Discuss
Error code F10?
 in
Hello, I was using my oven the other day to make cookies. I had it set to 350, and put
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Error code F10?
  #1 (permalink)
Old 03-16-2013, 01:20 PM
Junior Member
cs86 is on a distinguished road
Default Error code F10?
Model Number: FEFL79GBA   Brand: Frigidaire   Age: 1 - 5 years
Hello,
I was using my oven the other day to make cookies. I had it set to 350, and put the cookies in. Less than two minutes later it begins beeping and is showing an F10 error code, and the cookies are completely black.
I've looked around for the F10 error code, it says it means "Runaway Temperature". But other posts I've seen describing the problem don't seem to describe a similar situation like I had above, I read more about how the element never shuts off and they have to cut power to the oven, rather than just suddenly burning cookie dough. The oven shut off when I turned it off from the control panel, I didn't have to cut the power to it or anything.
Any assistance would be much appreciated, thank you!
Related Models
Frigidaire FEFL79GBA Frigidaire/range
Frigidaire FEFL79GCA Frigidaire/range
Frigidaire FEFL79GQA Frigidaire/range
Frigidaire FEFL79GSA Frigidaire/range
Frigidaire FEFL79HBA ELECTRIC RANGE
Frigidaire FEFL79HBB ELECTRIC RANGE
Frigidaire FEFL79HCA ELECTRIC RANGE
Frigidaire FEFL79HCB ELECTRIC RANGE
Frigidaire FEFL79HQA ELECTRIC RANGE
Frigidaire FEFL79HQB ELECTRIC RANGE
Frigidaire FEFL79HSA ELECTRIC RANGE
Frigidaire FEFL79HSB ELECTRIC RANGE
Frigidaire FEFL79JBA ELECTRIC RANGE
Frigidaire FEFL79JBB ELECTRIC RANGE
Frigidaire FEFL79JCA ELECTRIC RANGE
Frigidaire FEFL79JCB ELECTRIC RANGE
Frigidaire FEFL79JCC ELECTRIC RANGE
Frigidaire FEFL79JCE ELECTRIC RANGE
Frigidaire FEFL79JQA ELECTRIC RANGE
Frigidaire FEFL79JQB ELECTRIC RANGE
Frigidaire FEFL79JSA ELECTRIC RANGE
Frigidaire FEFL79JSB ELECTRIC RANGE
Frigidaire FEFL88ABA Frigidaire/electric Range
Frigidaire FEFL88ABB Frigidaire/electric Range
Frigidaire FEFL88ABC Frigidaire/electric Range
Frigidaire FEFL88ACA Frigidaire/electric Range
Frigidaire FEFL88ACB Frigidaire/electric Range
Frigidaire FEFL88ACC Frigidaire/electric Range
Frigidaire FEFL88ASA Frigidaire/electric Range
Frigidaire FEFL88ASB Frigidaire/electric Range
Frigidaire FEFL88ASC Frigidaire/electric Range
Frigidaire FEFL89CCA Frigidaire/electric Range
Frigidaire FEFL89CCB Frigidaire/electric Range
Frigidaire FEFLM600DQA Frigidaire/electric Range
Frigidaire FEFLM600DSA Frigidaire/electric Range
Frigidaire FEFLM605DBB Frigidaire/electric Range
Frigidaire FEFLM605DBD Frigidaire/electric Range
Frigidaire FEFLM605DCB Frigidaire/electric Range
Frigidaire FEFLM605DCC Frigidaire/electric Range
Frigidaire FEFLM605DCD Frigidaire/range
Frigidaire FEFLM605DCE Frigidaire/electric Range
Frigidaire FEFLM605DCG Frigidaire/range
Frigidaire FEFLM605DCH Frigidaire/range
Frigidaire FEFLM605DCJ Frigidaire/range
Frigidaire FEFLM605DQB Frigidaire/electric Range
Frigidaire FEFLM605DQD Frigidaire/electric Range
Frigidaire FEFLM605DSB Frigidaire/electric Range
Frigidaire FEFLM605DSD Frigidaire/electric Range
Frigidaire FEFLM66EBA Frigidaire/electric Range
Frigidaire FEFLM66EBB Frigidaire/electric Range
Frigidaire FEFLM66ESA Frigidaire/electric Range
Frigidaire FEFLM66ESB Frigidaire/electric Range
Frigidaire FEFLM66ESC Frigidaire/range
Frigidaire FEFLMC55FCA Frigidaire/electric Range
Frigidaire FEFLMC55FCB Frigidaire/range
Frigidaire FEFLMC55FCC ELECTRIC RANGE
Frigidaire FEFLMC55GCA ELECTRIC RANGE
Frigidaire FEFLMC55GCC ELECTRIC RANGE
Frigidaire FEFLMC55HCA ELECTRIC RANGE
Frigidaire FEFLMC55HCC ELECTRIC RANGE
Frigidaire FEFLMC55HCE ELECTRIC RANGE
Frigidaire FEFLZ87GCA ELECTRIC RANGE
Frigidaire FEFLZ87GCB ELECTRIC RANGE
Frigidaire FEFLZ87GCC ELECTRIC RANGE
Frigidaire FEFLZ87GCD ELECTRIC RANGE
Frigidaire FEFS52DQA Frigidaire/electric Range
Frigidaire FEFS52DQB Frigidaire/range
Frigidaire FEFS52DQC Frigidaire/range
Frigidaire FEFS52DQD Frigidaire/range
Frigidaire FEFS52DSA Frigidaire/electric Range
Frigidaire FEFS52DSB Frigidaire/range
Frigidaire FEFS52DSC Frigidaire/range
Frigidaire FEFS52DSD Frigidaire/range
Frigidaire FEFS66DQA Frigidaire/electric Range
Frigidaire FEFS66DQB Frigidaire/range
Frigidaire FEFS66DQC Frigidaire/range
Frigidaire FEFS66DQD Frigidaire/range
Frigidaire FEFS66DQF Frigidaire/range
Frigidaire FEFS66DQG Frigidaire/range
Frigidaire FEFS66DQH Frigidaire/range
Frigidaire FEFS66DQJ Frigidaire/range
Frigidaire FEFS66DSA Frigidaire/electric Range
Frigidaire FEFS66DSB Frigidaire/range
Frigidaire FEFS66DSC Frigidaire/range
Frigidaire FEFS66DSD Frigidaire/range
Frigidaire FEFS66DSF Frigidaire/range
Frigidaire FEFS66DSG Frigidaire/range
Frigidaire FEFS66DSH Frigidaire/range
Frigidaire FEFS66DSJ Frigidaire/range
Frigidaire FEFS68CJBA Frigidaire/electric Range
Frigidaire FEFS68CJBB Frigidaire/electric Range
Frigidaire FEFS68CJBC Frigidaire/electric Range
Frigidaire FEFS68CJSA Frigidaire/electric Range
Frigidaire FEFS68CJSB Frigidaire/electric Range
Frigidaire FEFS68CJSC Frigidaire/electric Range
Frigidaire FEFS68CJTA Frigidaire/electric Range
Frigidaire FEFS68CJTB Frigidaire/electric Range
Frigidaire FEFS68CJTC Frigidaire/electric Range
Frigidaire FEGB24S5ASE GAS OVEN
Roper FEP210EN0 ELECTRIC RANGE
Roper FEP210EN1 ELECTRIC RANGE
Roper FEP210EN2 ELECTRIC RANGE
Roper FEP210EN3 ELECTRIC RANGE
Roper FEP210EN4 ELECTRIC RANGE
Roper FEP210EN5 ELECTRIC RANGE
Roper FEP210EN6 ELECTRIC RANGE
Roper FEP210EQ2 ELECTRIC RANGE
Roper FEP210EQ3 ELECTRIC RANGE
Roper FEP210EQ4 ELECTRIC RANGE
Roper FEP210EQ5 ELECTRIC RANGE
Roper FEP210EW0 ELECTRIC RANGE
Roper FEP210EW1 ELECTRIC RANGE
Roper FEP210EW2 ELECTRIC RANGE
Roper FEP210EW3 ELECTRIC RANGE
Roper FEP210EW4 ELECTRIC RANGE
Roper FEP210EW5 ELECTRIC RANGE
Roper FEP210KN0 ELECTRIC RANGE
Roper FEP210KQ0 ELECTRIC RANGE
Roper FEP210KQ1 20" ELECTRIC FREESTANDING RANGE STANDARD CLEAN OVEN
Roper FEP210KW0 ELECTRIC RANGE
  #2 (permalink)
Old 03-17-2013, 04:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire FEFL79GBA Range - AppliancePartsPros.com
Here is the etch sheet.
http://manuals.frigidaire.com/prodin...16441481en.pdf
Those folks who had to cut power to the unit had a similar but different problem to yours. In their case either the bake or the broil relay contacts on the control board had welded together so that the element was always on.
In your case the relays are probably OK but for some reason the control board is keeping the relay closed.
Get an oven thermometer so you can measure the actual oven temperature.
Have you tried it since then?
It would not hurt to check the oven sensor with a meter, see the tech sheet.
I doubt this is your problem as the sensor is what told the control that the oven was too hot.
Odds are that the control board/timer is toast.
If you check the oven temperature and it is still running too hot, try removing power from the unit (unplug or flip the breaker off) for a couple minutes to see if the board will reset and work correctly.
Sometimes a glitch can confuse the microprocessor on the board and cause problems.
This is also a long shot.
__________________
  #3 (permalink)
Old 03-17-2013, 01:21 PM
Junior Member
Default
Thanks so much for the reply.
Yes I have tried it since then. I didn't want to make the original post too long so I didn't explain everything, but in case it changes anything I will explain the rest of it.
A few days before the cookies were burned, I had tried baking another dessert. The recipe called for approximately 35 minutes bake time, but it had to bake for over 75 minutes. I had chalked this up to using a very different pan size than the recipe called for, and doubling the batch. I brushed it off as nothing, even though I thought 75 minutes was excessive, especially when I made the exact thing a week later at a friends house and it took about 45 minutes. Of course by this time the oven at my house had already gone wonky, which was why I was at my friends house baking.
Come to find out, someone else who lives in the house decided it was a good idea to line the bottom of the oven with tinfoil, to make it easier to clean. Even though it is a self-cleaning oven. Apparently at some point the foil had curled up and was touching one of the coils along the bottom. Once the foil was removed, we turned the oven on to test it again. It seemed to work fine. Used it for a few weeks, no error codes flashed. Assumed it was fixed.
Then around 3 weeks later the same thing happened. Making dinner, put some biscuits in the oven, and a minute or two later they were burnt.
I haven't tried it since then.
Thank you for the links to the tech sheet and parts, as well as the advice. I will check all of that in the next few days.
  #4 (permalink)
Old 03-18-2013, 01:14 PM
Junior Member
grytten is on a distinguished road
Default Kenmore over error F10
Hi, I'm having the error code F10, with the same problem as others have had, with the oven getting incredibly hot. My oven is a Kenmore model 316402710.
The cooktop works fine.
I'd just like to know what steps I need to take to fix it. I wasn't sure if the EOC needs to be replaced or if the problem is something else. I haven't checked the temperature probe as I don't have an ohmmeter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven Error Code F3 E2 - Replaced Oven Tem Sensor and still getting error loanguy7171973 Oven Repair (including Ranges and Cooktops) 1 12-01-2012 03:53 AM
ERROR CODE F6E5 Cancel key error tammike Oven Repair (including Ranges and Cooktops) 8 08-06-2012 08:54 AM
Duet error code FH and diagnostic code C03 angelo78 Washer Repair 0 03-21-2012 08:12 AM
LG error code OE - drain error JPotter Washer Repair 0 04-01-2011 07:20 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
