upper oven broiler ignitor not heating up due to no power going to ignitor when i turn on upper broil the upper bake ignitor comes on and bake burner lights even though im calling for broil only model MGR6772BDW ser 15035826EE the dual gas valve has continuity through it but no power there im thinking bad clock assembly but dont want to order clock unless i sure any help out there
Hello, If there is no power to the igniter but the gas safety valve is good then the problem is a bad oven control board. So your guess is correct. - The control board Part number: 5701M576-60
