| » Kitchen aid double oven Thermal Fuse |
Model Number: KEBS278DSS10 Brand: Kitchen Aid Age: 5 - 10 years
Hello. After researching online it looks like it is a common problem to have the thermal fuse on kitchenaid ovens go out during self Cleaning I was able to get the door unclocked by opening the assembly where the control panel is. I cant seem to find the thermal fuse. I think it might be on the back of the oven. Does that mean I have to take the entire oven out of the wall?? There is not power whatsoever to the contol panel. Id like to fix this myself, but I cant find any instructions or diagrams to assist me.
My other thought is to just replace the whole oven with another brnd unit. I know this is not economical, but if this is going to keep happening which it sounds like it does, I am wondering if i should do this. ANY help would be gratly appreciated! Thanks so much in advance. jv Ads By Google Related Models |
Ok after working on this all day, I finally got the oven out.. WHEW.. Took off the back panel and removed the TCO. To test if the TCO was bad, I cliped the two wires that were connected to the TCO together and turn the breaker back on. Still nothing happened, no display. I am assuming the display and or micro computer has been fried. My question is connecting these two wires w/o the fuse should work if everything else is operational, right? At this point the cost of the new control assembly is outrageous so Imight just buy a new oven. I just want to make sure it is not the TCO... ANy thoughts or ideas would be greatly appreciated.
jv |
Here is the tech sheet
http://www.servicematters.com/docs/w...%204451879.pdf You will notice that there are 2 fuses in this unit. I believe the one for the boards power supply is behind the controls on the top of the oven. The one on the back is just for the elements.
__________________
| Display Modes | |
| Oven thermal fuse alternative | beocop | Oven Repair (including Ranges and Cooktops) | 2 | 12-09-2012 08:39 AM |
| Whirlpool Built in Oven - thermal fuse | Pastor George | Oven Repair (including Ranges and Cooktops) | 3 | 12-04-2010 09:44 AM |
| possible thermal fuse for dble oven question | ssff | Oven Repair (including Ranges and Cooktops) | 0 | 11-25-2009 03:02 AM |
| Kitchen Aid Dishwasher thermal fuse | Clay Man | Dishwasher Repair | 1 | 11-03-2009 03:34 AM |
| Oven shutdown thermal fuse | tony3333 | Oven Repair (including Ranges and Cooktops) | 1 | 05-12-2009 07:38 AM |
