Double Oven Bake Element needs replacement. I see you have element available but there is a burned end to one connector. 1. Looks like I will need to splice connector and part of a wire to get extra length to connect to end of element. 2. I will need high temp connector, high temp wire extension and high temp twist connector to do the job. What are those part numbers and can I order a wire with connector already crimped on? 3. I have traced the wire back to control panel, should I replace entire wire or just see if element was culprit with new one?
