This gas oven, when set at 350, timer set to any time; when you turn on any burner; the clock looses power and has to be reset. i.e. clock time, oven and timer. The problem is intermittant. One time the oven displayed the actual temperature and the temp. drop and could not be canceled or programmed .
Any suggestions or advice?
