Discuss
SEG196-Wiring a two wire replacement switch ???
 in
Part # 12200039 Replacement Jenn Air Fan Switch - 2 Wires Need too know what 2 wires should go to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » SEG196-Wiring a two wire replacement switch ???
  #1 (permalink)
Old 03-16-2013, 11:02 AM
Junior Member
Alan Gerew is on a distinguished road
Question SEG196-Wiring a two wire replacement switch ???
Brand: Jenn-Air   Age: More than 10 years
Need too know what 2 wires should go to the replacement switch I just got. Currently there are 4 wires to the old switch. (I know I can only use either fan or light with new switch.
What two would I use for just the fan?
Color wires are WHITE, BLUE, BROWN, RED
  #2 (permalink)
Old 03-17-2013, 04:33 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Looks like Blue and Red are for the blower
And Brown and White are for the light.
__________________
  #3 (permalink)
Old 05-07-2013, 03:40 PM
Junior Member
lanham01 is on a distinguished road
Default
I just installed a 2-wire replacement switch and the blue and red wires did the trick. Thank you. I am glad I found this post.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Proper Wiring to replacement Door Lock Switch Teacher123 Washer Repair 5 07-17-2012 06:17 PM
prsg304 oven switch replacement wiring diagram help mpap89 Oven Repair (including Ranges and Cooktops) 1 07-22-2010 07:58 AM
Wiring for replacement switch tsimm Oven Repair (including Ranges and Cooktops) 0 03-03-2010 11:14 AM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 5 11-24-2009 02:14 PM
Replacement Of Ge Dryer Motor The Wiring Is Not The Same As Old One How Do I Wire It feisty63 Dryer Repair 1 01-07-2009 01:25 PM
