Discuss
Another cooling fan question
 in
The cooling fan on my Jenn-Air JGS8850 comes on when the oven temp reaches 350 or more. The fan does
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Another cooling fan question
  #1 (permalink)
Old 04-06-2013, 05:31 PM
Junior Member
mcii4 is on a distinguished road
Default Another cooling fan question
Model Number: JGS8850   Brand: Jenn-Air   Age: More than 10 years
The cooling fan on my Jenn-Air JGS8850 comes on when the oven temp reaches 350 or more. The fan does not turn off until I turn the oven off, nor does it go off if I reset the temperature lower (to 275 for example). I am not getting an error codes and otherwise the oven works fine (It heats up appropriately). I have read several similar posts and based on those it would appear that I either need to change the temperature sensor or the front control panel assembly. Is there a specific test that I can run to isolate which is the problem? Thanks in advance!
Related Models
Jenn-Air JGS8850ADB RANGE- S/C S/I GAS
Jenn-Air JGS8850ADQ RANGE- S/C S/I GAS
Jenn-Air JGS8850ADS RANGE- S/C S/I GAS
Jenn-Air JGS8850ADW RANGE- S/C S/I GAS
Jenn-Air JGS8850BDB RANGE- S/C S/I GAS
Jenn-Air JGS8850BDQ RANGE- S/C S/I GAS
Jenn-Air JGS8850BDS RANGE- S/C S/I GAS
Maytag JGS8850BDS17 30" GAS SLIDE-IN
Jenn-Air JGS8850BDW RANGE- S/C S/I GAS
Maytag JGS8850CDB00 30" GAS SLIDE-IN
Maytag JGS8850CDS00 30" GAS SLIDE-IN
Jenn-Air JGS8850CDS01 30" GAS SLIDE-IN
Jenn-Air JGS8850CDS02 30" GAS SLIDE-IN RANGE
Maytag JGS8850CDW00 30" GAS SLIDE-IN
Jenn-Air JGS8860BDP RANGE- S/C S/I GAS
Maytag JGS8860BDP17 30" GAS SLIDE-IN
General Electric JGS905BEK1BB Gas range
General Electric JGS905BEK2BB Gas range
General Electric JGS905BEK3BB Gas range
General Electric JGS905KEK1CC Gas range
General Electric JGS905KEK2CC Gas range
General Electric JGS905KEK3CC Gas range
General Electric JGS905SEK1SS Gas range
General Electric JGS905SEK2SS Gas range
General Electric JGS905SEK3SS Gas range
General Electric JGS905TEK1WW Gas range
General Electric JGS905TEK2WW Gas range
General Electric JGS905TEK3WW Gas range
General Electric JGS968BEK1BB Gas range
General Electric JGS968BEK2BB Gas range
General Electric JGS968BEK3BB Gas range
General Electric JGS968BEK4BB GAS RANGE
General Electric JGS968BH1BB Gas range
General Electric JGS968BH2BB Gas range
General Electric JGS968BH3BB Gas range
General Electric JGS968BH4BB Gas range
General Electric JGS968BH5BB Gas range
General Electric JGS968BH6BB Gas range
General Electric JGS968KEK1CC Gas range
General Electric JGS968KEK2CC Gas range
General Electric JGS968KEK3CC Gas range
General Electric JGS968KEK4CC GAS RANGE
General Electric JGS968KH1CC Gas range
General Electric JGS968KH2CC Gas range
General Electric JGS968KH3CC Gas range
General Electric JGS968KH4CC Gas range
General Electric JGS968KH5CC Gas range
General Electric JGS968KH6CC Gas range
General Electric JGS968SEK1SS Gas range
General Electric JGS968SEK2SS Gas range
General Electric JGS968SEK3SS Gas range
General Electric JGS968SEK4SS GAS RANGE
General Electric JGS968SH1SS Gas range
General Electric JGS968SH2SS Gas range
General Electric JGS968SH3SS Gas range
General Electric JGS968SH4SS Gas range
General Electric JGS968SH5SS Gas range
General Electric JGS968SH6SS Gas range
General Electric JGS968TEK1WW Gas range
General Electric JGS968TEK2WW Gas range
General Electric JGS968TEK3WW Gas range
General Electric JGS968TEK4WW GAS RANGE
General Electric JGS968TH1WW Gas range
General Electric JGS968TH2WW Gas range
General Electric JGS968TH3WW Gas range
General Electric JGS968TH4WW Gas range
General Electric JGS968TH5WW Gas range
General Electric JGS968TH6WW Gas range
Jenn-Air JGS9900BDB RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDB15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Jenn-Air JGS9900BDF RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDF15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Jenn-Air JGS9900BDS RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDS15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900BDS16 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDB00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDF00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDR00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS01 30" SLIDE IN GAS ON GLASS DOWNDRAFT RANGE
Jenn-Air JGS9900CDS02 30" SLIDE-IN GAS ON GLASS DOWNDRAFT RANGE
General Electric JGSC07GEJ1 Electric range
General Electric JGSC07GEJ2 Gas range
General Electric JGSC08GEK1 Electric range
General Electric JGSC08GEK3 Electric range
General Electric JGSC12GEP1 Gas range
General Electric JGSC12GER1BG Gas range
General Electric JGSC12GET1BG Gas range
General Electric JGSC12GEV1BG Gas range
General Electric JGSP10GEK1 Electric range
General Electric JGSP10GEK2 Gas range
General Electric JGSP10GEK3 Electric range
General Electric JGSP20GEP1 Electric range
General Electric JGSP20GEP2 Gas range
General Electric JGSP20GER1BG Gas range
General Electric JGSP20GER2BG Gas range
General Electric JGSP20GER3BG Gas range
General Electric JGSP20GET1BB Gas range
General Electric JGSP21GEP1 Gas range
General Electric JGSP21GEP2 Gas range
General Electric JGSP21GER1WH Gas range
General Electric JGSP21GER2WH Gas range
General Electric JGSP21GER3WH Gas range
General Electric JGSP21WET1WW Gas range
General Electric JGSP22GEV1BB Gas range
General Electric JGSP22GEV3BB Gas range
General Electric JGSP23BEW1BB Gas range
General Electric JGSP23BEY1BB Gas range
General Electric JGSP23BEY2BB Gas range
General Electric JGSP23BEY3BB Gas range
General Electric JGSP23BEY4BB Gas range
General Electric JGSP23BEY5BB Gas range
General Electric JGSP23CEY1CC Gas range
General Electric JGSP23WEV1WW Gas range
General Electric JGSP23WEV2WW Gas range
General Electric JGSP23WEV5WW Gas range
General Electric JGSP23WEV6WW Gas range
General Electric JGSP23WEW1WW Gas range
General Electric JGSP23WEY1WW Gas range
General Electric JGSP23WEY2WW Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling angiebritt Refrigerator & Freezer Repair 4 05-16-2016 05:31 AM
frig stops cooling adjust thermastat and it starts cooling again Henry123 Refrigerator & Freezer Repair 1 01-18-2012 08:12 AM
Frigidaire FRS26R4AW6 stops cooling, starts cooling after unplugged. ckdorsey Refrigerator & Freezer Repair 1 11-01-2011 04:30 AM
noob with Whirlpool freezer not cooling question potatoman Refrigerator & Freezer Repair 1 04-27-2011 04:11 AM
Frigidaire Cooling Fan Question Bee46 Refrigerator & Freezer Repair 13 06-22-2008 01:31 PM
