Discuss
Self-Cleaning Oven Problem
 in
Self-cleaning cycle stopped functioning. Manual indicates to ensure oven racks and oven rack supports have been removed. Have done that.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Self-Cleaning Oven Problem
  #1 (permalink)
Old 03-19-2013, 04:57 PM
Junior Member
rejuras is on a distinguished road
Default Self-Cleaning Oven Problem
Model Number: E30DF74GPS2   Brand: Electrolux   Age: 1 - 5 years
Self-cleaning cycle stopped functioning. Manual indicates to ensure oven racks and oven rack supports have been removed. Have done that. However, the "Racks" indicator light flashes and the unit will not lock and start the self-cleaning cycle. This model does not have any error message indicators. I have done a little research from the manuals and the internet and they seem to point to the rack sensing switch (part no. 318903401) or the control panel (part no. unknown). Any ideas? Thanks!
Ads By Google
Related Models
 E30DF74GPS2 DUAL FUEL RANGE
 E30DF74GPS3 DUAL FUEL RANGE
 E30DF74GPS5 DUAL FUEL RANGE
 E30DF7CGPS1 DUAL FUEL RANGE
 E30DF7CGPS2 DUAL FUEL RANGE
 E30DF7CGPS3 DUAL FUEL RANGE
 E30EC65ESS1 ELECTROLUX/COOKTOP
 E30EC65ESS2 ELECTROLUX/COOKTOP
 E30EC65ESS3 ELECTROLUX/ COOK TOP
 E30EC70FSS1 ELECTROLUX/COOKTOP
 E30EC70FSS2 ELECTROLUX/COOKTOP
 E30EC70FSS3 COOKTOP
 E30EW75DSS1 ELECTROLUX/WALL OVEN
 E30EW75EPS1 ELECTROLUX/WALL OVEN
 E30EW75EPS3 ELECTROLUX/WALL OVEN
 E30EW75EPS4 ELECTROLUX/WALL OVEN
 E30EW75ESS2 ELECTROLUX/WALL OVEN
 E30EW75ESS3 ELECTROLUX/WALL OVEN
 E30EW75GPS1 WALL OVEN
 E30EW75GPS2 WALL OVEN
 E30EW75GPS3 WALL OVEN
 E30EW75GPS4 WALL OVEN
 E30EW75GSS1 WALL OVEN
 E30EW75GSS2 WALL OVEN
 E30EW75GSS3 WALL OVEN
 E30EW7CDSS1 ELECTROLUX/ELECTRIC WALLOVEN
 E30EW7CEPS1 ELECTROLUX CANADA/WALL OVEN
 E30EW7CEPS3 ELECTROLUX CANADA/WALL OVEN
 E30EW7CEPS4 WALL OVEN
 E30EW7CESS2 ELECTROLUX CANADA/WALL OVEN
 E30EW7CESS3 ELECTROLUX/WALL OVEN
 E30EW7CGPS1 WALL OVEN
 E30EW7CGPS2 WALL OVEN
 E30EW7CGPS3 WALL OVEN
 E30EW7CGPS4 ELECTROLUX/WALL OVEN
 E30EW7CGSS1 WALL OVEN
 E30EW7CGSS3 WALL OVEN
 E30EW85EPS1 ELECTROLUX/ELECTRIC WALLOVEN
 E30EW85EPS2 ELECTROLUX/WALL OVEN
 E30EW85EPS3 ELECTROLUX/WALLOVEN
 E30EW85EPS4 WALL OVEN
 E30EW85ESS1 ELECTROLUX/WALL OVEN
 E30EW85ESS2 ELECTROLUX/WALL OVEN
 E30EW85GPS1 WALL OVEN
 E30EW85GPS2 WALL OVEN
 E30EW85GPS3 WALL OVEN
 E30EW85GPS4 WALL OVEN
 E30EW85GPS5 WALL OVEN
 E30EW85GPS6 WALL OVEN
 E30EW85GSS1 WALL OVEN
 E30EW85GSS2 WALL OVEN
 E30EW85GSS3 WALL OVEN
 E30EW85GSS4 WALL OVEN
 E30EW85GSS5 WALL OVEN
 E30EW8CEPS1 ELECTROLUX CANADA/WALL OVEN
 E30EW8CEPS3 WALL OVEN
 E30EW8CESS1 ELECTROLUX/WALL OVEN
 E30EW8CESS2 ELECTROLUX CANADA/WALLOVEN
 E30EW8CGPS1 WALL OVEN
 E30EW8CGPS2 WALL OVEN
 E30EW8CGPS3 WALL OVEN
 E30EW8CGPS4 WALL OVEN
 E30EW8CGPS5 WALL OVEN
 E30EW8CGPS6 WALL OVEN
 E30EW8CGSS1 WALL OVEN
 E30EW8CGSS2 WALL OVEN
 E30EW8CGSS3 WALL OVEN
 E30EW8CGSS4 WALL OVEN
 E30EW8CGSS5 ELECTROLUX/WALL OVEN
 E30GC64ESS ELECTROLUX/GAS COOKTOP
 E30GC70FSS1 ELECTROLUX/GAS COOKTOP
 E30GC74GPS1 COOKTOP
 E30GC74GPS2 COOKTOP
 E30GF74GPS GAS RANGE
 E30GF74HPS1 GAS RANGE
 E30GF74HPS2 GAS RANGE
 E30GF74HPS3 RANGE
 E30IC75FSS1 ELECTROLUX/COOKTOP
 E30IC75FSS3 ELECTROLUX/COOK TOP
 E30IC75FSS4 COOKTOP
 E30IC75FSS5 COOKTOP
 E30IC80ISS1 COOKTOP
 E30MC75JPS1 WALL OVEN-MICROWAVE COMBO
 E30MC75JPS2 WALL OVEN-MICROWAVE COMBO
 E30MC75JPS3 WALL OVEN-MICROWAVE COMBO
 E30MC75JSS1 WALL OVEN-MICROWAVE COMBO
 E30MC75JSS2 WALL OVEN-MICROWAVE COMBO
 E30MH65GPSA OVER-RANGE MICROWAVE
 E30MH65GSSA OVER-RANGE MICROWAVE
 E30MO65GSSA ELECTROLUX/MICROWAVE
 E30MO65GSSB MICROWAVE
 E30MO75HPSA MICROWAVE
 E30MO75HSSA MICROWAVE
 E30SO75ESS ELECTROLUX/MICROWAVE
 E30SO75ESSA ELECTRIC OVEN
 E30SO75ESSB ELECTROLUX/MICROWAVE
 E30SO75FPSA ELECTROLUX/MICROWAVE
 E30WD75DSS1 ELECTROLUX/WARMER DRAWER
 E30WD75EPS1 ELECTROLUX/WARMER DRAWER
 E30WD75EPS2 ELECTROLUX/WARMER DRAWER
 E30WD75EPS3 ELECTROLUX/WARMER DRAWER
 E30WD75ESS1 ELECTROLUX/WARMER DRAWER
 E30WD75ESS2 ELECTROLUX/WARMER DRAWER
 E30WD75GPS2 WARMER DRAWER
 E30WD75GPS3 WARMER DRAWER
 E30WD75GSS2 WARMER DRAWER
 E30WD75GTT2 WARMER DRAWER
 E30WV60EPS ELECTROLUX/RANGE HOOD
Amana E3100I.000 COMMERCIAL MICROWAVES
Amana E3100I.A COMMERCIAL MICROWAVES
Amana E3100I.B COMMERCIAL MICROWAVES
Amana E3100I.C COMMERCIAL MICROWAVES
 E32AF75FPS0 ELECTROLUX/FREEZER
 E32AF75FPS1 FREEZER
 E32AF75FPS2 FREEZER
 E32AF75FPS3 FREEZER
 E32AF75FPS4 FREEZER
 E32AF75FPS5 FREEZER
 E32AF75FPS6 FREEZER
 E32AF75GTT0 FREEZER
  #2 (permalink)
Old 03-20-2013, 08:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the racks have been properly removed but the EOC displays this error message then the failure can be caused by defective switch contacts, wiring harness connections, stuck sensor rod assembly or defective EOC.
Examine the sensor assembly rod to be sure it can move freely. Also inspect the metal plunger cover on the switch to make sure it has not stuck.
The pivot points of the oven rack sensor assembly as well as the ball bearing assemblies on the oven racks should be lubricated annually or more often as needed. Use only the approved water based graphite lubricant available through authorized Electrolux parts dealers. Use the lubricant sparingly, a few drops is all that is necessary.
If there is nothing wrong, pull the range out of the wall and remove the rear cover to access the main control board. Remove the P5 connector and test for continuity between the wires connected to the pins 5 & 10. The normal reading with the racks removed should be < 1Ω.
If the reading is incorrect, replace the rack sensing switch.
If the reading is correct but the EOC displays the error message, replace the main control board.
- The lubricant Part number: 5304469602
- The rack sensing switch Part number: 318903401
- The main control board Part number: 316455704
Here are the breakdown diagrams and Parts for Electrolux E30DF74GPS2 Range - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Self Cleaning Oven Problem Buddygrant Oven Repair (including Ranges and Cooktops) 0 03-18-2013 08:31 AM
Self-cleaning oven problem hcbenoit Oven Repair (including Ranges and Cooktops) 2 07-10-2011 01:07 PM
self-cleaning oven problem Richard Heckart Oven Repair (including Ranges and Cooktops) 1 04-13-2011 02:55 PM
Oven Self Cleaning Problem double-g Oven Repair (including Ranges and Cooktops) 7 01-19-2011 04:22 PM
Whirlpool oven cleaning problem jwwilliams2 Oven Repair (including Ranges and Cooktops) 0 03-18-2010 01:46 PM
