dudman
#1 Posted : Sunday, March 24, 2013 7:50:56 PM(UTC)
dudman
the burner light on the left side is on the burners are off. the indicater light never go off.:confused:
#2 Posted : Monday, March 25, 2013 7:46:41 PM(UTC)
Hello,
Unplug the range. Remove the rear control panel cover. Remove the wire from the L1 terminal on each of the left side switches and check for continuity between the L1 & P terminals on each switch. If it reads continuity, replace the switch.
- The infinity switch for 6" burner Part number: 316436000
- The infinity switch for 8" burner Part number: 316436001
dudman
#3 Posted : Tuesday, March 26, 2013 12:01:59 PM(UTC)
dudman
Hello,
Gene.[/quote
Thermador Pro Grand 30" Rnage Burner Light Stays On (Oven Repair (including Ranges and Cooktops))
by hacker888 6/12/2012 6:10:49 PM(UTC)
Only one side of the burner lighting (Oven Repair (including Ranges and Cooktops))
by adrabek 10/9/2011 1:01:16 PM(UTC)
Burner Lighting Problem (Oven Repair (including Ranges and Cooktops))
by gilkelley 1/26/2011 1:01:28 AM(UTC)
Erratic oven burner lighting (Oven Repair (including Ranges and Cooktops))
by mjlewandowski 5/24/2010 9:14:11 AM(UTC)
Dryer burner lights but goes out after 10 seconds (Dryer Repair)
by jbenjamin 7/26/2009 8:51:14 AM(UTC)
Burner Light won't turn off (Oven Repair (including Ranges and Cooktops))
by beachrog 4/22/2009 4:07:50 AM(UTC)
hot burner light stays on (Oven Repair (including Ranges and Cooktops))
by bkitchen 4/8/2009 5:09:15 AM(UTC)
Gas burner lights then shuts off 3 min later (Dryer Repair)
by Gene9061 11/4/2008 5:13:51 PM(UTC)
by Gene9061 11/4/2008 5:13:06 PM(UTC)
Igniters keep clicking after burner lights (Oven Repair (including Ranges and Cooktops))
by rsisk 9/17/2008 5:07:55 AM(UTC)
Whrilpool SC8900EX only one burner lights (Oven Repair (including Ranges and Cooktops))
by ScottB 3/28/2008 7:37:29 AM(UTC)
Oven Burner Lights then Sputters (Oven Repair (including Ranges and Cooktops))
by markwidz 1/29/2008 5:22:25 AM(UTC)
Frigidaire Electric Oven Rear burner light wont go off (Oven Repair (including Ranges and Cooktops))
by seagullgeneral 12/14/2007 2:39:52 PM(UTC)
