Discuss
replaced oven ignitor and sensor, still not getting up to temp
 in
Hello, I have a CRG9800AAE Maytag gas range/oven. Recently it started to operate erratically. It would heat up to temp(I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replaced oven ignitor and sensor, still not getting up to temp
  #1 (permalink)
Old 03-25-2013, 04:54 PM
Junior Member
BSTrue is on a distinguished road
Default replaced oven ignitor and sensor, still not getting up to temp
Model Number: CRG9800AAE   Brand: Maytag   Age: More than 10 years
Hello, I have a CRG9800AAE Maytag gas range/oven. Recently it started to operate erratically. It would heat up to temp(I thought) and then would fail to keep the oven at that temp(I now know due to a couple of under-baked items). I replaced the ignitor (that didn't do it). It fires up, but doesn't keep firing up to maintain temp.
I replaced the temp sensor(that didn't do it either). I start it, set it at 375deg, it takes about 5 minutes and beeps claiming to have reached that temp. According to my newly acquired oven thermometer,it is barely
at 150 deg.
If I turn it up higher,or open the oven door for a bit, it might kick in again and run for a few minutes, but then it beeps showing that it has reached the set temp when it has only gained 10-30 degrees. Nowhere near where it was set for. It even shows the temp rising up to the set temp. on the control board. I set it for 450 deg, it says it reached that temp, the thermometer says its at around 275. It has gotten as hot as 325.
Is this the timer/control board?
I would like to be sure this is what is the problem before I replace this, as it is a pretty expensive part.
Thanks for any help you can provide....
Brenda
Related Models
Maytag CRG9800AAE RANGE- S/C F/S GAS
Maytag CRG9800AAL RANGE- S/C F/S GAS
Maytag CRG9800AAW RANGE- S/C F/S GAS
Maytag CRG9800BAB RANGE- S/C F/S GAS
Maytag CRG9800BAE RANGE- S/C F/S GAS
Maytag CRG9800BAL RANGE- S/C F/S GAS
Maytag CRG9800BAM RANGE- S/C F/S GAS
Maytag CRG9800BAW RANGE- S/C F/S GAS
Maytag CRG9800CAB RANGE- S/C F/S GAS
Maytag CRG9800CAE RANGE- S/C F/S GAS
Maytag CRG9800CAM RANGE- S/C F/S GAS
Maytag CRG9830CAB RANGE- S/C F/S GAS
Maytag CRG9830CAE RANGE- S/C F/S GAS
Maytag CRG9830CAM RANGE- S/C F/S GAS
Admiral CRGA250AAL RANGE- F/S STD GAS
Admiral CRGA250AAW RANGE- F/S STD GAS
Admiral CRGA250BAL RANGE- F/S STD GAS
Admiral CRGA250BAW RANGE- F/S STD GAS
Admiral CRGA300AAL RANGE- F/S STD GAS
Admiral CRGA300AAW RANGE- F/S STD GAS
Admiral CRGA300BAL RANGE- F/S STD GAS
Admiral CRGA300BAW RANGE- F/S STD GAS
Admiral CRGA350AAL RANGE- F/S STD GAS
Admiral CRGA350AAW RANGE- F/S STD GAS
Admiral CRGA400AAL RANGE- F/S STD GAS
Admiral CRGA400AAW RANGE- F/S STD GAS
Admiral CRGA400BAL RANGE- F/S STD GAS
Admiral CRGA400BAW RANGE- F/S STD GAS
Admiral CRGA500AAL RANGE- F/S STD GAS
Admiral CRGA500AAW RANGE- F/S STD GAS
Admiral CRGA600AAL RANGE- S/C F/S GAS
Admiral CRGA600AAW RANGE- S/C F/S GAS
Admiral CRGA650AAL RANGE- S/C F/S GAS
Admiral CRGA650AAW RANGE- S/C F/S GAS
Admiral CRGA700AAL RANGE- S/C F/S GAS
Admiral CRGA700AAW RANGE- S/C F/S GAS
Admiral CRGA800AAE RANGE- F/S STD GAS
Admiral CRGA800AAL RANGE- F/S STD GAS
Admiral CRGA800AAW RANGE- F/S STD GAS
Frigidaire CRGF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CRGF342AS1 Dryer - Frig/best Buy
Frigidaire CRGF342AS2 Frigidaire/gas Range
Frigidaire CRGF342AS3 Frigidaire/gas Dryer
Frigidaire CRGF342AS4 Frigidaire/dryer
Frigidaire CRGR442AS0 Dryer - Frig/best Buy
Frigidaire CRGR442AS1 Dryer - Frig/best Buy
Frigidaire CRGR442AS2 Dryer - Frig/best Buy
Frigidaire CRGR5700AS0 Dryer - Frig/best Buy
Frigidaire CRGR5700AS1 Frigidaire/gas Dryer
Frigidaire CRGR5700AS2 Frigidaire/gas Dryer
Frigidaire CRGR5700AS3 Frigidaire/dryer
Frigidaire CRGR7900AS0 Dryer - Frig/best Buy
Frigidaire CRGR7900AS1 Frigidaire/gas Dryer
Frigidaire CRGR7900AS2 Frigidaire/gas Dryer
Frigidaire CRGR7900AS3 Frigidaire/dryer
Amana CRH4-1 COMMERCIAL MICROWAVES
Amana CRH4-3 COMMERCIAL MICROWAVES
Amana CRH5-1 COMMERCIAL MICROWAVES
Amana CRH5-3 COMMERCIAL MICROWAVES
Admiral CRL5300BXA RANGE- F/S STD GAS
Admiral CRL5300BXW RANGE- F/S STD GAS
Admiral CRL5300CXL RANGE- F/S STD GAS
Admiral CRL5300CXW RANGE- F/S STD GAS
Admiral CRL5300DXL RANGE- F/S STD GAS
Admiral CRL5300DXT RANGE- F/S STD GAS
Admiral CRL5300DXW RANGE- F/S STD GAS
Admiral CRL7400CAL RANGE- F/S STD GAS
Admiral CRL7400CAW RANGE- F/S STD GAS
Amana CRMC-20B MWAVE - FAMILY SIZE (60 HZ)
Amana CRMC-30 RANGE- S/C S/I DDRAFT GAS
Amana CRMC-30 MICROWAVE - CONVECTION
Amana CRMC-30 MWAVE - FAMILY SIZE (60 HZ)
Amana CRMC720 MICROWAVE - CONVECTION
Maytag CRP200 RANGE- F/S STD GAS
Maytag CRP200B RANGE- F/S STD GAS
Maytag CRP205 RANGE- F/S STD GAS
Maytag CRP300 RANGE- F/S STD GAS
Maytag CRP300B RANGE- F/S STD GAS
Maytag CRP382 RANGE- F/S STD GAS
Maytag CRP382B RANGE- F/S STD GAS
Maytag CRP5300AXL RANGE- F/S STD GAS
Maytag CRP5300AXW RANGE- F/S STD GAS
Admiral CRPA200AXL RANGE- F/S STD GAS
Admiral CRPA200AXW RANGE- F/S STD GAS
Admiral CRPA200BXL RANGE- F/S STD GAS
Admiral CRPA200BXW RANGE- F/S STD GAS
Amana CRR-1225 MWAVE- CNTRTP / STAND ALONE
Amana CRR-5B MWAVE- CNTRTP / STAND ALONE
Amana CRR-7B MWAVE - FAMILY SIZE (60 HZ)
Amana CRR-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana CRR1220 MWAVE- CNTRTP / STAND ALONE
Amana CRRL-5C MWAVE- CNTRTP / STAND ALONE
Amana CRRL-5C MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-5D MWAVE- CNTRTP / STAND ALONE
Amana CRRL-5D MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-700 MWAVE- CNTRTP / STAND ALONE
Amana CRRL-700 RANGE- S/C S/I DDRAFT GAS
Amana CRRL-8TD MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-8TD MWAVE- CNTRTP / STAND ALONE
Amana CRRL-8X MWAVE- CNTRTP / STAND ALONE
Amana CRRL-8XA MWAVE- CNTRTP / STAND ALONE
Amana CRRL-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-9TC MWAVE- CNTRTP / STAND ALONE
Amana CRRL1020 MWAVE- CNTRTP / STAND ALONE
Amana CRRL920 MWAVE- CNTRTP / STAND ALONE
Amana CRS30 MWAVE- CNTRTP / STAND ALONE
Amana CRS40 MWAVE- CNTRTP / STAND ALONE
Amana CRS414T MWAVE- CNTRTP / STAND ALONE
Amana CRS415T MWAVE- CNTRTP / STAND ALONE
Amana CRS457P MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 03-26-2013, 11:54 AM
Junior Member
Default
It LOOKS like this is the problem, I just wanted to be sure there wasn't any other likely things going on here. IE, not valves or regulators or anything....
Would anyone have some advice on this?
Thanks, Brenda
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven temp sensor jason sholar Oven Repair (including Ranges and Cooktops) 0 04-18-2011 06:26 PM
Kenmore replaced coils,ignitor,and flame sensor still no heat. cfreeman Dryer Repair 3 01-01-2011 09:53 AM
Oven temp sensor Pcat Oven Repair (including Ranges and Cooktops) 0 10-24-2009 07:41 AM
oven temp sensor TexMac Oven Repair (including Ranges and Cooktops) 2 08-13-2009 03:41 PM
Oven sensor - upper replaced, still not working Jerry Parker Oven Repair (including Ranges and Cooktops) 0 12-24-2008 11:43 AM
