Discuss
Igniter Failure
 in
Hello, I have no spark on any of the five burners. When I take the trim off of the control
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Igniter Failure
  #1 (permalink)
Old 03-11-2013, 08:52 AM
Junior Member
Brian Turnock is on a distinguished road
Default Igniter Failure
Model Number: SGM356S   Brand: Dacor   Age: 5 - 10 years
Hello, I have no spark on any of the five burners. When I take the trim off of the control knobs I can see a switch at each of the knobs, so I'm thinking that if each knob has its own spark switch then the problem must be with the spark module. Is this sound logic?
Brian
Related Models
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
White Westinghouse SGR351HQ0 DRYER
White Westinghouse SGR351HQ1 DRYER
White Westinghouse SGR351HS0 DRYER
White Westinghouse SGR351HS1 DRYER
White Westinghouse SGR641HQ0 DRYER
White Westinghouse SGR641HQ1 DRYER
White Westinghouse SGR641HS0 DRYER
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
Thermador SGSX365ZB
Thermador SGSX365ZS
Thermador SGSX365ZW
Thermador SGSX456ZB
Thermador SGSX456ZS
Thermador SGSX456ZW
Thermador SGT3001 COOKTOP
Thermador SGT3002 COOKTOP
Thermador SGT36 COOKTOP
Thermador SGT3601 COOKTOP
Thermador SGT36G01 COOKTOP
Thermador SGT36G02 COOKTOP
Frigidaire SGWS1349AS0 Frigidaire/washer
Bosch SGZ1000
Bosch SGZ1005
Bosch SGZ1024
Bosch SGZ1025
Bosch SGZ1040
Bosch SGZ1042
Bosch SGZ1046
Bosch SGZ2004
Thermador SH01BG
Frigidaire SH205C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH205C1QB Kel(v1) / Room Air Conditioner
Frigidaire SH206C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH206D1QA Kel(v1) / Room Air Conditioner
General Electric SH208W0WW Washer
Frigidaire SH310C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH310D1QA Kel(v1) / Air Conditioner
Hardwick SH4-34A9 SURFACE UNIT- GAS
Hardwick SH4-34W9 SURFACE UNIT- GAS
Frigidaire SH418C2SA Kel(v0) / Room Air Conditioner
Frigidaire SH418D2SA Kel(v1) / Room Air Conditioner
Hardwick SH7241819R WALLOVEN- STD GAS
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
  #2 (permalink)
Old 03-11-2013, 12:57 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
HI.
When none of the ignitors spark you should check if there is 120VAC to the unit, if the unit is properly grounded, then if there is no broken wire and only after that - replace the spark module.
Part number: AP3395928
Here are the breakdown diagram and Cabinet Parts parts for Dacor SGM365 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-16-2013, 10:56 AM
Junior Member
Default
Sure enough, wires were resting on one of the burner tubes at two different points. The wire insulation melted in both places, creating a dead short. The burner tube was melted at both points and the flash plume covers over half of the underside of the cooktop. Thank goodness for grounded circuitry!
After some solder repairs and some jury-rigging to ensure wires are kept away from hot tubes, everything is back in working order.
A big THANKS for your help.
  #4 (permalink)
Old 04-16-2013, 11:42 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Just replaced failed igniter switch on Stove, now igniter on before gas flowing Isotonic Oven Repair (including Ranges and Cooktops) 0 03-19-2011 11:14 AM
F5 failure shshampton Oven Repair (including Ranges and Cooktops) 0 08-01-2010 12:41 PM
F5 failure shshampton Oven Repair (including Ranges and Cooktops) 0 07-30-2010 09:27 AM
Gas dryer with new fuse, thermostat & igniter. Igniter did NOT glow & no heat yzhong Dryer Repair 1 08-10-2009 04:03 PM
Oven igniter failure (nat. gas) dmaguire Oven Repair (including Ranges and Cooktops) 1 11-25-2008 11:14 AM
