BBL0 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100BBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH0 30" ELECTRIC OVEN
Whirlpool KEBI100BWH1 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100TBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL0 ELECTRIC BUILT-IN OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Auto sensor not working Magredvette Dryer Repair 0 08-29-2011 08:11 AM
freexer not working, lower fridg is working dinann Refrigerator & Freezer Repair 1 12-21-2010 05:18 AM
Ice maker sensor not working ncaruso Refrigerator & Freezer Repair 1 03-26-2010 11:00 AM
Need to replace sensor in lower oven fleabagh Oven Repair (including Ranges and Cooktops) 0 03-03-2009 12:33 PM
Refrigerator door closer, lower cam and cam-door aroffe Refrigerator & Freezer Repair 0 08-28-2008 09:54 AM
