Discuss
GE Cooktop No Gas at Burners
 in
I have a GE Model JGP945WEK2WW cooktop. Last week, the burner I was using just quit working -- like someone
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Cooktop No Gas at Burners
  #1 (permalink)
Old 03-13-2013, 06:41 PM
Junior Member
Perry401 is on a distinguished road
Default GE Cooktop No Gas at Burners
Model Number: JGP945WEK2WW   Brand: GE   Age: 1 - 5 years
I have a GE Model JGP945WEK2WW cooktop. Last week, the burner I was using just quit working -- like someone had shut the gas off. The other gas appliances are okay, and the gas company came out and there is gas at the dirt-leg within the normal pressures for our community. There is absolutely no gas at the burners -- no gas smell, no gas to be ignited by the automatic sparker (that works), if you hold a match next to the burner, the flame does not even bend even a tiny amount, so I assume that no gas is getting through. The gas regulator was installed horizontally, which the man from the gas company said could be the issue. He said that dirt might have been blown by the dirt leg and because the regulator is installed horizontally, it can not fall out of the way when the gas pressure is neutralized in the pipe when the stovetop burners are turned off. However, I now realize after viewing the on-line parts manual that the safety shut-off valve is suppose to turn off the gas (with a valve section) and also enable the buzzer (with the switch portion). This gas valve has never turned the gas off to the burners -- it only makes the buzzer sound, but gas could still be turned on with one of the gas valves and would continue forever. The cook top has always been very slow -- as if starved for gas. A 6-quart pan of water for pasta took at least 20 minutes to boil. I am suspicious that either the gas safety valve (which apparently never worked right) might have failed in the "OFF" position OR the regulator is not working right OR both. Can you give any advice?
Related Models
General Electric JGP960SEA1SS Gas range
General Electric JGP960SED1SS Gas range
General Electric JGP962BEC1BB Gas range
General Electric JGP962BEC2BB Gas range
General Electric JGP962CEC1CC Gas range
General Electric JGP962KED2CC Gas range
General Electric JGP962SEC1SS Gas range
General Electric JGP962SEC2SS Gas range
General Electric JGP962TEC1WW Gas range
General Electric JGP962TEC2WW Gas range
General Electric JGP963BEC1BB Gas range
General Electric JGP963BEC2BB Gas range
General Electric JGP963BEJ1BB Gas range
General Electric JGP963BEK1BB Gas range
General Electric JGP963BEK2BB Gas range
General Electric JGP963CEC1CC Gas range
General Electric JGP963CEC2CC Gas range
General Electric JGP963CEJ1CC Gas range
General Electric JGP963CEK1CC Gas range
General Electric JGP963CEK2CC Gas range
General Electric JGP963SEC1SS Gas range
General Electric JGP963SEC2SS Gas range
General Electric JGP963SEF1SS Gas range
General Electric JGP963SEJ1SS Gas range
General Electric JGP963SEK1SS Gas range
General Electric JGP963SEK2SS Gas range
General Electric JGP963WEC1WW Gas range
General Electric JGP963WEC2WW Gas range
General Electric JGP963WEJ1WW Gas range
General Electric JGP963WEK1WW Gas range
General Electric JGP963WEK2WW Gas range
General Electric JGP970BEK1BB Gas range
General Electric JGP970BEK2BB Gas range
General Electric JGP970KEK1CC Gas range
General Electric JGP970KEK2CC Gas range
General Electric JGP970SEK1SS Gas range
General Electric JGP970SEK2SS Gas range
General Electric JGP970TEK1WW Gas range
General Electric JGP970TEK2WW Gas range
General Electric JGP975BEK1BB Gas range
General Electric JGP975BEK2BB Gas range
General Electric JGP975CEK1CC Gas range
General Electric JGP975CEK2CC Gas range
General Electric JGP975SEK1SS Gas range
General Electric JGP975SEK2SS Gas range
General Electric JGP975WEK1WW Gas range
General Electric JGP975WEK2WW Gas range
General Electric JGP979BEF1BB Gas range
General Electric JGP979BEF2BB Gas range
General Electric JGP979SEF1SS Gas range
General Electric JGP979SEF2SS Gas range
General Electric JGP979WEF1WW Gas range
General Electric JGP979WEF2WW Gas range
General Electric JGP985BEJ1BB Gas range
General Electric JGP985SEJ1SS Gas range
General Electric JGP985WEJ1WW Gas range
General Electric JGP989BC1BB Gas range
General Electric JGP989BC2BB Gas range
General Electric JGP989BC3BB Gas range
General Electric JGP989BC4BB Gas range
General Electric JGP989BK1BB Gas range
General Electric JGP989BK2BB Gas range
General Electric JGP989KC1CC Gas range
General Electric JGP989KC2CC Gas range
General Electric JGP989KC3CC Gas range
General Electric JGP989KC4CC Gas range
General Electric JGP989KK1CC Gas range
General Electric JGP989KK2CC Gas range
General Electric JGP989TC1WW Gas range
General Electric JGP989TC2WW Gas range
General Electric JGP989TC3WW Gas range
General Electric JGP989TC4WW Gas range
General Electric JGP989TK1WW Gas range
General Electric JGP989TK2WW Gas range
General Electric JGP990BEL1BB Gas range
General Electric JGP990SEL1SS Gas range
General Electric JGP990WEL1WW Gas range
Jenn-Air JGR8730ADQ RANGE- S/C F/S GAS
Jenn-Air JGR8730ADW RANGE- S/C F/S GAS
Jenn-Air JGR8750ADA RANGE- S/C F/S GAS
Jenn-Air JGR8750ADB RANGE- S/C F/S GAS
Jenn-Air JGR8750ADQ RANGE- S/C F/S GAS
Jenn-Air JGR8750ADW RANGE- S/C F/S GAS
Jenn-Air JGR8750BDB RANGE- S/C F/S GAS
Jenn-Air JGR8750BDQ RANGE- S/C F/S GAS
Jenn-Air JGR8750BDW RANGE- S/C F/S GAS
Jenn-Air JGR8775QDB RANGE- S/C F/S GAS
Jenn-Air JGR8775QDQ RANGE- S/C F/S GAS
Jenn-Air JGR8775QDS RANGE- S/C F/S GAS
Jenn-Air JGR8775QDW RANGE- S/C F/S GAS
Jenn-Air JGR8775RDB RANGE- S/C F/S GAS
Jenn-Air JGR8775RDS RANGE- S/C F/S GAS
Jenn-Air JGR8775RDW RANGE- S/C F/S GAS
Jenn-Air JGR8850ADA RANGE- S/C F/S GAS
Jenn-Air JGR8850ADB RANGE- S/C F/S GAS
Jenn-Air JGR8850ADQ RANGE- S/C F/S GAS
Jenn-Air JGR8850ADW RANGE- S/C F/S GAS
Jenn-Air JGR8850BDB RANGE- S/C F/S GAS
Jenn-Air JGR8850BDQ RANGE- S/C F/S GAS
Jenn-Air JGR8850BDW RANGE- S/C F/S GAS
Jenn-Air JGR8855ADS RANGE- S/C F/S GAS
Jenn-Air JGR8855BDS RANGE- S/C F/S GAS
Jenn-Air JGR8875QDB RANGE- S/C F/S GAS
Jenn-Air JGR8875QDS RANGE- S/C F/S GAS
Jenn-Air JGR8875QDW RANGE- S/C F/S GAS
Jenn-Air JGR8875RDB RANGE- S/C F/S GAS
Maytag JGR8875RDB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Jenn-Air JGR8875RDS RANGE- S/C F/S GAS
Maytag JGR8875RDS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Jenn-Air JGR8875RDW RANGE- S/C F/S GAS
Maytag JGR8875RDW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Jenn-Air JGR8885RDP RANGE- S/C F/S GAS
Jenn-Air JGR8890ADP FREESTANDING-DOUBLE OVEN-GAS
Maytag JGR8890ADP13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag JGR8890ADP14 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag JGR8890ADP20 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag JGR8890ADP21 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag JGR8890ADP22 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag JGR8895BDS12 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag JGR8895BDS13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
  #2 (permalink)
Old 03-14-2013, 01:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
You have to verify presence of the gas before and after the gas shut off valve.
If there is no gas before the gas shut off valve then it is responsibility of the gas company.
If there is gas after the gas shut off valve (when it's open), replace the cooktop pressure regulator.
- The pressure regulator Part number: WB19T10078
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cooktop burners on when they shouldn't be 440@gmx.us Oven Repair (including Ranges and Cooktops) 1 04-04-2011 05:29 AM
cooktop xlo burners out cjz Oven Repair (including Ranges and Cooktops) 0 01-24-2009 10:30 AM
Cooktop Burners MikeDiehl Oven Repair (including Ranges and Cooktops) 0 03-27-2008 01:48 PM
sealed cooktop burners low flame large burners only heavy chevy Oven Repair (including Ranges and Cooktops) 3 12-22-2007 08:37 AM
sealed cooktop burners low flame large burners only heavy chevy Oven Repair (including Ranges and Cooktops) 0 12-21-2007 05:36 PM
