Hi My problem was the back burner would stay on at low heat when I turned the switch to the off position. The indicator light would also remain lit showing power to the burner. I had replaced the switch which solved the problem of the burner and the light staying on, but now the tea pot boils at low setting. I checked and made sure that I do not have the switch upside down. I replaced it with second new switch and still have the same problem. Can't be 2 bad switches? Should I start tracing wires with a continuity test? Any help will be greatly appreciated Thanks george
