Hi there, I have a GE Monogram 30" single wall oven ZET1R that isn't working. Touch pad lights up but doesn't respond. The repair guy told me it need a touch pad replacement and the control panel also needed to be replaced since it came with the touch pad part. Control Frame Asm by GE Part Number AP4355917 MFG Part Number WB27T11000. I was later told that part AP4980380/WB27T11264 was the right part. Any idea which is this the part that would be needed to replace the touch pad and control panel? It seems to have a lot of components, so is the whole package necessary? If I bought the whole assembly can I install it myself or do I need specialized tools (I'm pretty good at fixing things). Any advice would be appreciated as my wife is going to kill me if I don't get this fixed up soon! Thanks Steve
