The broiler unit operates at both high and low setting. However, the flame at both settings is at the "low" level. At the suggestion of some, I replaced the ignitor. Didn't think it would solve the problem, and it didn't. The broiler still operates at a low flame at both settings. Burner does not appear to be clogged. Flame is even along both sides. Could the orifice be clogged? Would a faulty electronic control be the problem? Everything else continues to work fine on the unit. Thanks for help.
