Discuss
kitchen aid superba control panel wont turn on
 in
It is the same old story turned on self clean and now the control panel won't come on. I bought
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » kitchen aid superba control panel wont turn on
  #1 (permalink)
Old 03-19-2013, 03:42 PM
Junior Member
lickmy rib is on a distinguished road
Default kitchen aid superba control panel wont turn on
Model Number: kgst307hbs1   Brand: Kitchen Aid   Age: 5 - 10 years
It is the same old story turned on self clean and now the control panel won't come on. I bought one on ******** because they aren't available. Is there a code or jumper that needs to be done? The newer one won't turn on either! Checked for continuity on the two thermal fuses they are fine even tried hard wiring them in case still nothing. I am hoping someone has a suggestion I would appreciate it.
Related Models
Whirlpool KGST307HBS1 GAS RANGE
Whirlpool KGST307HBS2 GAS SLIDE IN RANGE
Whirlpool KGST307HBS3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBS6 RANGE
Whirlpool KGST307HBS8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBS9 GAS SLIDE IN RANGE
Whirlpool KGST307HBT0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT2 GAS SLIDE IN RANGE
Whirlpool KGST307HBT3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBT6 RANGE
Whirlpool KGST307HBT8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBT9 GAS SLIDE IN RANGE
Whirlpool KGST307HWH0 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH2 GAS SLIDE IN RANGE
Whirlpool KGST307HWH3 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH4 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HWH6 RANGE
Whirlpool KGST307HWH8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HWH9 GAS SLIDE IN RANGE
Amana KGT-591 RANGE- S/C S/I DDRAFT GAS
Amana KGT-593 RANGE- S/C S/I DDRAFT GAS
Amana KGT-693 RANGE- S/C S/I DDRAFT GAS
Amana KGT341 SURFACE UNIT- GAS
KitchenAid KGTC366EAL0 36" GAS GLASS BURNER COOKTOP
Admiral KGU5700BS REF - SXS
Admiral KGU57990KD REF - SXS/I&W
Admiral KGU5950BS REF - SXS
Admiral KGU5955BS REF - SXS
Admiral KGU6465BS REF - SXS/I&W
Admiral KGU6650 REF - SXS/I&W
Admiral KGU6651 REF - SXS/I&W
Admiral KGU6655 REF - SXS/I&W
Admiral KGU66920 REF - SXS/I&W
Admiral KGU6695 REF - SXS/I&W
Admiral KGU66990 REF - SXS/I&W
Admiral KGU6700BS REF - SXS/I&W
Admiral KGU6940BS REF - SXS/I&W
Admiral KGU6945BS REF - SXS/I&W
Whirlpool KGYE550VWH0 Residential Dryer
Whirlpool KGYE560WAL0
Whirlpool KGYE560WHT0
Whirlpool KGYE560WPL0
Whirlpool KGYE560WTO0
Whirlpool KGYE560WWH0 Residential Dryer
Whirlpool KGYE650VAL0
Whirlpool KGYE650VHT0
Whirlpool KGYE650VPL0
Whirlpool KGYE650VTO0
Whirlpool KGYE650VWH0 Residential Dryer
Whirlpool KGYE660WAL0 GAS DRYER
Whirlpool KGYE660WAL1
Whirlpool KGYE660WHT0 GAS DRYER
Whirlpool KGYE660WPL0 GAS DRYER
Whirlpool KGYE660WTO0 GAS DRYER
Whirlpool KGYE660WWH0 Residential Dryer
Whirlpool KGYE660WWH1 Residential Dryer
Whirlpool KGYE664WWH0 Residential Dryer
Whirlpool KGYE664WWH1 Residential Dryer
Whirlpool KGYE665BAL0 GAS DRYER
Whirlpool KGYE665BAL1 GAS DRYER
Whirlpool KGYE665BWH0 GAS DRYER
Whirlpool KGYE665BWH1 GAS DRYER
Whirlpool KGYE665BWH3 GAS DRYER
Whirlpool KGYE670BAL0 GAS DRYER
Whirlpool KGYE670BAL1 GAS DRYER
Whirlpool KGYE670BAL2 GAS DRYER
Whirlpool KGYE670BAL3 GAS DRYER
Whirlpool KGYE670BWH0 GAS DRYER
Whirlpool KGYE670BWH1 GAS DRYER
Whirlpool KGYE670BWH2 GAS DRYER
Whirlpool KGYE670BWH3 GAS DRYER
Whirlpool KGYE677BWH0 GAS DRYER
Whirlpool KGYE677BWH1 GAS DRYER
Whirlpool KGYE677BWH2 GAS DRYER
Whirlpool KGYE677BWH3 GAS DRYER
Whirlpool KGYE678BAL0 GAS DRYER
Whirlpool KGYE678BAL1 GAS DRYER
Whirlpool KGYE679BBL0 GAS DRYER
Whirlpool KGYE679BBL1 GAS DRYER
Whirlpool KGYE700TWH0 Residential Dryer
Whirlpool KGYE750VWH0 Residential Dryer
Whirlpool KGYE760WAL0 GAS DRYER
Whirlpool KGYE760WAL1 DRYER
Whirlpool KGYE760WHT0 GAS DRYER
Whirlpool KGYE760WPL0 GAS DRYER
Whirlpool KGYE760WTO0 GAS DRYER
Whirlpool KGYE760WWH0 Residential Dryer
Whirlpool KGYE760WWH1 Residential Dryer
Whirlpool KGYE767WWH0 Residential Dryer
Whirlpool KGYE770BAL0 GAS DRYER
Whirlpool KGYE770BAL1 GAS DRYER
Whirlpool KGYE770BAL2 GAS DRYER
Whirlpool KGYE770BWH0 GAS DRYER
Whirlpool KGYE770BWH1 GAS DRYER
Whirlpool KGYE770BWH2 GAS DRYER
Whirlpool KGYE777BWH0 GAS DRYER
Whirlpool KGYE777BWH1 GAS DRYER
Whirlpool KGYE777BWH2 GAS DRYER
Whirlpool KGYE778BAL0 GAS DRYER
Whirlpool KGYE778BAL1 GAS DRYER
Whirlpool KGYE778BAL2 GAS DRYER
KitchenAid KGYE77BWH1 GAS DRYER
Whirlpool KGYE800SWH1 Residential Dryer
Whirlpool KGYE800TAL0
Whirlpool KGYE800THT0
Whirlpool KGYE800TPL0
Whirlpool KGYE800TTO0
Whirlpool KGYE800TWH0 Residential Dryer
Whirlpool KGYE850VWH0 Residential Dryer
Whirlpool KGYE860WAL0
Whirlpool KGYE860WAL1
Whirlpool KGYE860WHT0
Whirlpool KGYE860WPL0
Whirlpool KGYE860WTO0
Whirlpool KGYE860WWH0 Residential Dryer
  #2 (permalink)
Old 03-19-2013, 05:26 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Get the access to the control board, locate the J plug pins 1 and 3. With range plugged in check for 120VAC between those two pins.
If the proper voltage is present - replace the control board again.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Range control panel boblinfortino Oven Repair (including Ranges and Cooktops) 3 01-26-2014 07:01 AM
kitchen aid superba control lock julesygirl Oven Repair (including Ranges and Cooktops) 3 10-29-2012 04:29 PM
Kitchen Aid DW control panel flashing SBerian Dishwasher Repair 0 11-15-2009 02:43 PM
Kitchen Aid Control Panel replacement ndb8fxe Oven Repair (including Ranges and Cooktops) 4 03-07-2009 05:10 AM
Control Panel On Kitchen Aid Oven joncher Oven Repair (including Ranges and Cooktops) 1 01-21-2009 06:46 AM
