Discuss
F8 E1 Fault Code
 in
I began the self clean cycle which proceeded about 15 to 20 seconds and then shut down with the F8
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F8 E1 Fault Code
  #1 (permalink)
Old 03-25-2013, 11:31 AM
Junior Member
nrdlik is on a distinguished road
Default F8 E1 Fault Code
Model Number: KEMC378KSS04   Brand: Kitchen Aid   Age: 5 - 10 years
I began the self clean cycle which proceeded about 15 to 20 seconds and then shut down with the F8 followed by E1 displayed on the control panel. The "Door Locked" message was flashing. At this point I was unable to open the oven door. It was latched but I could move it slightly. Confused, I decided to switch off the breaker and switch it back on. After about 2 to 4 minutes I was able to open the oven door. So, I repeated the same actions again and had the same result. I thought I had better see if the oven would heat to a specific pre-heat temperature so I pre-heated to 350 degrees farenheit. The pre-heat cycle worked fine and an audible signal was emitted when it reached the specified temperature. While I have not gone through a complete cooking cycle to test that the oven is cooking properly, I suspect the problem is primarily related to the self-clean cycle.
I contacted Whirlpool concerning the fault codes and their staff could not locate the F8 or the E1 codes descriptions. I asked about the tech sheet they show in their exploded view parts diagram and they suggested I call AE Factory Service. They, AE, had no technician they could refer me to and said just set up a service appointment ($129 + parts) and they could resolve the issue. That result led me to your site. Spoke to Liya who was unable to find the codes and suggested I post my experience for a tech response. In my travels so far, I am sensing that the F8 is a control panel issue (PN 8302346 $374.41 on the Whirlpool parts site). Others think the code F8 refers to the door latch assembly (PN 9760888 $138.61 on the Whirlpool site).
If we can resolve the Fault Code leading to a needed repair part, I would like to know if it will be necessary to remove the oven/mircoware combo unit from its enclosure to do the part(s) replacement. Hopefully not, but if so, I would like to have a repair sequence instruction for the part install.
Thanks in advance for your response to my post question.
nrdlik
Related Models
Whirlpool KEMC378KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH0 OVEN WITH MICROWAVE
Whirlpool KEMC378KWH01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMI300SBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300SBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL2 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL3 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL4 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL5 BUILT-IN OVEN WITH MICROWAVE
KitchenAid KEMI300WBL0 ELEC. BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL2 ELEC BUILT IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL3 30" BUILT-IN COMBINATION OVEN
Whirlpool KEMI301BWH0 30" ELECTRIC BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI301GBL0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI301GWH0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI371BBL0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BBL1 27" BUILT-IN OVEN
Whirlpool KEMI371BBL2 27" BUILT-IN OVEN
Whirlpool KEMI371BWH0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BWH1 27" BUILT-IN OVEN
Whirlpool KEMI371BWH2 27" BUILT-IN OVEN
Whirlpool KEMI371GBL0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371GWH0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371SBL0 Ranges, Electric*
Whirlpool KEMI371TBL0 Ranges, Electric*
Whirlpool KEMI371TBL1 ELECTRIC RANGE
Whirlpool KEMI371TBL2 ELECTRIC RANGE
Whirlpool KEMI371TBL3 Ranges, Electric*
Whirlpool KEMI371XBL0 Ranges, Electric*
Whirlpool KEMI371XBL1 Ranges, Electric*
Whirlpool KEMI371XBL2 Ranges, Electric*
Whirlpool KEMI371YWH0 Ranges, Electric*
Whirlpool KEMS306BAL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BAL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BAL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BAL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BBL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BBL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BWH1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BWH2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306XAL0
Whirlpool KEMS306XAL1
Whirlpool KEMS306XAL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XAL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XAL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XAL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XBL0 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XBL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XBL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XWH0 Ranges, Electric*
Whirlpool KEMS306XWH1 Ranges, Electric*
Whirlpool KEMS306XWH2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XWH3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XWH4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XWH5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XWH6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS307DAL1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DAL2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DAL4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DAL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBL1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBL2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBL4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DBL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBS2 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBS4 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBS6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBT6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DWH2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DWH4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DWH6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307GAL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GAL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GAL2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GBL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBL2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBL4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GBS0 BUILT-IN ELECTRIC OVEN
Whirlpool KEMS307GBS1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBS2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBS3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBS4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GBT0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GBT1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBT2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBT4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GWH0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GWH1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GWH2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GWH3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GWH4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS308GBL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GBL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS308GBL2 OVEN/MW
Whirlpool KEMS308GBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS308GSS0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GSS1 OVEN/MW
Whirlpool KEMS308GSS2 BUILT-IN OVEN, ELECTRIC W/MICROWAVE
Whirlpool KEMS308GSS3 BUILT-IN OVEN/MW, ELECTRIC
Whirlpool KEMS308GWH0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GWH1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS308GWH2 OVEN/MW
  #2 (permalink)
Old 03-28-2013, 12:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
The "F8E1" error code means "Self-clean latch will not unlock".
Check the wires connections between the door latch and the control board. If there is nothing wrong replace the door latch assembly. The instructions and the tech sheet are attached to the post.
- The door latch assembly Part number: W10195934
Here are the breakdown diagrams and Parts for Whirlpool KEMC378KSS04 Wall Oven - AppliancePartsPros.com
File Type: pdf Tech Sheet - 8303852 - KEMC378KSS04.pdf (418.2 KB, 8 views)
File Type: doc Removing the lower oven door latch assembly.doc (452.5 KB, 6 views)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fault Code F20 gmbdinc Oven Repair (including Ranges and Cooktops) 1 01-07-2013 11:01 AM
GE fault code f3 ricky1842 Oven Repair (including Ranges and Cooktops) 1 09-27-2012 03:40 PM
code fault F H davisru Washer Repair 1 01-30-2011 11:47 AM
fault code f-9 Lou Barta Microwave Repair 1 04-03-2008 07:26 PM
F0 fault code William Oven Repair (including Ranges and Cooktops) 0 10-10-2007 06:13 PM
