Discuss
Jenn-Air Oven not reach set temperature
 in
Oven set for 400-500 degrees only gets to 300 as indicated by separate thermometer placed in oven. Bake element gets
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Oven not reach set temperature
  #1 (permalink)
Old 04-03-2013, 09:48 AM
Junior Member
dkopilec is on a distinguished road
Default Jenn-Air Oven not reach set temperature
Model Number: JDS9860AAP   Brand: Jenn-Air   Age: 5 - 10 years
Oven set for 400-500 degrees only gets to 300 as indicated by separate thermometer placed in oven. Bake element gets hot (red), digital display shows that temperature setting is reached very quickly, like 15 seconds, and then the bake element goes off, even though oven temperature is still 300. Checked the resistance of the temperature sensor - it is at 1100 at room temperature. Can it still be faulty at higher temperatures, even though it checks out at room temp? Is it worth changing out the temp sensor before anything else? Should I check voltage coming from the relay board first, or is the hot (red) color of the bake element enough to know that the voltage is okay? The two expensive parts on this are the electric control and the relay board, but don't know which one to go after if it's not the temp sensor. If it is the control, do I need to buy one with the overlay, or does the overlay come off the original board and reusable? Had F2 code a few times about a year ago, but that is not happening recently. (serial number begins with 20, gas cook top, electric oven)
Related Models
Jenn-Air JDS9860AAP RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9860AAW RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9860ACB RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9860ACP RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9860ACW RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9860BCP RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9860BDB RANGE-S/C S/I GAS & ELEC DUEL FUEL
Maytag JDS9860BDB21 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9860BDS RANGE-S/C S/I GAS & ELEC DUEL FUEL
Maytag JDS9860BDS22 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9860BDW RANGE-S/C S/I GAS & ELEC DUEL FUEL
Maytag JDS9860BDW21 30" MODULAR GAS DOWNDRAFT RANGE
Maytag JDS9860CDB00 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9860CDB01 30" MODULAR GAS DOWNDRAFT RANGE
Maytag JDS9860CDS00 30" MODULAR GAS DOWNDRAFT RANGE
Maytag JDS9860CDS01 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9860CDS02 30" MODULAR GAS DOWNDRAFT RANGE
Maytag JDS9860CDW00 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9860CDW01 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9861AAP RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air JDS9865BDP RANGE-S/C S/I GAS & ELEC DUEL FUEL
Maytag JDS9865BDP22 30" MODULAR GAS DOWNDRAFT RANGE
Jenn-Air JDS9865BDP23 30" MODULAR GAS DOWNDRAFT RANGE
Whirlpool JE-0
General Electric JE101901 Counter top microwave
General Electric JE101902 Counter top microwave
General Electric JE1019H01 Counter top microwave
General Electric JE1019H02 Counter top microwave
General Electric JE102001 Counter top microwave
General Electric JE102002 Counter top microwave
General Electric JE1020A01 Counter top microwave
General Electric JE1025E01 Counter top microwave
General Electric JE1025T01 Counter top microwave
General Electric JE1025T02 Counter top microwave
General Electric JE1025T03 Counter top microwave
General Electric JE1025T04 Counter top microwave
General Electric JE1027J01 Counter top microwave
General Electric JE103101 Counter top microwave
General Electric JE103102 Counter top microwave
General Electric JE1031H01 Counter top microwave
General Electric JE1031H02 Counter top microwave
General Electric JE1034T01 Counter top microwave
General Electric JE1040GB01 Counter top microwave
General Electric JE1040GY01 Counter top microwave
General Electric JE1040GY02 Counter top microwave
General Electric JE1040WB01 Counter top microwave
General Electric JE1040WY01 Counter top microwave
General Electric JE1040WY02 Counter top microwave
General Electric JE1050GA01 Counter top microwave
General Electric JE1050WA01 Counter top microwave
General Electric JE1060GB01 Counter top microwave
General Electric JE1060WB01 Counter top microwave
General Electric JE1140BC01 Counter top microwave
General Electric JE1140BD001 Counter top microwave
General Electric JE1140WC01 Counter top microwave
General Electric JE1140WD001 Counter top microwave
General Electric JE1160BC01 Counter top microwave
General Electric JE1160BD001 Counter top microwave
General Electric JE1160BD01 MICROWAVE
General Electric JE1160BD03 Counter top microwave
General Electric JE1160BD04 Counter top microwave
General Electric JE1160BD05 MICROWAVE
General Electric JE1160WC01 Counter top microwave
General Electric JE1160WD001 Counter top microwave
General Electric JE1160WD01 MICROWAVE
General Electric JE1160WD02 Counter top microwave
General Electric JE1160WD03 Counter top microwave
General Electric JE1160WD04 Counter top microwave
General Electric JE1160WD05 MICROWAVE
General Electric JE1219J01 Counter top microwave
General Electric JE1220J01 Counter top microwave
General Electric JE1220J02 Counter top microwave
General Electric JE1221K01 Counter top microwave
General Electric JE1223L01 Counter top microwave
General Electric JE1231J01 Counter top microwave
General Electric JE1232K01 Counter top microwave
General Electric JE1233L01 Counter top microwave
General Electric JE1234J01 Counter top microwave
General Electric JE1234J02 Counter top microwave
General Electric JE1234LWH01 Counter top microwave
General Electric JE1235T01 Counter top microwave
General Electric JE1235WW003 Counter top microwave
General Electric JE1235WW004 Counter top microwave
General Electric JE1235WW01 Counter top microwave
General Electric JE1235WW02 Counter top microwave
General Electric JE1236TWH01 Counter top microwave
General Electric JE1237T01 Counter top microwave
General Electric JE1238TWH01 Counter top microwave
General Electric JE1240GN01 Counter top microwave
General Electric JE1240GV01 Counter top microwave
General Electric JE1240GW01 Counter top microwave
General Electric JE1240GW02 Counter top microwave
General Electric JE1240L01 Counter top microwave
General Electric JE1240WN01 Counter top microwave
General Electric JE1240WV01 Counter top microwave
General Electric JE1240WW01 Counter top microwave
General Electric JE1240WW02 Counter top microwave
General Electric JE1250GN01 Counter top microwave
General Electric JE1250GV01 Counter top microwave
General Electric JE1250GW01 Counter top microwave
General Electric JE1250GW02 Counter top microwave
General Electric JE1250WY01 Counter top microwave
General Electric JE1340BC01 Counter top microwave
General Electric JE1340GA01 Counter top microwave
General Electric JE1340GB01 Counter top microwave
General Electric JE1340GY01 Counter top microwave
General Electric JE1340GY02 Counter top microwave
General Electric JE1340WA01 Counter top microwave
General Electric JE1340WB01 Counter top microwave
General Electric JE1340WC01 Counter top microwave
General Electric JE1340WY01 Counter top microwave
General Electric JE1340WY02 Counter top microwave
General Electric JE1350GA01 Counter top microwave
General Electric JE1350WA01 Counter top microwave
General Electric JE1360BC01 Counter top microwave
General Electric JE1360GA01 Counter top microwave
General Electric JE1360GB01 Counter top microwave
General Electric JE1360WA01 Counter top microwave
General Electric JE1360WB01 Counter top microwave
General Electric JE1360WC01 Counter top microwave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven does not reach proper temperature arvishyar Oven Repair (including Ranges and Cooktops) 2 06-06-2012 04:54 AM
Oven doesnt' reach temperature cmarkleski Oven Repair (including Ranges and Cooktops) 3 10-20-2010 12:17 PM
Oven won't reach temperature tcfroman Oven Repair (including Ranges and Cooktops) 0 10-10-2010 10:11 AM
Oven does not reach set temperature dcmjcook Oven Repair (including Ranges and Cooktops) 0 03-07-2010 06:23 AM
Oven won't reach temperature bbatt Oven Repair (including Ranges and Cooktops) 0 12-05-2008 01:20 PM
