Discuss
constant clicking from only 1 burner
 in
Good Day I have a GE Monogram Cooktop ZGU375NSD2SS I am been working on getting this cooktop back to 100%
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » constant clicking from only 1 burner
  #1 (permalink)
Old 04-02-2013, 11:22 AM
Junior Member
carlosrg is on a distinguished road
Default constant clicking from only 1 burner
Model Number: ZGU375NSD2SS   Brand: GE   Age: 5 - 10 years
I am been working on getting this cooktop back to 100% working condition.
I got a bunch of parts out of another unit to replace (used parts), here is what I have replaced so far
1. Transformer
2. Ignition Module
3. Ingitor switch (on Right Rear burner valve)
4. Wire harness from Ignition Module
5. Gas valve (I replaced LR,Middle Rear,Right Rear)
Let me explain the problem I have, If I turn on any burner other than Right Rear the gas will come on the ignitor will start sparking and light the burner and then stop sparking.
However if I turn the knob for the right rear the gas will flow to the burner, the ignitor will start arcing, the burner will light but the ignitor will continue to click the burner.
I am thinking maybe I have a bad ignitor assembly is bad or what ever tells the ignitor to stop sparking. I may try swapping the front and rear burner to see if it follows the problem. *UPDATE* I have swapped the RR and RF assemblies and RR continues to have same problem.
What I like to know is how to do I test the ignition module itself to make sure all the channel are working properly. I have a multimeter if there is a procedure for me try.
I also like to know how to test the ignitor switch, and the ignitor assembly. *UPDATED I have figured out how to test the ignitor switch a simple continunity test with shows if position is in it off state there is no continuity, any other position shows continuity. I tested another switch to figure that out the first one I had was bad.
Thank you
Related Models
General Electric ZGU375NSD2SS Gas range
General Electric ZGU375NSD3SS Gas range
General Electric ZGU384LSM1SS Gas range
General Electric ZGU384LSM2SS GAS COOKTOP
General Electric ZGU384NSM1SS Gas range
General Electric ZGU384NSM2SS GAS COOKTOP
General Electric ZGU385LSM1SS Gas range
General Electric ZGU385LSM2SS GAS COOKTOP
General Electric ZGU385NSM1SS Gas range
General Electric ZGU385NSM2SS GAS COOKTOP
General Electric ZGU484LGP1SS GAS COOKTOP
General Electric ZGU484LGP2SS GAS COOKTOP
General Electric ZGU484LGP3SS GAS COOKTOP
General Electric ZGU484LGP4SS GAS COOKTOP
General Electric ZGU484NGP1SS GAS COOKTOP
General Electric ZGU484NGP2SS GAS COOKTOP
General Electric ZGU484NGP3SS GAS COOKTOP
General Electric ZGU484NGP4SS GAS COOKTOP
General Electric ZGU484NGP5SS GAS COOKTOP
General Electric ZGU486LDP1SS GAS COOKTOP
General Electric ZGU486LDP2SS GAS COOKTOP
General Electric ZGU486LDP3SS GAS COOKTOP
General Electric ZGU486LDP4SS GAS COOKTOP
General Electric ZGU486LRP1SS GAS COOKTOP
General Electric ZGU486LRP2SS GAS COOKTOP
General Electric ZGU486LRP3SS GAS COOKTOP
General Electric ZGU486LRP4SS GAS RANGE
General Electric ZGU486NDP1SS GAS COOKTOP
General Electric ZGU486NDP2SS GAS COOKTOP
General Electric ZGU486NDP3SS GAS COOKTOP
General Electric ZGU486NDP4SS GAS COOKTOP
General Electric ZGU486NRP1SS GAS COOKTOP
General Electric ZGU486NRP2SS GAS COOKTOP
General Electric ZGU486NRP3SS GAS COOKTOP
General Electric ZGU486NRP4SS GAS COOKTOP
General Electric ZGU486NRP5SS GAS RANGE
General Electric ZGU48L4GD1SS Gas range
General Electric ZGU48L4GD2SS Gas range
General Electric ZGU48L4GH1SS Gas range
General Electric ZGU48L4GH2SS Gas range
General Electric ZGU48L4GH3SS Gas range
General Electric ZGU48L4GH4SS Gas range
General Electric ZGU48L4GH5SS COUNTER UNIT
General Electric ZGU48L4GWSS Gas range
General Electric ZGU48L6DD1SS Gas range
General Electric ZGU48L6DH1SS Gas range
General Electric ZGU48L6DH2SS Gas range
General Electric ZGU48L6DH3SS Gas range
General Electric ZGU48L6DH4SS Gas range
General Electric ZGU48L6DH5SS COUNTER UNIT
General Electric ZGU48L6DWSS Gas range
General Electric ZGU48L6RD1SS Gas range
General Electric ZGU48L6RD2SS Gas range
General Electric ZGU48L6RH1SS Gas range
General Electric ZGU48L6RH2SS Gas range
General Electric ZGU48L6RH3SS Gas range
General Electric ZGU48L6RH4SS Gas range
General Electric ZGU48L6RH5SS COUNTER UNIT
General Electric ZGU48L6RWSS Gas range
General Electric ZGU48N4GD1SS Gas range
General Electric ZGU48N4GD2SS Gas range
General Electric ZGU48N4GH1SS Gas range
General Electric ZGU48N4GH2SS Gas range
General Electric ZGU48N4GH3SS Gas range
General Electric ZGU48N4GH4SS Gas range
General Electric ZGU48N4GH5SS COUNTER UNIT
General Electric ZGU48N4GWSS Gas range
General Electric ZGU48N6DD1SS Gas range
General Electric ZGU48N6DH1SS Gas range
General Electric ZGU48N6DH2SS Gas range
General Electric ZGU48N6DH3SS Gas range
General Electric ZGU48N6DH4SS Gas range
General Electric ZGU48N6DH5SS COUNTER UNIT
General Electric ZGU48N6DWSS Gas range
General Electric ZGU48N6RD1SS Gas range
General Electric ZGU48N6RD2SS Gas range
General Electric ZGU48N6RH1SS Gas range
General Electric ZGU48N6RH2SS Gas range
General Electric ZGU48N6RH3SS Gas range
General Electric ZGU48N6RH4SS Gas range
General Electric ZGU48N6RH5SS COUNTER UNIT
General Electric ZGU48N6RWSS Gas range
General Electric ZGU650EM1BG Electric range
General Electric ZGU650ES1 Gas range
General Electric ZGU650ES2BG Gas range
General Electric ZGU650ES3BG Gas range
General Electric ZGU651EM1WG Electric range
General Electric ZGU651ES1 Gas range
General Electric ZGU651ES2WG Gas range
General Electric ZGU651ES3WG Gas range
General Electric ZGU660EM1BG Gas range
General Electric ZGU660ES1 Gas range
General Electric ZGU660ES2BG Gas range
General Electric ZGU660ES3BG Gas range
General Electric ZGU661EM1WG Electric range
General Electric ZGU661ES1 Gas range
General Electric ZGU661ES2WG Gas range
General Electric ZGU661ES3WG Gas range
General Electric ZGU665BEX1BG Gas range
General Electric ZGU665WEX1WG Gas range
General Electric ZGW124EN2SS Gas range
General Electric ZGW124EN3SS Gas range
General Electric ZGW124EN5SS GAS COOKTOP
General Electric ZGW124EYSS Gas range
General Electric ZGW124N Gas range
General Electric ZGW125EN2SS Gas range
General Electric ZGW125EN3SS Gas range
General Electric ZGW125EN5SS Gas range
General Electric ZGW125EYSS Gas range
General Electric ZGW125N Electric range
General Electric ZHE25NGTAFNB REFRIGERATOR T SERIES
General Electric ZHE25NGTJFNB REFRIGERATOR T SERIES
General Electric ZHE25NGWAFNB REFRIGERATOR W SERIES
General Electric ZHU30RBM1BB ELECTRIC COOKTOP
General Electric ZHU30RBM2BB ELECTRIC COOKTOP
General Electric ZHU30RSM1SS ELECTRIC COOKTOP
General Electric ZHU30RSM2SS ELECTRIC COOKTOP
General Electric ZHU30RSR1SS ELECTRIC COOKTOP
General Electric ZHU36RBM1BB ELECTRIC COOKTOP
General Electric ZHU36RBM2BB ELECTRIC COOKTOOP
  #2 (permalink)
Old 04-02-2013, 04:25 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
To check if it's bad ignitor or spark module switch around two ignitor cables at the module.The one in question with a good one.
P.S. Did you replace all ignitor switches?
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-03-2013, 06:17 AM
Junior Member
Default
I will try that next as switching the burner assemblies didn't seem to fix the problem.
Another piece of information the ignitor switch that went with RR burner was bad. I am also starting to wonder if the ignitor switch that I replaced it with is also bad. I would think the ignitor switch should only latch on at specific location which would be 90 degrees counter clockwise of the resting position. The one I replaced it with latches on at 90 degrees and almost all the way back to resting position. I would think that ignitor switch would only latch on at say 90 degree CCW only else there would have to be another mechanism to let the ignitor know to stop activating. Can anyone explain how ignitor knows to stop working?
Do these switches have a specific polarity?
My next step is to move the switch from a properly working burner, and then trying to use another channel on the ignition module, and checking the ground wire near that burner as well.
  #4 (permalink)
Old 04-03-2013, 04:53 PM
Expert
Default
Hi.
First of all there are two different type switches you have there. They differ in the mounting angle.So use the same type when switching them.
The spark ic controlled by the spark module. The spark module is sensing the flame and turn the ignitor off.If you blow the flame off the ignitor, the spark should start again.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
The constant clicking noise of the bad overload/relay 1sacto Refrigerator & Freezer Repair 1 07-05-2012 07:54 AM
GE Fridge constant clicking canaanp Refrigerator & Freezer Repair 0 10-22-2011 03:13 PM
GE PDF22MFSBB constant clicking noise gtxbrad Refrigerator & Freezer Repair 1 10-18-2011 11:01 AM
cONSTANT CLICKING NOISE scopat Refrigerator & Freezer Repair 0 01-06-2010 09:31 AM
Constant clicking johnny mac Oven Repair (including Ranges and Cooktops) 1 06-15-2009 08:29 AM
