Discuss
oven wont work at all
 in
My frigidaire range blew a bottom element sunday morning. As i tried to finish baking my biscuits by using the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven wont work at all
  #1 (permalink)
Old 03-12-2013, 06:53 PM
Junior Member
kdsull is on a distinguished road
Default oven wont work at all
Brand: Frigidaire   Age: 5 - 10 years
My frigidaire range blew a bottom element sunday morning. As i tried to finish baking my biscuits by using the broiler it would not work either. i replaced the bottom element today and neither of the elements will heat at all. The bottom element did not do the usual flash and out when it blew out. It arked for probably 10 seconds or longer so I'm thinking it may have blown something else electrical? The digital key pad still works fine and when you hit the bake button and set the temperature, after a couple seconds, the preheat and bake lights come on and I can hear a click like a relay kicks on to activated it but the element never heats. A friend says it probably burnt out the temperature probe but it is in the upper opposite corner from where the element blew out. Is that still a possibility ot is something else likely?
  #2 (permalink)
Old 03-13-2013, 02:27 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Sounds like the control board/timer blew.
Since the unit stays in pre-heat, it is trying to heat up so the oven sensor is OK.
Need to check to be sure there is not a thermal cut-out in the circuit to the elements.
If there is not, then the board is likely shot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Double wall oven panel wont work and oven won't go on Pat T Oven Repair (including Ranges and Cooktops) 1 03-31-2012 04:19 AM
self cleaning lock wont stop running oven wont work laura10 Oven Repair (including Ranges and Cooktops) 0 10-10-2011 02:58 PM
oven wont work RDHawk Oven Repair (including Ranges and Cooktops) 3 02-11-2011 10:23 AM
my oven wont work! jbcmiri Oven Repair (including Ranges and Cooktops) 1 04-13-2010 08:28 PM
Oven wont work daddy28 Oven Repair (including Ranges and Cooktops) 0 10-10-2009 03:54 PM
