| » Oven turns on by itself |
Model Number: arg7301ww Brand: Amana Age: More than 10 years
The broiler turns on by itself when a burner on the stovetop is turned on. Called a repair person who said it's probably the thermostat. Does this sound right? Any other ideas on what could cause this to happen and how to correct it? I don't use the oven at all and if there's any simple way to permanently disconnect the oven that would be a reasonable solution.
I am temporarily keeping the oven door open to prevent this from happening. DETAILS: manufacturer: amana model: arg7301ww mfg: p1143330nww Thanks! Ads By Google Related Models |
| Display Modes | |
| oven turns on and off by itself | arin | Oven Repair (including Ranges and Cooktops) | 3 | 12-07-2009 01:29 PM |
| Oven turns itself off | PastorJohn | Oven Repair (including Ranges and Cooktops) | 3 | 07-17-2009 03:59 PM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| oven turns on with out a tem being set | pmeyer60 | Oven Repair (including Ranges and Cooktops) | 1 | 09-23-2008 12:17 PM |
| Clock turns on when the oven is turned on but oven doesn't work | LMesey | Oven Repair (including Ranges and Cooktops) | 2 | 08-22-2008 11:20 AM |
