everthing works except the small bake oven. i have changed the ignitor at the bottom of the bake oven and did not help. replased the ignition module did not work. ignition make only a click noise but not a continiuse buzz the gas flow is ok and i can fire it with a lighter. Also once i switch the ignition module wires from small oven to the ignition module of large oven, the small oven works fine. but the large oven connected to the small ignition madule dose not work. I have replaced the ignition mudual three times(new parts) but still the same problem. the small bake oven wont work. i do not think it is the PC board. i need help. please advise me what part need to be changed. thanks
