Discuss
1950's stove - fuse problems?
 in
Got an old 50's era RCA Victor Hotpoint range/stove. Nothing worked on it when it was acquired. The wiring looked
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 1950's stove - fuse problems?
  #1 (permalink)
Old 03-28-2013, 07:16 AM
Junior Member
meneermalik is on a distinguished road
Default 1950's stove - fuse problems?
Brand: -brand-   Age: More than 10 years
Got an old 50's era RCA Victor Hotpoint range/stove. Nothing worked on it when it was acquired. The wiring looked good so we inspected the fuses. All were pretty much finished. We know the stove worked up until 5-10 years ago.
We replaced the fuses with the same types that were in there. Two of the stove top elements now work. The other two blew the fuses in the range when they were turned on. Any idea why? Any idea as to the fuse types for this type of stove?
The are 5 sets (of 2) of fuse plugs plus an 11th fuse plug on the side. After cleaning the inside of the stove near the fuses there's a number under each set that says 15A. Would it mean that 15a fuses should go in both plugs of each set? The fuses that we took out and replaced vary from 15 to 30.
Thanks for any help in the matter!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1950's GE Fridge with 3 in 1 bw800402 Refrigerator & Freezer Repair 6 03-15-2012 01:31 AM
Problems with Thermal Fuse mapirkle Dryer Repair 1 12-23-2011 04:26 AM
Just one fuse in stove? And how do you take it out? wbamberger Oven Repair (including Ranges and Cooktops) 0 10-07-2011 03:07 PM
1950's era Roper Town & Country Stove/Oven MGreebel Oven Repair (including Ranges and Cooktops) 0 01-08-2010 01:58 PM
kenmore 1950's oven jthom Oven Repair (including Ranges and Cooktops) 0 12-09-2009 08:29 AM
