Discuss
ge sealed burners not lighting
 in
Only two burners lighting (right rear and left front). The left rear and right front do not spark. I thought
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ge sealed burners not lighting
  #1 (permalink)
Old 03-11-2013, 08:47 PM
Junior Member
Juan Garcia is on a distinguished road
Question ge sealed burners not lighting
Model Number: jgb920tec2ww   Brand: GE   Age: More than 10 years
Only two burners lighting (right rear and left front). The left rear and right front do not spark. I thought maybe it was the spark module, but ruled it out by removing the burner head and just placing the burner cap closer to the electrode, doing this made the electrode spark. Could the burner cap be so worn out that over time the gap between it and the electrode is to big for the spark to jump? This stove has sealed burners. Any help is appreciated!!
Related Models
General Electric JGB920TEC2WW Gas range
General Electric JGB920TEC3WW Gas range
General Electric JGB920TEF1WW Gas range
General Electric JGB920TEF2WW Gas range
General Electric JGB920WEC1WW Gas range
General Electric JGB920WEC2WW Gas range
General Electric JGB928BEK1BB Gas range
General Electric JGB928BEK2BB Gas range
General Electric JGB928BEK3BB Gas range
General Electric JGB928BEK4BB Gas range
General Electric JGB928BEK5BB Gas range
General Electric JGB928BEK6BB GAS RANGE
General Electric JGB928KEK1CC Gas range
General Electric JGB928KEK2CC Gas range
General Electric JGB928KEK3CC Gas range
General Electric JGB928KEK4CC Gas range
General Electric JGB928KEK5CC Gas range
General Electric JGB928KEK6CC GAS RANGE
General Electric JGB928SEK1SS Gas range
General Electric JGB928SEK2SS Gas range
General Electric JGB928SEK3SS Gas range
General Electric JGB928SEK4SS Gas range
General Electric JGB928SEK5SS Gas range
General Electric JGB928SEL1SS Gas range
General Electric JGB928SEL2SS GAS RANGE
General Electric JGB928TEK1WW Gas range
General Electric JGB928TEK2WW Gas range
General Electric JGB928TEK3WW Gas range
General Electric JGB928TEK4WW Gas range
General Electric JGB928TEK5WW Gas range
General Electric JGB928TEK6WW GAS RANGE
General Electric JGBC12GEN1 Gas range
General Electric JGBC12GEN2 Gas range
General Electric JGBC15GEK1 Gas range
General Electric JGBC15GEK3 Electric range
General Electric JGBC15GEK4 Gas range
General Electric JGBC15GEN1 Gas range
General Electric JGBC15GEN2 Gas range
General Electric JGBC15GER1 Gas range
General Electric JGBC15GER2 Gas range
General Electric JGBC15GER3 Gas range
General Electric JGBC15GER4 Gas range
General Electric JGBC15GER5 Gas range
General Electric JGBC15GER6 Gas range
General Electric JGBC15GPK1 GE FREE-STANDING / DROP-
General Electric JGBC16GEH1 Electric range
General Electric JGBC16GEH2 Gas range
General Electric JGBC16GEH3 Gas range
General Electric JGBC16GEH4 Gas range
General Electric JGBC16GEJ1 Electric range
General Electric JGBC16GEJ2 Gas range
General Electric JGBC16GEJ3 Gas range
General Electric JGBC16GEJ4 Gas range
General Electric JGBC16GEJ5 Gas range
General Electric JGBC16GEJ6 Gas range
General Electric JGBC16GEJ7 Gas range
General Electric JGBC16GEP1 Gas range
General Electric JGBC16GEP2 Gas range
General Electric JGBC16GEP3 Gas range
General Electric JGBC16GEP4 Gas range
General Electric JGBC16GEP5 Gas range
General Electric JGBC16GEP6 Gas range
General Electric JGBC16GEP7 Gas range
General Electric JGBC16GPH1 Gas range
General Electric JGBC16GPH2 Electric range
General Electric JGBC16GPH3 Gas range
General Electric JGBC16GPJ1 Gas range
General Electric JGBC16GPJ2 Gas range
General Electric JGBC16GPJ3 Gas range
General Electric JGBC16GPJ4 Gas range
General Electric JGBC16GPJ5 Gas range
General Electric JGBC16GPJ6 Gas range
General Electric JGBC17EV1AD Gas range
General Electric JGBC17EV1WH Gas range
General Electric JGBC17EV2AD Gas range
General Electric JGBC17EV2WH Gas range
General Electric JGBC17EV3AD Gas range
General Electric JGBC17EV3WH Gas range
General Electric JGBC17EV4AD Gas range
General Electric JGBC17EV4WH Gas range
General Electric JGBC17GEH1 Gas range
General Electric JGBC17GEH2 Gas range
General Electric JGBC17GEH3 Gas range
General Electric JGBC17GEJ1 Gas range
General Electric JGBC17GEJ2 Gas range
General Electric JGBC17GEJ3 Gas range
General Electric JGBC17GEJ4 Gas range
General Electric JGBC17GEJ5 Gas range
General Electric JGBC17GEK1 Gas range
General Electric JGBC17GEK2 Gas range
General Electric JGBC17GEK3 Gas range
General Electric JGBC17GER1 Gas range
General Electric JGBC17GER2 Gas range
General Electric JGBC17GER3 Gas range
General Electric JGBC17GER4 Gas range
General Electric JGBC17GPH1 Gas range
General Electric JGBC17GPH2 Electric range
General Electric JGBC17GPH3 Gas range
General Electric JGBC17PEA1AD Gas range
General Electric JGBC17PEA1WH Gas range
General Electric JGBC17PEA2AD Gas range
General Electric JGBC17PEA2WH Gas range
General Electric JGBC17PEA3AD Gas range
General Electric JGBC17PEA3WH Gas range
General Electric JGBC17PEW1AD Gas range
General Electric JGBC17PEW1WH Gas range
General Electric JGBC17PEW2AD GAS RANGE
General Electric JGBC17PEW2WH GAS RANGE
General Electric JGBC18EV1WW Gas range
General Electric JGBC18EV2WW Gas range
General Electric JGBC18EV3WW Gas range
General Electric JGBC18EV4WW Gas range
General Electric JGBC20BEA1AD Gas range
General Electric JGBC20BEA1CT Gas range
General Electric JGBC20BEA1WH Gas range
General Electric JGBC20BEA2AD Gas range
General Electric JGBC20BEA2CT Gas range
General Electric JGBC20BEA2WH Gas range
General Electric JGBC20BEA3AD Gas range
General Electric JGBC20BEA3CT Gas range
  #2 (permalink)
Old 03-12-2013, 02:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Juan,
The problem can be a bad igniter (damaged ceramic) or a bad spark module.
Remove the burner cap and the burner head. Remove the two screws secured the burner base and lift up the burner base. Inspect the igniters.
If there is nothing wrong, replace the spark module which is inside the control panel/
- The igniter Part number: WB13T10010
- The spark module Part number: WB13K25
Here are the breakdown diagrams and Parts for GE JGB920TEC2WW Range - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to remove sealed burners AppHelp2012 Oven Repair (including Ranges and Cooktops) 0 01-27-2012 12:08 PM
Gas burners not lighting? starkey5 Oven Repair (including Ranges and Cooktops) 1 10-10-2009 08:04 AM
burners not lighting emarkov11 Oven Repair (including Ranges and Cooktops) 3 01-22-2009 03:54 PM
sealed cooktop burners low flame large burners only heavy chevy Oven Repair (including Ranges and Cooktops) 3 12-22-2007 08:37 AM
sealed cooktop burners low flame large burners only heavy chevy Oven Repair (including Ranges and Cooktops) 0 12-21-2007 05:36 PM
