Discuss
Maytag Electric Range - Lights on but no heat
 in
I have a 23 year old Maytag LCRE350 electric range. None of the burners work however the indicator light is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Electric Range - Lights on but no heat
  #1 (permalink)
Old 10-04-2009, 05:31 PM
Junior Member
bunangst is on a distinguished road
Default Maytag Electric Range - Lights on but no heat
Model Number: LCRE350   Brand: Maytag   Age: More than 10 years
I have a 23 year old Maytag LCRE350 electric range. None of the burners work however the indicator light is lit. The oven does not work and the indicator light does not work. I realize it is time for a new range since I can not find any information using the model number but is there a place I should start troubleshooting?
Thanks!
Related Models
Maytag LCRE350 RANGE- F/S STD ELE
Maytag LCRE400 RANGE- F/S STD ELE
Maytag LCRE600 RANGE- F/S STD ELE
Maytag LCRE650 RANGE- F/S STD ELE
Maytag LCRE655 RANGE- S/C F/S ELE
Maytag LCRE682 RANGE- S/C F/S ELE
Maytag LCRE683 RANGE- S/C F/S ELE
Maytag LCRE700 RANGE- S/C F/S ELE
Maytag LCRE750 RANGE- S/C F/S ELE
Maytag LCRE800 RANGE- S/C F/S ELE
Maytag LCRE805 RANGE- S/C F/S ELE
Maytag LCRE883 RANGE- S/C F/S ELE
Maytag LCRG200 RANGE- F/S STD GAS
Maytag LCRG300 RANGE- F/S STD GAS
Maytag LCRG305 RANGE- F/S STD GAS
Maytag LCRG350 RANGE- F/S STD GAS
Maytag LCRG355 RANGE- F/S STD GAS
Maytag LCRG382 RANGE- F/S STD GAS
Maytag LCRG383 RANGE- F/S STD GAS
Maytag LCRG400 RANGE- F/S STD GAS
Maytag LCRG405 RANGE-F/S CONT CLEAN GAS
Maytag LCRG500 RANGE- F/S STD GAS
Maytag LCRG501 RANGE- F/S STD GAS
Maytag LCRG502 RANGE- F/S STD GAS
Maytag LCRG505 RANGE- F/S STD GAS
Maytag LCRG560 RANGE- F/S STD GAS
Maytag LCRG583 RANGE-F/S CONT CLEAN GAS
Maytag LCRG600 RANGE- F/S STD GAS
Maytag LCRG601 RANGE- F/S STD GAS
Maytag LCRG602 RANGE-F/S CONT CLEAN GAS
Maytag LCRG700 RANGE- S/C F/S GAS
Maytag LCRG705 RANGE- S/C F/S GAS
Maytag LCRG750 RANGE- S/C F/S GAS
Maytag LCRG755 RANGE- S/C F/S GAS
Maytag LCRG760 RANGE- S/C F/S GAS
Maytag LCRG760A RANGE- S/C F/S GAS
Maytag LCRG783 RANGE- S/C F/S GAS
Maytag LCRG800 RANGE- S/C F/S GAS
Maytag LCRG805 RANGE- S/C F/S GAS
Maytag LCRG860 RANGE- S/C F/S GAS
Maytag LCRG860A RANGE- S/C F/S GAS
Maytag LCRP200 RANGE- F/S STD GAS
Maytag LCRP205 RANGE- F/S STD GAS
Maytag LCRP300 RANGE- F/S STD GAS
Maytag LCRP382 RANGE- F/S STD GAS
Maytag LCSE600 SURFACE UNIT- ELE
Maytag LCSE601 SURFACE UNIT- ELE
Maytag LCSG500 SURFACE UNIT- GAS
Maytag LCSG501 SURFACE UNIT- GAS
Maytag LCSG560 SURFACE UNIT- GAS
Maytag LCSG600 SURFACE UNIT- GAS
 LCU240CP Air Conditioner
 LCU340CP Air Conditioner
Amana LD10 COMMERCIAL MICROWAVES
Amana LD10D COMMERCIAL MICROWAVES
Amana LD10D2 COMMERCIAL MICROWAVES
Amana LD10MP COMMERCIAL MICROWAVES
Amana LD10MPS COMMERCIAL MICROWAVES
 LD25EL Dehumidifier
 LD40 Dehumidifier
 LD40E Dehumidifier
 LD50EBL Dehumidifier
 LD50EL Dehumidifier
 LD50ELY5 Dehumidifier
Amana LD510 COMMERCIAL MICROWAVES
Amana LD510D COMMERCIAL MICROWAVES
Amana LD510M COMMERCIAL MICROWAVES
Amana LD510P COMMERCIAL MICROWAVES
Amana LD510S COMMERCIAL MICROWAVES
 LD65EL Dehumidifier
 LD65ELY5 Dehumidifier
Gaggenau LD816-610
Gaggenau LD816-620
 LDC22720ST Refrigerator
 LDC22720SW Refrigerator
 LDC22720TT Refrigerator
Admiral LDE1000ACE DRYER- ELE
Admiral LDE1000AKE DRYER- ELE
Admiral LDE1000GGE DRYER- ELE
Maytag LDE110 DRYER- ELE
Maytag LDE18CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CA MANUAL, PARTS (DRYER ELE)
Maytag LDE19CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CS MANUAL, PARTS (DRYER ELE)
Maytag LDE19CT MANUAL, PARTS (DRYER ELE)
Maytag LDE210 DRYER- ELE
Maytag LDE212 DRYER- ELE
Maytag LDE21CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE22CS MANUAL, PARTS (DRYER ELE)
Maytag LDE22CT MANUAL, PARTS (DRYER ELE)
Maytag LDE23CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE25CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE26CA MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CS MANUAL, PARTS (DRYER ELE)
Maytag LDE26CT MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CA MANUAL, PARTS (DRYER ELE)
Maytag LDE27CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CS MANUAL, PARTS (DRYER ELE)
Maytag LDE27CT MANUAL, PARTS (DRYER ELE)
Maytag LDE303 DRYER- ELE
Maytag LDE312 DRYER- ELE
Maytag LDE313 DRYER- ELE
Frigidaire LDE333PBW0 Frg(v0) / Gas Dryer
Frigidaire LDE333PBW1 Frg(v0) / Electric Dryer
Frigidaire LDE333PEW0 Frg(v0) / Electric Dryer
Maytag LDE382 DRYER- ELE
Maytag LDE4000 DRYER- ELE
Maytag LDE4000ACL DRYER- ELE
Maytag LDE4000ACW DRYER- ELE
Maytag LDE4000ADL DRYER- ELE
Maytag LDE4000ADW DRYER- ELE
  #2 (permalink)
Old 10-05-2009, 04:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I would start by checking the power.
Indicator lights and oven lights often work on 120 volts while your elements need 240 volts.
Try turning the breaker off/on a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Better yet check it with a meter.
If OK, unplug the unit and check that a wire has not burned up somewhere, often this is at the terminal block in the unit.
__________________
  #3 (permalink)
Old 10-05-2009, 06:28 AM
Junior Member
Default
That did the trick! Thanks! Should I be concerned about the electricial box? I know my parents were having some issues with their oven as well as other issues like lights dimming and they needed to have their electrical service updated. We are having no other issues other than the oven.
Thanks again!
  #4 (permalink)
Old 10-05-2009, 06:32 AM
Senior Expert
APP Volunteer
Default
I would not be too concerned unless it starts happening on a regular basis.
Many others have had this problem so it is a fairly common occurance.
__________________
  #5 (permalink)
Old 10-05-2009, 06:42 AM
Junior Member
Default
Thanks again!
  #6 (permalink)
Old 10-05-2009, 06:49 AM
Senior Expert
APP Volunteer
Default
My pleasure, glad it worked out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Range - Stove Top won't heat DIY_landlord Oven Repair (including Ranges and Cooktops) 0 07-25-2009 04:30 PM
maytag electric range pelder Oven Repair (including Ranges and Cooktops) 2 01-26-2009 07:57 AM
Dim Lights in controls of Maytag double oven range cityfolks Oven Repair (including Ranges and Cooktops) 1 12-22-2008 02:48 PM
Removing Maytag Electric Range Cooktop Chryslerpetz Oven Repair (including Ranges and Cooktops) 3 01-03-2008 05:50 PM
Maytag Electric Range Control Panel Dim Chryslerpetz Oven Repair (including Ranges and Cooktops) 0 12-26-2007 05:52 PM
