Discuss
Roper Oven Cuts Out at High Temperature
 in
Hi, I have a Roper RGE3330 Range that ever time I try to set the oven temperature above about 450
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Roper Oven Cuts Out at High Temperature
  #1 (permalink)
Old 10-04-2009, 02:45 PM
Junior Member
CavalierJW is on a distinguished road
Default Roper Oven Cuts Out at High Temperature
Model Number: RGE3330   Brand: Roper   Age: 5 - 10 years
I have a Roper RGE3330 Range that ever time I try to set the oven temperature above about 450 degree it gets to about 425 and cuts outs (with a popping noise) and the oven indicator turns off. It will then cool down to about 325 degrees and start heating again. If I keep the temperature setting below 425 degrees it maintains the temperature. I have a thermometer in the oven it the thermostat maintains the temperature within +/-10 degrees. I suspect it may be a faulty thermodisc since it work fine at lower temperatures (this model does have one located under the left side panel). Any help would be appreciated.
Jeremy
Related Models
Roper RGE33301 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Roper RGE34301 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Whirlpool RGE4900W1 Ranges, Electric*
Whirlpool RGE8300H Ranges, Electric*
Whirlpool RGE8800H Ranges, Electric*
General Electric RGH558U01 Gas range
General Electric RGH646G1F0 Gas range
General Electric RGH647GEH1 Gas range
General Electric RGH647GEH2 Gas range
General Electric RGH647GEH3 Gas range
General Electric RGH647GEJ1 Gas range
General Electric RGH647GEJ2 Gas range
General Electric RGH647GEJ3 Gas range
General Electric RGH647GEJ4 Gas range
Whirlpool RGH83301 Range Hood
Whirlpool RGH83361 Range Hood
Whirlpool RGH83481 Range Hood
General Electric RGH846GEH1 Gas range
General Electric RGH846GEH2 Gas range
General Electric RGH846GEH3 Gas range
General Electric RGH846GEJ1 Hi-low range
General Electric RGH846GEJ2 Gas range
General Electric RGH846GEJ3 Gas range
General Electric RGH846GEJ4 Gas range
General Electric RGH846GEJ5 Gas range
General Electric RGH946GEH1 Gas range
General Electric RGH946GEH2 Gas range
General Electric RGH946GEH3 Gas range
General Electric RGH946GEJ1 Hi-low range
General Electric RGH946GEJ2 Gas range
General Electric RGH946GEJ3 Gas range
General Electric RGH946GEJ4 Gas range
General Electric RGH946GEJ5 Gas range
General Electric RGH946GEJ6 Gas range
General Electric RGH946GEJ7 Gas range
General Electric RGH946GEJ8 Gas range
General Electric RGJ515GEH1 Gas range
General Electric RGJ515GEH2 Gas range
General Electric RGJ515GEH3 Gas range
General Electric RGJ515GEL1 Gas range
General Electric RGJ515GEL2 Gas range
General Electric RGJ515GEL3 Gas range
General Electric RGJ515GEL4 Gas range
General Electric RGJ534GEP1 Gas range
General Electric RGJ534GEP2BG Gas range
General Electric RGJ616GEH1 Gas range
General Electric RGJ616GEH2 Gas range
General Electric RGJ616GEH3 Gas range
General Electric RGJ616GEL1 Gas range
General Electric RGJ616GEL2 Gas range
General Electric RGJ616GEL3 Gas range
General Electric RGJ616GEL4 Gas range
General Electric RGJ736GEP1 Gas range
Roper RGK2951KQ0 COMMERCIAL DRYER
Roper RGK2951KQ1 COMMERCIAL DRYER
Roper RGK2951KQ2 For Model: RGK2951KQ2 (White)
Whirlpool RGL3422AL0
Roper RGL3422AW0 Residential Dryer
Roper RGL3612BW0 GAS DRYER
Roper RGL3612BW1 GAS DRYER
Roper RGL3612BW2 GAS DRYER
Roper RGL3612BW3 GAS DRYER
Roper RGL3636AW0 Residential Dryer
Roper RGL4422AW0 Residential Dryer
Roper RGL4432AW0 Residential Dryer
Roper RGL4434AW0 Residential Dryer
Roper RGL4622BL0 GAS DRYER
Roper RGL4622BL1 GAS DRYER
Roper RGL4622BL2 GAS DRYER
Roper RGL4622BW0 GAS DRYER
Roper RGL4622BW1 GAS DRYER
Roper RGL4622BW2 GAS DRYER
Roper RGL4622DL0 GAS DRYER
Roper RGL4622DL1 GAS DRYER
Roper RGL4622DW0 GAS DRYER
Roper RGL4622DW1 GAS DRYER
Roper RGL4632BL0 DRYER
Roper RGL4632BL1 GAS DRYER
Roper RGL4632BL2 GAS DRYER
Roper RGL4632BL3 GAS DRYER
Roper RGL4632BQ0 DRYER
Roper RGL4632BQ1 GAS DRYER
Roper RGL4632BQ2 GAS DRYER
Roper RGL4632BQ3 GAS DRYER
Roper RGL4632BW0 DRYER
Roper RGL4632BW1 GAS DRYER
Roper RGL4632BW2 GAS DRYER
Roper RGL4632BW3 GAS DRYER
Roper RGL4632DL0 GAS DRYER
Roper RGL4632DL1 GAS DRYER
Roper RGL4632DW0 GAS DRYER
Roper RGL4632DW1 GAS DRYER
Roper RGL4634BL0 GAS DRYER
Roper RGL4634BL1 GAS DRYER
Roper RGL4634BL2 GAS DRYER
Roper RGL4634BL3 GAS DRYER
Roper RGL4634BW0 GAS DRYER
Roper RGL4634BW1 GAS DRYER
Roper RGL4634BW2 GAS DRYER
Roper RGL4634BW3 GAS DRYER
Roper RGL4636BL0 GAS DRYER
Roper RGL4636BL1 GAS DRYER
Roper RGL4636BL2 GAS DRYER
Roper RGL4636BL3 GAS DRYER
Roper RGL4636BW0 GAS DRYER
Roper RGL4636BW1 GAS DRYER
Roper RGL4636BW2 GAS DRYER
Roper RGL4636BW3 GAS DRYER
Roper RGL5646AW0 Residential Dryer
Frigidaire RGS35CH0 Frg(v4) / Electric Range
Frigidaire RGS35CH2 Frg(v3) / Electric Range
Frigidaire RGS35CL1 Frg(v7) / Free Standing Electric Range
Frigidaire RGS35CL2 Frg(v2) / Electric Range
Frigidaire RGS35CW0 Frg(v5) / Electric Range
Frigidaire RGS35CW1 Frg(v8) / Free Standing Electric Range
Frigidaire RGS35CW2 Frg(v1) / Electric Range
Frigidaire RGS36BNL1 Frg(v2) / Electric Range
Frigidaire RGS36BNW1 Frg(v1) / Electric Range
General Electric RGS525GEJ1 Gas range
General Electric RGS525GEJ2 Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
High Freezer Temperature WaltL Refrigerator & Freezer Repair 0 01-24-2010 02:09 PM
oven temperature too high clyde_evelyn Oven Repair (including Ranges and Cooktops) 1 09-19-2009 04:01 AM
Dacor High Temperature Override Reset tsedona Oven Repair (including Ranges and Cooktops) 1 05-28-2009 01:38 PM
maytag oven slow baking plus runaway high temperature russell harris Oven Repair (including Ranges and Cooktops) 2 02-13-2009 10:15 AM
High Temperature in Upright Freezer timb Refrigerator & Freezer Repair 0 09-04-2007 10:06 AM
