I Have One Burner That Does Not Come On At All. It The Front Left Burner. I Was Wondering If It Is The Infinite Control Switch That Is Bad. Or Is It Something Else?
Hello, Turn the switch On and check for continuity between the terminals: P1 & 2, P2 & 4 and S1 & S2. If any of the pair reads no continuity, replace the infinite switch. Otherwise check the wires between the infinite switch and the heating element and replace the heating element. - The infinite switch Part number: WB24T10153
