Discuss
GE Profile oven ignition problem
 in
Our GE Profile gas oven nearly explodes when igniting. Sometime it lites normally. At other times it ignites with a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile oven ignition problem
  #1 (permalink)
Old 03-24-2013, 06:20 AM
Junior Member
Waterbug is on a distinguished road
Default GE Profile oven ignition problem
Brand: GE   Age: 5 - 10 years
Our GE Profile gas oven nearly explodes when igniting. Sometime it lites normally. At other times it ignites with a bang. At times there is the oder of gas when igniting. It is propane powered. I'thinking gas presure regulator, but is it a faulty part or an adjustment?
  #2 (permalink)
Old 03-25-2013, 06:28 AM
Junior Member
Default
I just solved my own issue. The holes in the gas igniter tube were corroded shut in the area of the electronic igniter. I cleaned the holes and all is well. Will replace the tube because it will corrode again in short order, now that the anti oxidation coating is gone.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE XL44 Gas Oven problem????? Ignition?? John79 Oven Repair (including Ranges and Cooktops) 3 12-15-2011 12:24 PM
Ignition Problem GE Profile alexj Oven Repair (including Ranges and Cooktops) 2 01-08-2010 04:16 PM
oven ignition problem powellbren Oven Repair (including Ranges and Cooktops) 1 07-05-2009 12:04 PM
GE Profile Burner Ignition Inconsistant nycphog Oven Repair (including Ranges and Cooktops) 3 12-04-2007 06:20 PM
