Discuss
Upper oven is leaking hot air
 in
Hello, Some History for this question. During the cleaning cycle yesterday for the upper oven, the oven completely quit with
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Upper oven is leaking hot air
  #1 (permalink)
Old 04-03-2013, 09:11 AM
Junior Member
toddflora is on a distinguished road
Default Upper oven is leaking hot air
Model Number: KEBC208KSS02   Brand: Kitchen Aid   Age: 5 - 10 years
Hello,
During the cleaning cycle yesterday for the upper oven, the oven completely quit with no lights or anything on the control panel. After some research on this excellent forum and help from Gene, I determined that the Control Panel Fuse likely blew and so I have ordered another one.
In trying to figure out why this happened though and have noticed recently that there seems to be hot air escaping from the oven. This hot air is causing the control panel to steam up during oven use. This happening right by the air intake to the left of center. The air intake or snorkel as some have called it is what allows cool air from the room to be circulated into the cabinet so that the unit does not overheat.
So the question is, how to I resolve the issue of the hot air coming up out of the oven, Do I need to replace the Gasket, is there a way to verify that this is actually leaking?
Upon visual inspection, there are no burn marks around the gasket, or rips etc. The gasket visually looks fine.
Thanks for any help.
Todd.
Related Models
Whirlpool KEBC208KSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KSS1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC208KWH0 OVEN
Whirlpool KEBC208KWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC208KWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECT
Whirlpool KEBC247KBL0 OVEN
Whirlpool KEBC247KBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KSS07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH0 OVEN
Whirlpool KEBC247KWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH04 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH06 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH07 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247KWH2 24" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC247VBL00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VBL02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VBL03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC247VSS00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VSS02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH00 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC247VWH02 24" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
KitchenAid KEBC247VWH03 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBC276KBL0 OVEN
Whirlpool KEBC276KBL02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KBL1 DOUBLE OVEN
Whirlpool KEBC276KSS03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH0 OVEN
Whirlpool KEBC276KWH02 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH03 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH04 27" BUILT-IN ELECTRIC SELF-CLEAN DOUBLE OVEN
Whirlpool KEBC276KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC276KWH1 DOUBLE OVEN
Whirlpool KEBC277KBL0 OVEN
Whirlpool KEBC277KBL02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBL05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBL1 DOUBLE OVEN
Whirlpool KEBC277KBT0 OVEN
Whirlpool KEBC277KBT02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KBT05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KBT1 DOUBLE OVEN
Whirlpool KEBC277KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KSS05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH0 OVEN
Whirlpool KEBC277KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION SELF-CLEAN
Whirlpool KEBC277KWH05 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC277KWH1 DOUBLE OVEN
Whirlpool KEBC278HBL0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBL1 OVEN
Whirlpool KEBC278HBL2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBL3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HBT1 OVEN
Whirlpool KEBC278HBT2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HBT3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH0 BUILT-IN ELECTRIC OVEN
Whirlpool KEBC278HWH1 OVEN
Whirlpool KEBC278HWH2 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278HWH3 ELECTRIC DOUBLE OVEN
Whirlpool KEBC278KBL0 OVEN
Whirlpool KEBC278KBL02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBL1 DOUBLE OVEN
Whirlpool KEBC278KBS0 OVEN
Whirlpool KEBC278KBS1 DOUBLE OVEN
Whirlpool KEBC278KBT0 OVEN
Whirlpool KEBC278KBT02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBT1 DOUBLE OVEN
Whirlpool KEBC278KSS0 OVEN
Whirlpool KEBC278KSS02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KSS1 DOUBLE OVEN
Whirlpool KEBC278KWH0 OVEN
Whirlpool KEBC278KWH02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KWH1 DOUBLE OVEN
Whirlpool KEBI100BBL0 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100BBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH0 30" ELECTRIC OVEN
Whirlpool KEBI100BWH1 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100TBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL0 ELECTRIC BUILT-IN OVEN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Double Oven Upper oven not working scri8e Oven Repair (including Ranges and Cooktops) 18 12-30-2012 04:50 PM
Whirlpool Double Oven Upper Oven Upper Element Not Working rprosad Oven Repair (including Ranges and Cooktops) 0 12-30-2012 01:19 PM
Frigidaire Double Wall Oven Upper No Broil Lower No Oven Jim Gaspar Oven Repair (including Ranges and Cooktops) 0 10-14-2012 12:50 PM
27" electric double oven self clean w/erc111 & upper convection oven sksmith Oven Repair (including Ranges and Cooktops) 0 12-22-2010 06:08 PM
kitchen aid wall oven shuts off periodically when cooking with the upper oven? eddevlin Oven Repair (including Ranges and Cooktops) 6 03-15-2009 01:55 PM
